Go to Post Honestly, I'd volunteer my team to be on that alliance. It'd be an honor to touch bumpers with those bots. - ttldomination [more]
Thread Tools Rating: Thread Rating: 9 votes, 5.00 average. Display Modes
Unread 20-05-2013, 22:03
the.miler's Avatar
the.miler the.miler is offline
taking a break
AKA: Miles Chan
FRC #0846 (Funky Monkeys)
Rookie Year: 2011
the.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of lightthe.miler is a glorious beacon of light
Re: Competitive Intakes
Got a shoutout from 3173, had to respond! I designed our floor collector this year, and it seems to be the system that people remember when they see our robot. There are features that I would never replicate on that collector if I could do it over . . . there are also great features, and I've tried to detail them below.
Mooretep had an awesome video (0:30 has a really nice shot): http://www.youtube.com/watch?v=GqfuRlymtSQ
Official Reveal (showcases initial testing): http://www.youtube.com/watch?v=jmdET56tukM
Official Recap: http://www.youtube.com/watch?v=w79l4VhjrD0
Ironically, the floor collector wasn't really our top priority (we didn't have priorities due to the fact that we tried to do everything; don't do that!), so features such as being able to funnel really well and take two discs at the same time didn't make it into the final design. If we had properly valued the collector, we would have thought differently and implemented those features.
Cool Attributes:
At the mouth of the collector, there are actually two rollers, one on the bottom and one on the top. We arrived at the same conclusion as 33, that the bottom roller for kicking the disc up was crucial. The coolest part was really that we did not drive it using anything nearly as complicated as a gearbox; it was just a twisted belt run from the top roller. I can get a picture later, but it was something like this: http://www.chiefdelphi.com/forums/sh...ht=2826+teaser
That bottom roller kicked the disc into contact with the upper roller, and that powered the frisbee through the rest of the system (geared at 18 ft/sec roller surface speed) and out into our storage subsystem.
To prevent our collector from getting caught on the carpet and irregular surfaces we installed wheels for the collector to ride on. This was another pretty cool feature, we machined two delrin rounds with holes for bearings, turned down the ends of two 3/8" bolts to 1/4" diameter and the bearings rode on that makeshift shaft.
What I would have liked to do:
Here's a really easy way to make your collector take two frisbees side by side. Make your collector funnel to the side, kind of like 233's or 973's collectors. One straight edge, one slanted edge. Our prototypes indicated that this worked really really well, and we only didn't implement it because our robot design forced that compromise.
Alternatively, do something like 971's collector (I would note that both their 2012 and 2013 robots are absolutely phenomenal in handling game pieces throughout their system) . . . http://www.youtube.com/watch?v=6bsWRIMV9CY It would be really cool if they posted on this thread
Hope this helps! Collectors this year were really challenging, and it's really interesting to see how other teams approached that problem. Keep the responses going, I'm having a blast reading this thread
Member 846 The Funky Monkeys 2010-2014
Team 846 Highlights 2014
lynbrookrobotics.com
becauserobots.org
Unread 21-05-2013, 02:13
themccannman's Avatar
themccannman themccannman is offline
registered lurker
AKA: Jake McCann
FRC #3501
Rookie Year: 2011
themccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond reputethemccannman has a reputation beyond repute
We had a very long, arduous journey over the course of the season to prototype and perfect our intake. Our original intake design was like many others with a single double wide roller in the front and a "scooper" plate underneath. Here's two pictures of our original intake design, the pool noodle on the front was just a bumper to protect the roller underneath. The entire roller was on a hinged arm that allowed the roller to actuate vertically
In this picture the black rollers were made of a low durometer urethane called sorbothane, it was by far the most frisbee-adhesive material we could find. If you just laid the sheet of sorbothane on a frisbee you could pull the frisbee across the carpet with only the weight of the sorbothane holding itself down.
This intake design was fairly successful, it picked up almost every frisbee we touched, however like other teams we occasionally had some jamming problems when feeding 2 discs next to each other and the scooper plate getting stuck on the carpet lip around the pyramid. The other problem was that it would push the frisbees a short distance before picking them up which was a problem in autonomous. We went back to the drawing board using 254's intake as inspiration. Our final intake design worked better than we ever could have dreamed.
Our final design used a thin front roller with a polyurethane sheet wrapped around it that had similar traction properties to the sorbothane. The entire intake was wide enough to pull in two frisbees next to each other. Only having the traction on the center of the front roller allowed us to pull in one frisbee at a time without them fighting each other while being pulled in.
Behind the front roller we had a counter rotating roller with the same polyurethane traction material on it that lifted the edge of the frisbee and pulled it into our hopper. We also had another roller directly above it with a large brush on it, rolling in the same direction as the front roller, to assist the frisbees getting pulled in after the bottom roller had lifted the edge. This intake design worked flawlessly, it instantly picked up any frisbee touching the front roller, never had jamming issues, and had an additional, accidentally built in feature, if you picked up an upside down frisbee then lifted the intake it would flip the frisbee out right side up to be picked up again
Our final intake also had no bottom scooper plate and the entire intake rolled on two steel track balls which kept the front roller at a consistent height and allowed easy transitions over the carpet lip. Our intake also took a much heavier beating than it should have including a full speed hit against the pyramid and several pushing matches with other robots. We did end up bending the side plates that make up most of the intake however we reinforced them with a set of back-up plates that we had brought along in case that happened.
I'm sure most of you saw this live but here's a match with our intake after it had been "Frankensteined" back together.
http://www.youtube.com/watch?v=U_blP_tD8Yk
Thanks to 973 for the great quality video of the einstein matches.
All posts here are purely my own opinion.
2011-2015: 1678
2016: 846
2017 - current: 3501
Unread 16-05-2013, 19:31
BJC's Avatar
BJC BJC is online now
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Originally Posted by MICHAELABICK View Post
I think building a competitive roller intake was one of the hardest challenges this year. Our team for example trashed our intake design midseason, after spending many, many hours prototyping. However many teams still built fast intakes, despite our team's troubles. What were the challenges that your team faced in building an intake? What designs overcame these issues? What designs led to the fastest, most consistent roller intakes?
33’s primary design objectives for our intake were:
1. Had to be two disks wide for the 7 disk auto.
2. Had to be extremely fast (469 in 2012 was our benchmark)
3. Had to be able to properly function over wrinkles/tape on the carpet.
We had a very successful prototype using an overhead roller and spatula. However, this didn’t meet our 3rd functional objective.
Recognizing that the key to intaking was getting the leading edge of the disk off the floor we began prototyping a counter rotating bottom roller. This resulted in a second very successful prototype using a 3/8” fiberglass rod sleeved with surgical tubing. However, the very tight dimensional restrictions (54” cylinder) meant that this design was almost impossible to package.
Because of packaging constraints we began prototyping large diameter bottom rollers. These evolved to have “fingers” and we ended up with AndyMark stars cut down slightly.
The final intake pretty much met all of our objectives. We consistently averaged 6 disks in auto throughout the season, and the collector functioned properly up to about 1/2” off the ground and wasn’t affected by tape or carpet wrinkles. It didn’t quite meet the 469 in 2012 requirement but it was still good enough that we never had to wait around for disks to enter the robot.
Photo by Dan Ernst
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 20-05-2013, 20:44
Jay O'Donnell's Avatar
Jay O'Donnell Jay O'Donnell is online now
Division by Pirates
FRC #0229 (Division by Zero)
Rookie Year: 2012
Jay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond reputeJay O'Donnell has a reputation beyond repute
I find it funny that your third design objective ended up being our biggest problem. I think we broke our intake almost ten times just on tape. It was something we completely overlooked and didn't think of as a problem.
Student on Team 1058 (2012-2015)
Mentor on Team 229 (2016-Present)
Writer for Blue Alliance Blog
