Re: 6 CIMs and 4 MiniCIMs - Will they stay?
Maybe someone from 971 can answer this, but what gear were they in (and what speed)? Do you have video of the match?
I believe its on TBA. It might have been match 50.
Remember 971 also has 2" wide wheels which give them a ton more traction. I have a hard time believing that they are not traction limited in low gear, but is it possible that in high gear they blow faster because of this?
We had this issue a few times this year. We are traction limited in low gear, but not in high gear. The instances where this happened occurred when our driver failed to shift down soon enough. Because of the 2 extra CIMS, the breaker blew much quicker than our driver was used to reacting to shift down. If we do a 6 CIM drive next year, there will likely be some mechanical and/or programming solution to prevent this from happening.
We gotta credit 766's old mentor Scott Baron for teaching us this back in 2005. |
Yeah i did this in 2003. Long wheel base 4 wheel drive with 2 inch wide wheels w/ conveyor tread on them. It was two CIMs and 2 drill motors. Couldn't turn and would pop the breaker from the stall. Would up changing to low traction wheels.
Yes. We had 6 CIM's for our drive train, and in our first event of the year (Hatboro Horsham), we got into a few pushing matches and popped our main breaker more than twice. When all of our CIM's stalled, they pulled about 780-800 amps for more than a few seconds, which is definitely enough to trip the main breaker.
Last edited by Pratik Kunapuli : 29-04-2013 at 09:23. Reason: Added more information. |
We were also conscientious that it was possible to trip the main breaker and didn't push for that long the rest of the season.
#10
I personally tripped it in 4 matches during my time as a driver. We also tripped it twice this year. In both cases we had a 4-motor 2-speed drive that was traction limited in low gear. In other cases, we've seen battery cables heat up and become sticky, and also melted a few robot-side battery connectors (they're only rated for 50a) on practice robots (even with cool-down times between batteries). We used 4-gauge robot-side battery cables to hopefully improve this, and did not melt anything this year. |
#11
you just gear to break traction before you trip the breaker.
#12
Before they allowed 6 CIMs, several teams used to use FP motors as a 5th and 6th motor in their drivetrains due to similar specs.
#13
Fixed that for you. FPs in the drivetrain will probably end up running at or near stall quite a bit, and they don't like stalling.
#14
Either way, I've heard of quite a bit of success from this. At the very least, it's worth exploring. - Sunny G. |
#15
I know of a couple of very, very good teams that did FP+2 CIMs in the drive for one year and then swore never to do it again. Something about having to replace the FPs--I know one of those teams had to do it on Thursday at a regional and it was a long job, or something like that.
