Go to Post Common sense goes a long way. - Akash Rastogi [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 12-05-2013, 01:14
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
Re: 233 telescoping arms how do they work?
Originally Posted by Triple B View Post
I can only speak for the 233 arm on this topic. First off, a gearbox is attatched to the outside of the largest box (4d0 x 4d0 x d125 al box) at the bottom of the tower. It has a shaft that transfers power to a sprocket on the inside of the box. At the top of the box is an idler sprocket which is also the tensioner for this chain. We will call this chain 1. Chain 1 is attatched to the outside of the next box (2d5 x 2d5 x d125 al box) thru what I call the "chain anchor". The motor/gearbox drives this stage in and out directly.
The gearbox has a 10 turn pot attatched which controls the limits and also the PID control for ramping up and down the power as the tower nears its limits at each end of its travel. Now here is where it gets a little tricky, the opposite side if the 2d5 box has a shaft in the bottom with a sporcket on the inside and the outside, this is what drives the final stage of the tower. It also has an idler at the top which also acts as the tensioner for these 2 chains.
The chains both have a "chain anchor". The chain on the inside of 2d5 box is attached to the bottom of the final stage (1d0 x 1d0 x d125 al box). The chain on the outside of the box is attatched to the inside of the 4do box. The key is that the anchors are on opposite sides of the chain, this allows the second stage to use the anchor to drive the chain which extends the final stage at the same time. This is a very lengthy post and I may not of explained the subject completely but it has started an open line of communication. Ask any questions you may have and i can explain why Charlie did not like the delrin bearing blocks from 2k10.
Mike D "233 for life"
After some analysis, this is my understanding of what Mike describes.
EDIT: would someone familiar with the 254 system we willing to describe or diagram that system? From looking at all the pictures, I believe they use a different concept.
Unread 10-05-2013, 11:08
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Originally Posted by smart1 View Post
i have seen pictures but i still can't figure how they work. I want to know how to make one this summer. any pics or cad would be great.
Take a look at how 1986 did their arm. They used heavy duty drawer slides and a cascaded cable and pulley system. It was simple, elegant, easy to manufacture and did the job.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 10-05-2013, 13:24
smart1's Avatar
smart1 smart1 is offline
AKA: Kyle
FRC #0967 (Iron Lions)
Rookie Year: 2007
smart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud ofsmart1 has much to be proud of
we have done many lift's with bosch 20 series with custom sliders and cable but that has it's limitations, mainly strength and weight.
Unread 11-05-2013, 20:13
craigboez's Avatar
Mechanical Engineer
In our application we use the constant force springs to assist the extend function only.
Would you mind elaborating on which constant force springs you use?
EDIT: I ask because I'm only familiar with the coil style constant force springs and if you used those I'm curious how they were implemented.
Unread 11-05-2013, 22:17
Chinmay's Avatar
Chinmay Chinmay is offline
incurable FIRSTaholic
FRC #0846 (Funky Monkeys)
Chinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant futureChinmay has a brilliant future
Try looking up negator spring or constant force spring motor. It's a really nicely packed solution to the counterbalance problem. Ill update this when I'm at a computer with some links Ect.
Member 846 Funky Monkeys 2007-2011
Mentor 558 Robosquad 2012
Mentor 846 Funky Monkeys 2011-Present
http://www.becauserobots.org
Man is a robot with Defects
Unread 12-05-2013, 06:48
R1ffSurf3r R1ffSurf3r is offline
AKA: Charlie
FRC #0233 (The Pink Team)
Team Role: Driver
R1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to beholdR1ffSurf3r is a splendid one to behold
look at post 18, and the second picture
Unread 13-05-2013, 21:19
smart1's Avatar
AKA: Kyle
Rookie Year: 2007
Thanks for all of the helpful insight.
Who is this guy named We I keep hearing about, everybody says We will do that later but I haven't ever met him.
Unread 17-05-2013, 15:53
craigboez's Avatar
Mechanical Engineer
After looking through the pictures referenced earlier in the thread, I was able to better understand the 254 telescopic arm. It is conceptually very different from the 233 arm.
  • 254 used a single piece of belt routed continuously through the assembly and then pinned to the final stage at each end of the belt. See attached for a diagram.
  • 233 used two loops of chain, one to drive the first stage and then in a cascading fashion used the first stage to drive the second stage. See my previous post 39 for a diagram.
Both elegant solutions to a similar problem, and as you can see from the pics, the hardest part of building one of these is in the packaging.
We attempted to build a nylon strap driven arm, similar in concept to the 254 design, and found it very difficult to get all the rollers, idler pulleys, and pieces of slippery UHMW from colliding with each other. In the end we ran out of time, kept the first stage, and just implemented a first level hanger.
The devil is definitely in the details with these mechanisms.
Unread 17-05-2013, 16:18
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Rookie Year: 1998
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
This is correct. Thanks for illustrating this for others.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 17-05-2013, 21:58
smart1's Avatar
AKA: Kyle
Rookie Year: 2007
Thanks again.
Unread 21-10-2013, 11:37
fr05ty27355's Avatar
fr05ty27355 fr05ty27355 is offline
FRC Scorekeeper
AKA: Paul
FRC #2169 (KING TeC)
fr05ty27355 is on a distinguished road
What did 254 and 233 do to pin the chain/belt to a stage? I'm wondering if they put bolts through the chain/belt, pinched the chain/belt against a toothed surface, or did something else. I'm guessing they might have had different methods since 254 used a belt and 233 used chain.
FTC: 3855 Tempered Steel
2010 - Minnesota Snow Drift - FTC Winning Alliance
2010 - World Championship - FTC Finalist Alliance
FRC: 2169 KING TeC
2013 - MSHSL State Championship - Finalist Alliance
2013 - Galileo Division - Finalist Alliance
2013 - Colorado - Winning Alliance
2013 - Northern Lights - Winning Alliance
2012 - MSHSL State Championship - Winning Alliance
2012 - Wisconsin - Finalist Alliance
2012 - Lake Superior - Regional Chairman's Award
2012 - Lake Superior - Winning Alliance
2011 - 10,000 Lakes - Finalist Alliance
2011 - Lake Superior - Regional Chairman's Award
2011 - Lake Superior - Finalist Alliance
2010 - 10,000 Lakes - Regional Chairman's Award
Unread 21-10-2013, 13:50
George C's Avatar
George C George C is offline
AKA: George Chisholm
FRC #1360 (Orbit Robotics)
George C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to beholdGeorge C is a splendid one to behold
We did something similar for a two-stage cascading mechanism driven by a Gates belt. We were able to saw and file a piece of aluminum to match the Gates tooth profile. The block covered about 6 teeth and we avoided putting holes through the belt. Worked perfectly on the second try.
Unread 21-10-2013, 14:26
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
971 did a similar attachment method with a machined block to match the belt tooth profile for their elevator in 2011.
For #25 chain, you can fit #4 screws through the gaps between the rollers to fix it to something, although I don't know if this is how 233 does it or not. Another method is to drill a hole in the fixed structure that one end of a masterlink fits through.
Unread 21-10-2013, 14:32
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
I've also used #4 Screws to fix #25 chain before, it works just fine when done right but can be a bit tricky considering the size of both the chain and the screws.
233, in 2011 at least, machines a part that appears to 'look' like a #25 chain link at either end and uses that to fix the chain to the stages. Here's a few pictures on their flickr.
http://www.flickr.com/photos/thepinkteam/5787028180/
http://www.flickr.com/photos/thepinkteam/5787033770/
http://www.flickr.com/photos/thepink...n/photostream/
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
  #15   Spotlight this post!
Unread 21-10-2013, 15:03
BurkeHalderman's Avatar
BurkeHalderman BurkeHalderman is offline
Casual Robot Observer
Rookie Year: 2010
BurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant futureBurkeHalderman has a brilliant future
Has anyone tried using these to attach chain? Specifically the K-1 style connector.
http://www.mcmaster.com/#roller-chai...hments/=p1acmb
Seems like an easier option than machining an attachment for the chain.
[2010-2014]: FRC 3266 Robots-R-Us: Founder and Alumni
2010 (5-5-1): Buckeye Regional; Driver
2011 (4-5-0): Buckeye Regional; CORI; CAGE Match; Drivetrain/Manipulator Operator
2012 (7-13-0): Buckeye Regional; Queen City Regional; CAGE Match; BPRC; Drivetrain Operator
2013 (25-15-1): Queen City Regional; Buckeye Regional; Crossroads Regional; CORI; Ohio State Champs; CAGE Match; BPRC; Drivetrain Operator
2014 (21-10-0): Crossroads Regional; Queen City Regional; Designer; Mechanical/Design Mentor
Founding an FRC team as an 8th grader sure wasn't easy, but it was totally worth it.
Get in touch with me:
Personal Facebook
I believe every human has a finite number of heartbeats. I don’t intend to waste any of mine. – Neil Armstrong
