Go to Post Blame it on the programmer. - colt527 [more]
Unread 09-05-2013, 22:10
feli feli is offline
feli is an unknown quantity at this point
Exclamation [Urgent] How to key in symbol and put picture on Labview Front panel & Block Diagram?
I doing a project using labview
Now I'm facing two problems
1) how to key in Symbol in labview at both front panel & Block Diagram. Ex: θi and θr
2) how to put in picture ( ex : the picture is an answer of my question, I need to show the picture, when they press the "end" button)
Thanks
Unread 10-05-2013, 07:59
Re: [Urgent] How to key in symbol and put picture on Labview Front panel & Block Diag
The symbol entry depends on the OS. You can swap fonts to use the Symbol font or you can use the OS method of creating unicode characters.
To show a static picture, or a limited set of pictures, there is a control called the Picture Ring. Import the pictures into the named/numbered set, and set the value to whatever you like.
For more extensive picture control, you can look at using the 2D or even the 3D picture control. These get more complex as they are actually more like canvas controls with complete drawing APIs on the diagram.
Greg McKaskle
