6 Wheel Drives Without Dropped Centers
I've been looking at different drive systems lately and I have tried to come up with something that our team could try. I have heard of teams using 6 wheel drives without a dropped center so that it is truly a 6 wheel drive and not just a 4 wheel drive with some extra stability.
I have heard that 25 has used this concept before and looking at some threads from the early 2000's I found some information on it but I still don't quite understand how it would work. Can anyone enlighten me as to how this would work? Everything that I can think of says that a 6 wheel drive robot without a dropped center shouldn't turn without a special 7th wheel mechanism or omniwheels or something of the sort. |
Re: 6 Wheel Drives Without Dropped Centers
Hey Cam!
Someone from 25 will probably have to pop in to clear up the details, but here is what I know. 25 does use a 6WD with no drop. In the past, they have even gone up to 8WD, still with no drop. They use what has been termed as "Brute Force" turning; no tricks, no mechanism. It's all drive train for them. From what I recall, the secret lies in the wheels. Those massive drum wheels 25 has used in their drive system for years are from Skyway. 25 sands down the wheels so they are slick, and then cuts into them and adds tread as necessary. Here's a little more info on it: 25's Tires. While the thread is over 10 years old now, I seem to recall a thread in more recent years where the process is verified to still be alive. Like I said, an actual member of 25 is going to need to provide the details, but that's the just of it. EDIT: Here is a more straight-forward description of the design from a member of 25 - Link When it comes to drive systems with speed and power, you'd be hard-pressed these days to find a team who surpasses 25 in both respects. Regards, Leeland Last edited by LeelandS : 12-05-2013 at 20:11. |
Yes, thank you Leeland, you have come through for me again! This is exactly what I was wondering about. I hope someone from 25 could come in and provide a little bit more detail about this. Just wait till FLR next year when we have a 6 cim, 2 speed, 6 wheel no drop drive train ![]() |
Here's a thread from 2010 that generated some good discussion about dropping the center wheel: http://www.chiefdelphi.com/forums/sh...ad.php?t=85763. In particular, this post by Jared from 341 does a good job explaining some of the specifics of our drivetrain. If you have any more questions, feel free to ask (or come on down to Brunswick Eruption in November to check it out in person ). |
As a fun side note, we blew one of our drive speed controllers at Battle O' Baltimore that year (and didn't have a replacement with us to swap it out) and were still able to drive around pretty well. |
The turning ability of a robot with no drop-center and all traction wheels is dependent on the normal force experienced at each wheel. That is to say, it depends on how much force each of the wheels on the robot supports.
As Jared mentioned in his post that was linked to, a 6 wheel drive with no drop center is statically indeterminant. This is because if you isolate the physics on one side of the drive train (assuming a perfectly symmetrical robot), you have the force for 3 wheels as variables but only the sum of moments about the wheels' axes and the sum of forces in the vertical axis as equations. That's 3 variables and 2 independent equations, so this mathematical model cannot solve for how much weight each of the wheels supports. This makes it complicated to approach from a design perspective, which is why the over simplification of "a long wheel base robot without drop center wheels will not turn" is often made. In reality, as you approach the limit where all of the weight is supported by the 4 corner wheels, the robot will behave like a 4WD long robot and have difficulty turning. As more and more of the weight is supported by the center wheels, this reduces the normal force at the corners, thereby reducing the tractive force applied at the corners and reducing the robot's resistance to turning. More weight at the corners = Harder turning. Less weight at the corners = Easier turning. When the center wheel is dropped on a robot, much of the robot's weight is supported by the center wheel at all times in addition to shortening the wheel base, which makes turning easier (another generalization, but a widely accurate one so this is part of why drop centers are so popular). Team 25 REALLY knows what they are doing, which is why they can pull this off. My guess would be that criteria that lead them to this type of design decision are: -Makes it harder for defense to turn them -Eliminates rocking, so stability isn't an issue I personally cannot perform the math necessary to prove that a drive train without a drop-center would turn. I also have not done the necessary testing and experimentation to have the experience needed to design such a drive train that I will guarantee can turn well. Therefore, I would hesitate to build this type of drive train. This is where it's important for teams to build within their means and recognize them. |
Does anyone know if versa wheels would work for this sort of drive train? They have really good traction going forward and backwards but not the best laterally because of the W tread on them. I think that this sort of wheel would almost be perfect for this scenario.
It might be worth trying with colsons though... |
#10
What T^2 said is true given your robot remains completely flat on the floor, parallel with the carpet, and doesn't weigh too much. In the event you're not parallel (ie. being pushed from the side and slightly tipped upwards on the pushing end), the W tread will grip to the carpet like cleats. It won't need to be a significant lift, but anything to change the robot from parallel with the floor will engage cleat mode.
Source: Experience with cleat mode this year. |
#13
Quite interesting, Miss Daisy used the VersaWheels this year, and I witnessed them getting pushed sideways. However, I'm not certain if they dropped the center wheel or not (6wd, 6cim), It would be interesting to hear about their drivetrain.
#14
48 has been running no drop center, 6WD West Coast setups since 2011.
2011: two 4" omnis up front, four 4" performance wheels in rear, roughtop tread. Long wheelbase. 2012: six 8" AM pneumatics, square footprint 2013: six 6" dia. 1" wide aluminum performance wheels, blue nitrile roughtop tread. Very slightly wide-biased footprint. All three were powered by some variation of the A-M SuperShifter, 2 CIM's per side. 2012 was not surprisingly the least-maneuverable of the three setups, but it still was good enough to get the job done in one of our most productive seasons ever. The 2013 iteration is very nimble yet able to provide enough punch to apply solid defensive pressure when needed. |
#15
It turned like butter (if anything, a little more scrub would have been nice), and it was possible for a high traction robot to push us sideways a little bit. But with fresh-ish wheels our traction in the forward/backward direction was incredible (we inadvertently tore a couple holes in the carpet at the Las Vegas Regional during pushing contests). |
