Re: Make your Champs predictions!
And that, my friends, is how 701 and 2169 swept at Colorado.
At the level we're talking about, which is divisional elminations, it's not about possible points scored, but how consistently high the scoring is of each robot, regardless of opposition. A cycler who is known to bob and weave and put up 15/16 discs a match could see more value than an FCS that can kick out 24 discs but miss a bunch because of any factor affecting accuracy.
Those are points the other alliance can steal at this level, where you could have three robots on an alliance who can each clear more than a third of the discs behind the wall each match. I'm slightly dismissive towards FCS robots because I see them falling to second pick in a lot of cases. For 2nd picks, alliances will probably look for consistent scoring in any form over the way you get the points to the hole, and cyclers are usually more accurate than FCSes, because dialing it in at a close range is not something that happens. Last edited by PayneTrain : 20-04-2013 at 00:07. |
There's more than one way to stop a FCS. If the robots on your alliance work together and have good DTs, there's no reason that you should be beaten by a *pure* FCS.
A FCS that can also cycle well is an entirely different animal. |
If FCS is well designed, it can beat a 60" blocker on it's own. An 84" blocker however requires some help from alliance partners. Even if the FCS is being blocked, some good ones can cycle as well. If a robot has a hastily attached 84" blocker that doesn't move that can mean they are trapped in their zone all match while the FCS is cycling.
Edit: Yes yes, I agree. A team with more auto points has a great shot of seeding above 1114 (possibly even 118). Last edited by EricDrost : 20-04-2013 at 17:39. |
As discussed above, it seems unlikely that 1114 will be first seed, as they only get 18 in autonomous. However, 1114 will probably be an excellent first pick for the first seed.
They were the highest scoring robot at SVR in autonomous and teleop points-averaging about 80 disc points per match, IIRC. |
Also, 469 prefers to cycle despite an excellent ground pickup, and no one is going around saying 469 has a slow pickup. If you have 4 frisbees far away from eachother, it's easier to go to the feeder station and get 4 instead of driving around the entire field scouring for discs. If you noticed, 254 and 2056 always had a supply of discs close to their scoring location. |
#10
4451 is getting picked in Newton. I guarantee it.
#11
Wow, I just saw a video of them, I think I wanna rethink my prediction
#12
The only team that does that type of thing is 1114. They are one seriously polished outfit. Their pit was spotless and so neat. |
#13
Their bumpers are so shiny too...
#14
Here are my predictions as seen in my April Absurdity Bracket:
Archimedes: 469, 987, 2468 Curie: 2056, 67, 4080 Galileo: 118, 1114, 2512 Newton: 1986, 195, 2789 Curie and Galileo win in the first round and Curie breaks the curse by winning with the combination of 2 full court shooters/possible cycles and the amazing ground pickup of 2056. I really think that any of these four alliances could win it all (if they get formed) and I just can't want untill I see the outcome this year!! |
#15
Not anymore. With the elimination of the regional website award, and the fact that they can't apply for chairman's anymore limits them.
