Go to Post Pretty sure getting a frowny face from a safety inspector means you're doing it right. - Cory [more]
Unread 17-04-2013, 17:57
matthewdenny's Avatar
matthewdenny matthewdenny is offline
FRC #6054 (Dukes)
Rookie Year: 2012
matthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant futurematthewdenny has a brilliant future
Encoders (What's up with those?)
So our official season is done, but we are looking forward to some off-season events. In our attempt to remedy some weaknesses from the season we are looking to add an encoder to our shooting system. It is a miniCIM connected by ~.9 Gear ratio to a pneumatic wheel.
We have no idea what kind of sensors to look into, where to purchase them, or how to install them. Any help would be great. Thanks!
Unread 17-04-2013, 18:04
Ernst's Avatar
Ernst Ernst is offline
Ernst
AKA: Ernst
FRC #1732 (Hilltoppers)
Rookie Year: 2011
Ernst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond reputeErnst has a reputation beyond repute
Re: Encoders (What's up with those?)
We have never had much luck mounting US Digital encoders to flywheels. We also haven't had luck with using another motor as a tachometer. This year and last year for flywheels we used photoelectric sensors pointed at retro-reflective tape strips stuck to the wheels. We have 6 strips of the tape stuck evenly around the wheel this year. 6 ticks = 1 revolution. Our speed control has had quick responses and accuracy.
FIRST Team 1732- Hilltopper Robotics
Website, Facebook, Twitter, Instagram
Unread 17-04-2013, 18:11
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Photoswitches are definitely the way to go. At the wheel speeds teams are using, finding encoders with shafts is difficult. Shaftless encoders like the US digital are a little touchy, and require decent tolerances too.
Optical sensors, on the other hand, will give you excellent speed control while allowing just about any alignment you feel like. There are a number of threads on this, however, so I suggest you search some of them out.
http://www.chiefdelphi.com/forums/sh...ht=photoswitch
Unread 17-04-2013, 18:52
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
How are you decoding the signal from the photosensor? i.e. Are you reading the number of counts, and dividing by elapsed time, or are you using getPeriod() to read the elapsed time between pulses?
What speed control algorithm are you using? PID, TBH, bang-bang, something else?
Unread 17-04-2013, 23:12
Ernst's Avatar
Ernst
AKA: Ernst
Rookie Year: 2011
I wasn't involved with the programming. Sorry. I'll try to direct my team's main programmer to this thread.
Unread 17-04-2013, 23:19
propionate's Avatar
propionate propionate is offline
Team co-lead and LabVIEW programmer
AKA: Stephen
FRC #1732 (Hilltopper Robotics)
propionate is on a distinguished road
Fortunately, I just made a video this weekend explaining how it all works. (It was for the SpaceX FIRST application, hence the title).
http://www.youtube.com/watch?v=zzNLlAUbbcU
Edit: Might only leave this up for a little while. Watch it quick!
Unread 17-04-2013, 23:39
Ether's Avatar
Rookie Year: 1969
Would you be interested in discussing this? If so, I have a few observations to make, and a few questions.
Unread 17-04-2013, 23:42
propionate's Avatar
AKA: Stephen
Sure, go ahead. The video length had to be 2 minutes or less so I had to skip a lot of details unfortunately.
Unread 17-04-2013, 23:59
Ether's Avatar
Rookie Year: 1969
OK here goes :-)
Is there a reason why you used the encoder VI, instead of the counter VI, for this non-quadrature sensor?
Why did you use 6 pieces of tape, instead of just one?
In an earlier post you said that your speed control is accurate to within 0.2% of point. What test equipment did you use to independently measure the wheel speed to make this determination?
Are your motors directly connected to the wheel, or are there gears or belts or chains between them?
What motor controllers are you using for the shooter motors?
What is the range of wheel speeds you are controlling?
Why did you need a custom PID? Did you try other methods (LabVIEW PID, TBH, bang-bang) and they didn't work?
Unread 18-04-2013, 00:03
Ernst's Avatar
Ernst
AKA: Ernst
Rookie Year: 2011
OK here goes :-)
I can answer some of these. We have CTRE Talons controlling BaneBots 550s which drive 4:1 gearboxes.
Unread 18-04-2013, 00:18
propionate's Avatar
AKA: Stephen
This is actually just a habit now. When I made my first feedback control loop for a flywheel last year, I had some trouble getting it to work using the counter. On a whim, I tried inputting them as encoders and it worked great. I've since figured out how to do it with the counter VI (some simple problem with the math I had), but never switched back.
This was the recommendation of a mentor. His explanation was that it allowed for a 'finer' count. I have tried it with just one piece of tape and didn't notice any significant different (just different scaling).
I should have said, the PID controller keeps the flywheel within a .2% error based on the readings from the photoelectric sensors. If those readings themselves are incorrect, then I'd have to rescind that statement.
See post by team member above. Directly connect w/ 4:1 gearboxes.
See above - talons.
Do you mean in RPM? I'd have to check my documentation at the shop, I can't remember off the top of my memory.
The LabVIEW PID has worked fine for us in the past, but it's always more fun to write the code yourself, to a reasonable extent. Better learning opportunity for rookie programmers. I don't have much experience with the half-back or bang-bang controllers, so I can't comment on those. Would be interesting to try them though and see how they compare. Sorry I don't have a good response for this one!
Unread 18-04-2013, 00:45
Ether's Avatar
Rookie Year: 1969
Thanks for the detailed answers.
I don't have access to the LabVIEW help files here, so one more question:
Can you tell me what the "12" input is for in the "Configure Timer" vi, and why did you chose that particular number.
Unread 18-04-2013, 00:54
propionate's Avatar
AKA: Stephen
Number of samples to average. I think it was a bit of trial and error until we got a smooth reading from the photoelectrics.
Unread 18-04-2013, 01:05
Ether's Avatar
Rookie Year: 1969
Can you tell me, the way you have the encoder configured, is it sampling both rising and falling edges?
  #15   Spotlight this post!
Unread 17-04-2013, 23:27
asteb27 asteb27 is offline
FRC #0293
asteb27 is an unknown quantity at this point
How did you measure how accurate you were?
Originally Posted by Tom Line View Post
Photoswitches are definitely the way to go. At the wheel speeds teams are using, finding encoders with shafts is difficult. http://www.chiefdelphi.com/forums/sh...ht=photoswitch
We have encoders in the 10,000 rpm range. I know some teams are running faster than 10k rmp, but plenty (like us) are running much slower than that.
I've used both of the following with no problem
http://www.digikey.com/product-searc...256&vendor=136
http://www.usdigital.com/products/en...otary/shaft/S1
