Go to Post Well... as ready as we can be 30 days before build season... We definitely do not have a robot yet though... :) - pandamonium [more]
Unread 04-29-2013, 11:42 PM
drkabob drkabob is offline
Alum & Swag Coordinator Emeritus
AKA: Nathan Hakkakzadeh
FRC #1836 (Team 1836: The Milkenknights)
drkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant futuredrkabob has a brilliant future
Introducing SwagDrive. The drive code of the future.
So I attended the World Championships this year. It was great seeing all these high level robots. However, I had a problem with them, they drove too straight. They drove with too much precision. There was no sense of "YOLO", the robots did not drive with enough swag.
So I decided to remedy this issue at the programming level, by creating SwagDrive. SwagDrive increases the robot's level of swag by at least ten-fold. By using new and innovative algorithms (or rather "swagorithms"), SwagDrive decreases the robot's consistency and accuracy so that when it drives on the playing field it looks a lot cooler.
It is similar to ArcadeDrive with some important modifications. If the change on an axis is not larger than the "swag barrier", it will multiplied by the "swag multiplier" in order to "swag up" the driver's inputs. If the input is larger then the "swag barrier" for that particular cycle, then the robot's "swag level" increases by one. If the "swag level" becomes over 9000 the robot enters a moment of ultimate swag and rotates for one "swag period" (truly a YOLO move). Many of these values still need to be tuned and modified to achieve optimal swag.
You can find an example implementation written in Java by clicking here. While I have yet to test SwagDrive on a real robot, I can assure you that it will swag up your robot.
I look forward to your comments and hope that we can improve SwagDrive for future competitions.
(If you haven't figured it out yet, this is a joke. You can find 1836's robot code here by our main coder. I would strongly recommend not using the SwagDrive code on your robot, as you will likely lose control and possibly hurt the robot and the people around it.)
Best Regards,
Nathan Hakkakzadeh
Website: http://nathancod.es/
Twitter: @drkabob
Reddit: /u/drkabob
Check out our team's website! http://themilkenknights.com/
