Go to Post If that track ball comes crashing into Exploding Bacon's robot there is literally going to be an Oink Oink BOOM!:yikes: - Koko Ed [more]
  #16   Spotlight this post!
Unread 04-05-2013, 16:21
1683cadder 1683cadder is offline
FRC #1683 (Techno Titans)
Team Role: CAD
Rookie Year: 2012
1683cadder is on a distinguished road
Re: designing a three motor gearbox
Originally Posted by EricH View Post
Anyways, if two motors are different, matching their speed will work for a quick solution. But to optimize, you probably want to match their available power at a given RPM, which will require slightly different gear ratios than just matching speeds.
How do you do that?
  #17   Spotlight this post!
Unread 04-05-2013, 16:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Rookie Year: 1999
Originally Posted by 1683cadder View Post
How do you do that?
The speed/current/power vs. torque curves are shaped similarly for DC permanent magnet brush motors (i.e. all current FRC motors). Motors differ in the magnitudes of these quantities. You plot those curves (either experimentally or theoretically), and then decide what ranges you'd like your mechanism to operate in. Then you scale the curves using gear ratios (to multiply the torque by some factor). Look at the JVN DesignCalc spreadsheet (here, here and here) and Andrew Kesic's motor curve spreadsheet (here and here) for examples.1
If you want the motors to share the load proportionally to their maximum output power, then you want to gear them so that the speed vs. torque curves of all motors are superimposed (or that at least they're as close as possible within the relevant range). If you want motors to share unequally at different loads,2 then you can orient those motor curves arbitrarily.
1 I have some incremental updates to these I've been meaning to complete and post. (Mostly updated motor lists for 2012, and minor formatting/functionality improvements.) One of these days....
2 That's a pretty rare requirement. Maybe one motor is a can motor with a fan that has a minimum effective speed, and you are willing to load it more at high speed, in order reduce its load when high torque is demanded (at low speed when cooling is ineffective).
  #18   Spotlight this post!
Unread 04-05-2013, 17:24
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
Team Role: Mechanical
Rookie Year: 2011
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
My apologies. I forgot for a moment that the MiniCIM and CIM were different RPMS. However, going from all MiniCIM to all CIM wouldn't be a problem. You should definitely use a slight reduction on the MiniCIM, though I am not positive on the exact ratio required.
Junior at the University of Notre Dame, Mechanical Engineering
Got questions (about Notre Dame, robots, college, etc), don't hesitate to ask.
**Bang Boom Pop!** "Was that the robot?" "I don't know, do it again"
**BANG BOOM POP** "Oh, now it's on fire."
  #19   Spotlight this post!
Unread 04-05-2013, 17:37
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
1.1676082862523540489642184557439:1 or 620:531 or 62:53* or 6:5*
*Approximate
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
  #20   Spotlight this post!
Unread 04-05-2013, 17:53
Team Role: CAD
Rookie Year: 2012
How close do the gear ratios need to be?
  #21   Spotlight this post!
Unread 04-05-2013, 19:06
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
They don't. Slower motors will act as loads on faster motors. If you're incorporating CIMs and MiniCIMs in the same gearbox, you can use 12-tooth pinions on the CIMs and 11-tooth pinions on the MiniCIMs (or 14t and 12t respectively), which will get you close enough. In all honesty, you can probably use the same pinions on the motors, and they'll balance each other out without too much stress.
  #22   Spotlight this post!
Unread 04-05-2013, 21:22
EricH's Avatar
EricH EricH is online now
New year, new team
FRC #1197 (Torbots)
This question doesn't make sense in the context of the current discussion. I believe the question you're asking is, "How close do the RPMs need to be?" unless you're looking into what the different stages of the gearbox will be.
The answer is, they WILL be the same, eventually, due to the single gear they both go to--it can't travel at two different speeds at the same time. However, having the speeds wildly different is going to really annoy one motor or the other or both. Given that you're talking about 5K RPM and 6K RPM motors, I'd shoot for within 100-200 RPM difference; that should be close enough to work with and within the rated speed tolerance.
Just in case you were asking about the different gear ratios in the gearbox, though, the answer is "it depends". Depends on design, depends on designed speed(s). Each reduction stage, as a rule of thumb, should be less than a 10:1 reduction by itself (total reduction of the gearbox can be a LOT more).
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
