Re: Colson Wheels??
(As a huge fan of your swerve as well as a huge fan of Colsons, this was one of the questions I forgot to ask while taking a look at your swerve at Lehigh) |
Re: Colson Wheels??
We run colsons every year, you will not be disappointed. As for belts, calculating the center to center distances for the pulley placement is well worth the effort (and it isnt very difficult). The Gates HDT belts that come in the KOP will not stretch or wear over the course of a competition season if they are tensioned properly and your belt runs are straight. Even if you implement them terribly, Gates makes really high quality belts, it is doubtful you will break one.
Also, that WDC looks great, if you use this drivetrain, chances are it will be one of the best at any regional you attend. |
Re: Colson Wheels??
1) We measured the friction coefficients of the HiGrip wheels (on carpet) and were favorably impressed. 2) The weight and cost of the HiGrips were in the direction we wanted to go with our swerve units. 3) Ease of mounting was tertiary consideration. That said, I've always been a big fan of easy when it doesn't sacrifice performance. Mechanically, we never had a problem with driving the Colsons, but the same is true (so far) with the HiGrips. The HiGrips do wear faster. |
Re: Colson Wheels??
WCP products has two options, live axle and dead axle.
To use with the kitbot (dead axle) you'll need the hubs and two bearings for each wheel. |
Re: Colson Wheels??
WCProducts has some good products to help you get started. They make both live axle and dead axle hubs for colson wheels.
Edit: Everybody has the same idea! These must be really good. Last edited by ehfeinberg : 17-04-2013 at 19:54. Reason: Some people are ninjas... |
