Go to Post Through 30 years of teaching I've heard the same refrain..."I love science, I love math but I can't stand my language classes". Well enough is enough. Get over it. - Mr.B [more]
Unread 01-05-2013, 16:18
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
pic: 2013.5 Mock Game Pipefall
Unread 01-05-2013, 16:24
ehfeinberg's Avatar
ehfeinberg ehfeinberg is offline
AKA: Evan
FRC #0449 (Blair Robot Project)
Rookie Year: 2011
ehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant futureehfeinberg has a brilliant future
Re: pic: 2013.5 Mock Game Pipefall
Interesting concept, stacking pipes around a pole. However, I would think that the pipes should be obtained from the human player similar to how robots got tetras in 2005. I say this because it seems extremely difficult to pick up a slick PVC pipe from the ground, especially if it might just roll away. It seems that if you don't let teams get pipes from human players, rookie teams might have an exceedingly difficult time.
But looks like a lot of fun, and I would gladly have this be the game for 2015.
“They’ve done studies, you know. 60 percent of the time, it works every time.” — Brian Fantana
"You miss 100% of the shots you don't take." - Wayne Gretzky
"Simplicity is the ultimate form of sophistication" - Leonardo da Vinci
Unread 01-05-2013, 16:29
Engineering Coach
Team Role: Coach
We thought about that but wanted to make the challenge harder (it is fake game after all). So many times the human player rules just get in the way. Also how do you easily hand over a pipe to a robot safely? The tetras required a crazy system that disabled your robot when you stepped off a mat, if we never have a system like that again in FRC I will be a happy man. The 2007 system, through the driver station window or over the top, doesn't seem that much better. We also wanted the field easy to prototype for. If we built some kind of ramp for introducing them like this year it would be one more field element teams would need to build.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 01-05-2013, 16:41
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
Team Role: Leadership
ablatner is on a distinguished road
Looks interesting. I'd get rid of the Kinect and change hybrid to autonomous though. The Kinect and hybrid was pretty useless in 2012.
Also, what's the point of different height scoring poles? It looks like scoring on the 10' ones is worth the same as the shorter ones.
2009-2013: Student, Team 100
2013-????: ?
Unread 01-05-2013, 16:45
Engineering Coach
Team Role: Coach
It wasn't useful in 2012 because that game didn't require movement in auton and you started with most of the game pieces that you were going to have in auton. You also had very limited time and only one per alliance. We think with a game that encourages more movement in hybrid we could see teams take advantage of the alternative interface to the robot.
They are worth the same. The idea is that the more scoring pieces that are scored the harder it is to score them. That means that instead of what happened in 2011 teams are encouraged to score higher at the end of the game not the beginning (similar to 2005). Teams can decide to score only on the lower poles but eventually they might all be full so having a robot that can go to the high poles on your alliance may be useful.
Unread 01-05-2013, 17:08
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
Simple solution. Cut 4" diameter holes in the driver station walls. Have human players feed them through those holes. Probably dedicate specific locations (corners?) for the task, and potentially have a protected loading zone.
It doesn't really make the challenge too much easier, either, as the orientation of the pipes coming through the wall is different from the orientation the pipes must be scored in.
Unread 01-05-2013, 17:12
Engineering Coach
Team Role: Coach
How many teams got pieces from the 2011 human players? (1503 and who else?). We also don't like protected zones that cause ticky tack fouls.
Unread 01-05-2013, 18:24
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
So what you're saying is you're planning a takeover of the GDC to ensure a future of more interesting and challenging FRC games without ticky tack fouls...
Unread 01-05-2013, 18:58
Engineering Coach
Team Role: Coach
We tried to stay true to a real FRC game but sometimes we just had to get
rid of a few of the more annoying things.
Unread 01-05-2013, 21:07
cmrnpizzo14's Avatar
cmrnpizzo14 cmrnpizzo14 is offline
AKA: Cam Pizzo
FRC #3173 (IgKNIGHTers)
cmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond reputecmrnpizzo14 has a reputation beyond repute
I did not read too carefully but I like that you chose to allow teams to possess as many pipes as they design for. I prefer that to games where teams are limited to 1, 3, 4 etc.
FIRST Team 3173 The IgKNIGHTers
"Where should we put the battery?"
Unread 01-05-2013, 21:29
Rookie Year: 1998
Best brickbot hybrid/first 5s strategy: Drive forward and shove all your opponent's pipes into the corner.
Unread 01-05-2013, 23:08
Engineering Coach
Team Role: Coach
We had a lot of debate about this. We wanted a mass quantity game like 09 and a single object game like 2011. We almost limited the number of large pipes but thought better of it. If you can design for it why should the game penalize you?
That's why the pipes start on both sides of the field and some in the middle.
Unread 01-05-2013, 23:36
Rookie Year: 1998
Horrible game design idea just popped into my head. I have to commend you for eschewing the "top scoring piece owns a goal, now make some combos" bonus system in this game. The less we remind the GDC of that style of bonus, the better.
Unread 01-05-2013, 23:49
Engineering Coach
Team Role: Coach
The only one worse that we came up with was a bonus for the most length of pipe on a scoring peg. That would be disastrous for spectators.
I like this system because visually you should be able to get an idea of who is winning without real time scoring. Look at the field, are there more red or blue pipes scored? You won't know exactly but you can get a general idea if the match is close or not.
  #15   Spotlight this post!
Unread 02-05-2013, 09:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
How many teams got pieces from the 2013 human players? Why is 2011 the go to example? FRC teams has plenty of examples of how to pick up tubes from the 1997 and 2007 games. Throw them a game object they've never seen before, and they're far more likely to load from a human player than anywhere else (see 1997, 2005, 2013). Especially if they can't be lobbed across the field by the human player like they were in 2011.
Also, off the top of my head, 1218 also loaded from the human player in 2011.
And I'd rather have "ticky tack" fouls than make it borderline impossible for 30th percentile teams to load successfully.
Or just knock them all over and laugh as 50% of teams can no longer pick them up and re-orient them to score successfully.
