Go to Post Remember, however, that such software limitations in no way approximate the functionality of a multiple-speed, mechanical transmission. They're simply a convenient way of limiting your students' lead feet. - Madison [more]
Unread 29-04-2013, 12:27
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
2013 Qual Schedule Analysis
All 81 Qual Schedules for 2013 (Weeks 1 thru 7 Regionals & Districts, plus MAR, MSC, Archimedes, Curie, Galileo, & Newton) are summarized in individual CSV files (which can be opened directly in Excel if file association is set).
For each event, a matrix shows which teams each team played With and Against.
FWIW, this shows anomalies in the scheduling algorithm where oftentimes a team will play with or against another team more than once, while not playing with or against dozens of other teams in the event.
http://www.chiefdelphi.com/media/papers/2822
Unread 29-04-2013, 14:31
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Re: 2013 Qual Schedule Analysis
I noticed this at Northern Lights. There were a many teams we had two matches with (both with and against). But there were 5 teams we never played with or against, which was quite odd to me given there were only 48 teams and 10 qualification matches.
-T
Unread 29-04-2013, 16:23
MikeE's Avatar
MikeE MikeE is offline
Wrecking nice beaches since 1990
no team (Volunteer)
MikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond reputeMikeE has a reputation beyond repute
A few points.
There is a description of an early version of the scheduling software on the Idle Loop website. The FMS may use a more recent version but let's assume the algorithm is the same.
The scheduling algorithm is stochastic, i.e. it has a random element to it, which is a standard approach for solving a complex optimization problem.
The particular criterion discussed above is "Pairing Uniformity" and it is one of the goals being optimized, but that has to be balanced against several other criteria including computation time.
Since the algorithm is stochastic, the "good schedule" metric isn't really do the same teams play with/against each other more than once but rather does this happen much more frequently than we expect.
Smaller events such as Western Canada or Toronto East have few enough teams that it's a mathematical necessity that the same teams face each other more than once.
Finally, most Regionals have 1-5 teams who play an additional surrogate match. If the purpose of this analysis is to see how it affects ranking then a team's surrogate match should really be excluded, although they would still count as a partner or alliance for other teams. (This is a small effect)
Unread 29-04-2013, 21:44
Shu Shu is offline
FRC #2137 (TORC)
Shu is an unknown quantity at this point
At the Livonia district, we had to go against Team 27 in three of our first four matches during qualifications. We also played with them once in our last match of qualifications. It just seemed that the scheduling algorithm should have prevented something like that from occurring.
Unread 30-04-2013, 12:49
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
Team Role: Tactician
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
Ok maybe I am just not getting it what is the difference between W and A and what does each number in each mean
EDIT: Wait Senior moment W is With and A is Against? and the numbers are the occurrences
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
Unread 01-05-2013, 15:48
Ether's Avatar
Rookie Year: 1969
I just added a one-page summary of the 162 qual schedule analysis spreadsheets.
Unread 01-05-2013, 16:19
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
Rookie Year: 2012
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
All 4 divisions in worlds have the same numbers. Does that mean they don't use random generation?
All opinions are my own.
Unread 01-05-2013, 16:33
MikeE's Avatar
no team (Volunteer)
With only 8 matches and a field of 100 any reasonable optimization algorithm should converge to the same general solution: play with 16 different teams and against 24 other different teams.
That solution will always give the same summary statistics.
Unread 01-05-2013, 17:24
MikeE's Avatar
no team (Volunteer)
...although that's not what the schedule summaries are showing, since a pair of teams do play each other more than once.
So I reverse my conclusion.
Unread 01-05-2013, 17:59
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
It appears that the match scheduler does not care about multiple opponents/partners in surrogate matches. I checked the Archimedes schedule and the teams that had multiple opponents played each other once in their surrogate match and once in a match that counted.
Here is the scheduler's analysis of the Archimedes schedule, which does not show repeats in matches that count.
Code:
Schedule Statistics
          #: number of matches played, a '+' after the number
               indicates one additional round as a surrogate
          d: minimum delta between matches (e.g. '1' means back-to-back)
       part: number of distinct partners followed by most frequent repeat count
        opp: number of distinct opponents followed by most frequent repeat count
       both: number of distinct teams seen as partner or opponent
               followed by most frequent combined repeat count
        r/b: balance between red and blue alliance appearances
               eg, 3b means team appeared as blue 3 times more than as red
 4+ repeats: any teams seen four or more times as partners or opponents
 team   #   d    part    opp    both    r/b   4+ repeats
   11:  8  11 | 16  1 | 24  1 | 40  1 |  0
   20:  8   9 | 16  1 | 24  1 | 40  1 |  0
   33:  8   9 | 16  1 | 24  1 | 40  1 |  0
   51:  8   8 | 16  1 | 24  1 | 40  1 |  0
   71:  8   9 | 16  1 | 24  1 | 40  1 |  2r
   78:  8  11 | 16  1 | 24  1 | 40  1 |  0
  126:  8   9 | 16  1 | 24  1 | 40  1 |  2r
  172:  8  11 | 16  1 | 24  1 | 40  1 |  2r
  236:  8  14 | 16  1 | 24  1 | 40  1 |  0
  254:  8   8 | 16  1 | 24  1 | 40  1 |  2b
  291:  8   9 | 16  1 | 24  1 | 40  1 |  2b
  314:  8  11 | 16  1 | 24  1 | 40  1 |  0
  316:  8   8 | 16  1 | 24  1 | 40  1 |  0
  321:  8   9 | 16  1 | 24  1 | 40  1 |  2r
  326:  8   9 | 16  1 | 24  1 | 40  1 |  2b
  365:  8   8 | 16  1 | 24  1 | 40  1 |  0
  379:  8  10 | 16  1 | 24  1 | 40  1 |  2b
  433:  8+ 11 | 16  1 | 24  1 | 40  1 |  0
  469:  8   8 | 16  1 | 24  1 | 40  1 |  0
  525:  8  11 | 16  1 | 24  1 | 40  1 |  2r
  639:  8   9 | 16  1 | 24  1 | 40  1 |  2b
  694:  8  14 | 16  1 | 24  1 | 40  1 |  0
  701:  8   8 | 16  1 | 24  1 | 40  1 |  2b
  801:  8   9 | 16  1 | 24  1 | 40  1 |  2r
  812:  8   8 | 16  1 | 24  1 | 40  1 |  0
  836:  8   9 | 16  1 | 24  1 | 40  1 |  0
  840:  8   9 | 16  1 | 24  1 | 40  1 |  0
  846:  8  11 | 16  1 | 24  1 | 40  1 |  2r
  868:  8   8 | 16  1 | 24  1 | 40  1 |  2b
  910:  8   8 | 16  1 | 24  1 | 40  1 |  2r
  930:  8+  9 | 16  1 | 24  1 | 40  1 |  0
  948:  8   8 | 16  1 | 24  1 | 40  1 |  0
  955:  8   8 | 16  1 | 24  1 | 40  1 |  0
  973:  8  10 | 16  1 | 24  1 | 40  1 |  0
  987:  8+  8 | 16  1 | 24  1 | 40  1 |  0
 1011:  8  10 | 16  1 | 24  1 | 40  1 |  0
 1071:  8  12 | 16  1 | 24  1 | 40  1 |  0
 1075:  8   9 | 16  1 | 24  1 | 40  1 |  2b
 1100:  8   8 | 16  1 | 24  1 | 40  1 |  2b
 1334:  8  13 | 16  1 | 24  1 | 40  1 |  0
 1448:  8  10 | 16  1 | 24  1 | 40  1 |  0
 1519:  8  10 | 16  1 | 24  1 | 40  1 |  0
 1595:  8   8 | 16  1 | 24  1 | 40  1 |  0
 1610:  8   9 | 16  1 | 24  1 | 40  1 |  2b
 1660:  8   8 | 16  1 | 24  1 | 40  1 |  2r
 1714:  8   9 | 16  1 | 24  1 | 40  1 |  2b
 1747:  8  11 | 16  1 | 24  1 | 40  1 |  0
 1756:  8   8 | 16  1 | 24  1 | 40  1 |  0
 1796:  8  11 | 16  1 | 24  1 | 40  1 |  0
 1836:  8   8 | 16  1 | 24  1 | 40  1 |  2b
 1868:  8  10 | 16  1 | 24  1 | 40  1 |  2b
 1902:  8   8 | 16  1 | 24  1 | 40  1 |  0
 1967:  8   8 | 16  1 | 24  1 | 40  1 |  2b
 2016:  8  10 | 16  1 | 24  1 | 40  1 |  0
 2081:  8  11 | 16  1 | 24  1 | 40  1 |  2r
 2137:  8   8 | 16  1 | 24  1 | 40  1 |  0
 2165:  8   9 | 16  1 | 24  1 | 40  1 |  0
 2408:  8  13 | 16  1 | 24  1 | 40  1 |  0
 2415:  8  12 | 16  1 | 24  1 | 40  1 |  0
 2457:  8   9 | 16  1 | 24  1 | 40  1 |  0
 2468:  8   8 | 16  1 | 24  1 | 40  1 |  2r
 2486:  8   9 | 16  1 | 24  1 | 40  1 |  2r
 2543:  8   8 | 16  1 | 24  1 | 40  1 |  2r
 2590:  8  12 | 16  1 | 24  1 | 40  1 |  0
 2604:  8   9 | 16  1 | 24  1 | 40  1 |  0
 2614:  8   9 | 16  1 | 24  1 | 40  1 |  0
 2704:  8   8 | 16  1 | 24  1 | 40  1 |  0
 2705:  8  12 | 16  1 | 24  1 | 40  1 |  0
 2709:  8  10 | 16  1 | 24  1 | 40  1 |  0
 2959:  8  11 | 16  1 | 24  1 | 40  1 |  2b
 3003:  8   9 | 16  1 | 24  1 | 40  1 |  2r
 3008:  8   9 | 16  1 | 24  1 | 40  1 |  0
 3044:  8+  8 | 16  1 | 24  1 | 40  1 |  0
 3145:  8  14 | 16  1 | 24  1 | 40  1 |  2r
 3242:  8  10 | 16  1 | 24  1 | 40  1 |  0
 3245:  8  12 | 16  1 | 24  1 | 40  1 |  0
 3310:  8  10 | 16  1 | 24  1 | 40  1 |  0
 3314:  8   8 | 16  1 | 24  1 | 40  1 |  0
 3467:  8   9 | 16  1 | 24  1 | 40  1 |  2b
 3478:  8   9 | 16  1 | 24  1 | 40  1 |  0
 3504:  8   8 | 16  1 | 24  1 | 40  1 |  2r
 3612:  8  10 | 16  1 | 24  1 | 40  1 |  2b
 3627:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4067:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4265:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4450:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4466:  8   9 | 16  1 | 24  1 | 40  1 |  0
 4470:  8   9 | 16  1 | 24  1 | 40  1 |  2r
 4471:  8   9 | 16  1 | 24  1 | 40  1 |  2r
 4499:  8  10 | 16  1 | 24  1 | 40  1 |  0
 4501:  8   9 | 16  1 | 24  1 | 40  1 |  0
 4537:  8  10 | 16  1 | 24  1 | 40  1 |  0
 4545:  8  13 | 16  1 | 24  1 | 40  1 |  0
 4585:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4589:  8  11 | 16  1 | 24  1 | 40  1 |  0
 4637:  8   8 | 16  1 | 24  1 | 40  1 |  0
 4673:  8   9 | 16  1 | 24  1 | 40  1 |  2b
 4731:  8   9 | 16  1 | 24  1 | 40  1 |  0
 4753:  8  12 | 16  1 | 24  1 | 40  1 |  2b
 4810:  8   8 | 16  1 | 24  1 | 40  1 |  2r
 best:  8  14 | 16  1 | 24  1 | 40  1 |  0
worst:  9   8 | 16  1 | 24  1 | 40  1 |  2  (38)
Unread 01-05-2013, 18:16
MikeE's Avatar
no team (Volunteer)
Code:
Schedule Statistics
That pattern continues in all 4 divisions and several other schedules based on 8 matches from 100 teams. The surrogate teams also appear in the last match in all cases I've looked at, so I suspect that's an artifact of the initial population of the matches.
So I think we're back to there being no evidence that the matches were not generated randomly with the standard scheduling algorithm.
Unread 01-05-2013, 18:44
Ether's Avatar
Rookie Year: 1969
At Razorback, there were 101 pairs of teams who played against each other twice.
There were 17 pairs of teams who played against each other 3 times.
There were 217 pairs of team who did not play against each other.
Each team played exactly 12 matches, so I assume there were no surrogates (or am I misunderstanding what a surrogate is, in this context?).
