Go to Post Act humble, avoid hubris, and post widely and thou shalt receivith postive rep. ;) - artdutra04 [more]
Unread 01-05-2013, 13:19
menns menns is offline
AKA: Michel Enns
FRC #1310 (Runnymede Robotics)
menns has a spectacular aura aboutmenns has a spectacular aura about
FRC Team Name Random Generator
Just for fun on bus on the way back from Championships I wrote a little Ruby script that generates random FRC team names based on the names of all this year's teams.
To run it you will need Ruby installed and you will need to change the file extension of the FRCNameRubyScript file to .rb
The names.txt data file should be in the same directory as the Ruby script.
Thanks to Ed Law's scouting database for the team names.
Unread 01-05-2013, 19:49
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
Rookie Year: 2011
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Re: FRC Team Name Random Generator
It seems like it exits the window after generating the team names.
2013 North Star Regional Industrial Design Award
2011-2013: FRC #3633 Catalyst
2014-20XX: FRC #3633 College Mentor
RPI Class of '17 / Materials Engineering
Unread 02-05-2013, 16:13
AKA: Michel Enns
In Windows if you run it from the command prompt you'll be able to see the results.
