Go to Post But please take into account that each year, the GDC has to come up with a rule book that will spend the next three months being picked apart by 40,000 of the brightest, most creative minds on the planet. I think they do an outstanding job of it. - dtengineering [more]
Unread 17-04-2013, 22:19
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Limit Switch Issues
Has anyone had issues with limit switches tripping due to excessive vibraton?
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
Unread 17-04-2013, 22:22
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Rookie Year: 2012
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Re: Limit Switch Issues
No, but a way to fix that would to be to put a filter on your limit switch in code. That way it has to stay down for a certain amount of time before the code reads it as tripped.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 17-04-2013, 23:34
asteb27 asteb27 is offline
FRC #0293
asteb27 is an unknown quantity at this point
What limit switches are you using? Also, that much vibration may point to a mechanical issue (for example, non symmetric shooter wheels)
Unread 17-04-2013, 23:35
lonnie lascelle's Avatar
lonnie lascelle lonnie lascelle is offline
Team Mentor
FRC #0930 (Mukwonago BEARs)
Rookie Year: 2011
lonnie lascelle is on a distinguished road
We have noticed back EMF noise generated from the motors to cause false tripping "limit switch closures" on our robots. Many of the false triggers can last for a second or two. Filtering in code, suppressing via capacitor, using 5 volts as input, using ferrite doughnuts, and assuring good wiring practice(keeping wires as short as possible for motor and signals, twisting pairs, not running signal wires near or in parallel with motor power wires). generally eliminates these issues. Be sure to ward off this in all areas to limit the issue. Have you tried to put a meter on the limit switch? Start by using a AA battery in-line and set meeter to hold peak or min/max hold (assure the robot wires are not connect) and then drive the robot causing vibration to see if it actually mechanically opens or bounces? Try to confirm that the limit is mechanically vibrating open and closed. We have often thought that we must have a bad limit or excessive vibration only to find noise.
Unread 18-04-2013, 09:34
zaphodp.jensen zaphodp.jensen is offline
Alumni and Mentor of 3130
AKA: Pierce Jensen
FRC #3130 (East Ridge Robotics Ominous Raptors (E.R.R.O.R.'s))
zaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the roughzaphodp.jensen is a jewel in the rough
One other simple thing to try is just making a mechanical "filter". This year, my team had issues where a limit switch with a longer paddle was bouncing up and down, preventing us from using our lifter. The solution: We wrapped a piece of surgical tubing around the paddle, and attached it above the limit switch, so the tubing was slightly stretched. It worked great, and we didn't have any more false triggers.
Unread 18-04-2013, 17:08
inkspell4's Avatar
Rookie Year: 2011
Do you have a picture of this?
Rookie Year: 2011
Unread 19-04-2013, 20:08
inkspell4's Avatar
Rookie Year: 2011
What is a good robust type of limit switch?
Rookie Year: 2011
Unread 19-04-2013, 20:54
timytamy's Avatar
timytamy timytamy is offline
AKA: Tim
FRC #3132 (The Thunder Down Under)
Team Role: Electrical
Rookie Year: 2010
timytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant futuretimytamy has a brilliant future
We had an issue where the switch where the micro switch that we used to position frisbees before the shooter would bounce mechanically, ie occasionally it would detect two frisbees passing through instead of the one. The switch was set up so that it had a flexible surgical tubing extension that contacted the frisbee. We found the extra mass of the tubing would give it a higher inertia, and give it a higher tendancey to bounce.
We solved this by removing the tubing and by repositioning the switch so that it contacted a bent metal section of the lever, in tandem software also implemented debouncing code. (Which I think we disabled after fixing the problem mechanically)
As for what limit switch, in Australia we use: http://australia.rs-online.com/web/p...itches/515735/ It is pretty much identical to the one that came in the KoP (except grey, and slightly higher current rating) and has been very versatile.
Tim
Tim W
FIRST® Team 3132 - The Thunder Down Under
Sydney, Australia
Website | Facebook | Youtube
Unread 19-04-2013, 22:37
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Lonnie,
I am a little surprised at the noise problems you are having. If you use the normally closed contacts, then the line impedance is so low (effectively zero ohms) that noise would only affect the input circuitry if a motor was directly connected to the switch. Even when using the normally open contacts there is still a low enough impedance by the DSC input to be relatively immune to noise pickup. What you may have is an intermittent switch contact that is affected with vibration. The result would be a rapidly changing trigger to the DSC. This should be easily diagnosed by rapping the switch with the insulated end (handle) of a screwdriver. Microswitches can be damaged by rough handling of the exterior contacts. In rare cases, the internal spring can be damaged or broken resulting in the effect you describe.
Al
WB9UVJ
www.wildstang.org
Unread 21-04-2013, 16:11
inkspell4's Avatar
Rookie Year: 2011
Tim
Is there any way that i can see the code that you wrote?
Rookie Year: 2011
Unread 21-04-2013, 16:31
Shiri Shiri is offline
FRC #0612
Shiri is an unknown quantity at this point
612 uses similar logic with our joysticks:
https://github.com/anidev/612-2013/b...edJoystick.cpp
(see GetRawButton())
Hope this helps!
Unread 08-05-2013, 20:32
inkspell4's Avatar
Rookie Year: 2011
To update this problem has not yet been solved.
It has been determined that vibration inside the limit switch is causing the problem.
Hardware solutions would be prefered.
Rookie Year: 2011
Unread 08-05-2013, 20:42
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Perhaps vibration isolating the switch by mounting it on shock absorbing foam rather than directly to a solid piece of vibrating frame.
Maybe a firmer style switch like the big ones we've received in older kits.
Unread 09-05-2013, 07:28
Pendulum^-1's Avatar
Pendulum^-1 Pendulum^-1 is offline
Mentor
AKA: Jim Grove
FRC #1915 (Firebird Robotics)
Rookie Year: 2007
Pendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nicePendulum^-1 is just really nice
Lightbulb Re: Limit Switch Issues
Recommend going optical.
https://www.sparkfun.com/products/9299
https://www.sparkfun.com/products/9322
(Get the breakout board with the photo interrupter.)
Or maybe try this:
https://www.sparkfun.com/products/246
If nothing else, extend a small, opaque tab in a position such that the above products give you a return at an appropriate location.
We tested the photo interrupter out for a home made linear encoder this year. While we never used it, the concept worked quite well, with the interrupter/optical limit switch hooked to the digital input on the sidecar. The Optical Detector / Phototransistor could pointed across the path of your mechanism, but close enough to the path so that when the mechanism passed across the interrupter, you got a response. Should be very accurate. While we have not tried this, I plan to test out the concept this summer, to have another item in our bag of tricks.
Jim Grove, Mentor
firebirds1915.blogspot.com
(2007-2017) 1915, McKinley Tech HS, Washington, DC
(2009) 2932, Mid-Pac Institute, Honolulu, HI (Rookie Season)
(2011) 2425, Hillsborough HS, Tampa, FL
(2013-2015) 4464, College Park, MD, 2013 Rookie All Star Winner and 2014 Regional Champions, Washington, DC
FIRST is not rocket science. But it is like drinking from a fire hose.
  #15   Spotlight this post!
Unread 09-05-2013, 07:38
Unsung FIRST Hero
Rookie Year: 1996
Can you post a photo of the mounting of the switch. These are used in industrial applications all the time and vibration is rarely a problem. Often the actuator is actually the problem and that is easily solved with external damping. As I stated earlier it is always possible you have a damaged switch. The construction of the microswitch uses a spring to hold the contacts in place.
Are you experiencing "contact bounce" instead? There are certainly electronic and programming techniques that can eliminate this condition.
Al
WB9UVJ
www.wildstang.org
