Go to Post Be civil in all things and you will get far. - Wetzel [more]
Unread 29-04-2013, 00:01
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Re: 6 CIMs and 4 MiniCIMs - Will they stay?
Originally Posted by EricH View Post
I know of a couple of very, very good teams that did FP+2 CIMs in the drive for one year and then swore never to do it again. Something about having to replace the FPs--I know one of those teams had to do it on Thursday at a regional and it was a long job, or something like that.
I know 254 and 968 did it 2008 and had problems. We used 550s this year and ran into no problems whatsoever.
Also anyone doing a 6 motor drive needs to make sure they have a traction limited gear
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 29-04-2013, 04:39
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
We ran 2 CIM's and 2 FP's in 2006. These were the super awesome 300W FP's that were only rated for 6V, IIRC.
It was a nightmare. We smoked too many motors to count and our drive was unreliable at the worst possible times as a result. We did indeed swear we would never use only 2 CIM's in a drive again (Lunacy notwithstanding).
2001-2004: Team 100
2006-Present: Team 254
Unread 29-04-2013, 19:05
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
Originally Posted by cbale2000 View Post
Does anyone know of an instance where this has EVER happened on a FIRST robot?
As Jared and Pratik said above, it's happened to us at least once this season. Took a good bit a defense to pop it, but it can happen. There are a handful of other teams that have complained of popping breakers as well, most of which are using high traction drives with 6 CIMs or 4 CIMs and some additional motor.
Looking back, I'm fairly sure that prior to this year electrical shorts were the most/more common cause of the 120a breaker tripping, but I'm not sure.
Originally Posted by AlexH View Post
you just gear to break traction before you trip the breaker.
There's a bit more to it than that. In a perfect world, when you break traction between the drive wheel and surface (carpet) the motor would then essentially spin at free speed and draw little to no current (see 2009) but with carpet that isn't the case.
More often than not, a wheels static COF is what's being used for current draw calculations rather than it's dynamic COF - which makes sense for seeing if you're traction limited. Most of the time, when people design something to be traction limited, it's so that they know that they won't have an issue in the off chance that their motors are stalled due to some interaction with an immovable object for a reasonably short period of time. Usually, this is all you need to do as long (more than a few seconds) instances of high load like that are pretty uncommon in recent FRC games.
There are occasions where you need to go a bit deeper into the issue than that. Once your wheels have broken traction with the carpet, the wheels Dynamic COF starts getting important. Most wheels have a Dynamic COF that's significantly lower than it's Static COF, but there are some wheels that don't so it's best to try and dig up some hard numbers first. Anyway, once you're out of the traditional traction limited realm and Dynamic COF starts coming into play, you'll see that the motor is still under a decent amount of load and will draw the appropriate amount of current. Depending on the setup, this can be (probably is) enough of a current draw to start tripping breakers (either 40A or the 120A main) after a few seconds.
One more thing to be aware of: The weight/normal force on your robot's drive wheels may increase during a pushing match. This is especially true for low bumper robots pushing high bumper robots as the bumpers tend to ride onto one another. You might be traction limited at normal weight, but what if an additional 60lbs or so is on top?
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 28-04-2013, 21:11
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
Rookie Year: 2011
theawesome1730 will become famous soon enough
We used all 6 CIMs and all 4 Minis and absolutely loved it. I really hope they continue the use of all 4 Minis even if they drop back to 4 CIMs
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 28-04-2013, 22:58
coalhot's Avatar
coalhot coalhot is offline
Assistant to the regional manager
AKA: Phil
FRC #4454 (Artisan Rockets)
Rookie Year: 2007
coalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant futurecoalhot has a brilliant future
Send a message via AIM to coalhot
I like the idea of 6 CIMS and 4 MiniCims. However, if FIRST does decide to stay with them, I'd like to see them ramp up the battery size and PDB.
Maybe they'll do that with the new control system. Who knows?
Current home, 4454 (Glowa's ghetto Philly FRC team). Check us out!
My posts represent my personal views only, and do not represent the views of my team, its school, sponsors, or FIRST.
Unread 29-04-2013, 00:30
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is offline
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Team Role: Coach
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
I sure hope so.
Unread 28-04-2013, 20:16
TheMadCADer TheMadCADer is offline
Rookie Year: 2010
TheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant futureTheMadCADer has a brilliant future
Mini-CIMs and BAG motors are definitely here to stay since they're pretty much replacements for the FPs and Globes. I think the CIM count could vary between 4-6 from year to year, though I do like having more than just 4. However, chances are that we'll continue to only see extra CIMs in years with climbing/hanging endgames.
