| Thread Tools |
Rating:
Display Modes |
1114 and 2056's shooter wheels
I noticed that 1114 and 2056 used some blue shooter wheels that seemed to work really well. I just wanted to know if anybody else used them and had any idea what there were. I think they are a McMaster-Carr buy but there are so many products on that site that some things are a little hard to find if you are looking for something specific. If there is any one that can help it is much appreciated!
Re: 1114 and 2056's shooter wheels
I believe the part number you are looking for is 2477k36 on mcmaster.
So they made custom hubs for the wheels?
McMaster 2477K36 in 60A I believe. They have a 1.25" bore in the middle.
We machined a hub to interface with 1/2" keyed shaft. The hub was just a piece of 6061 round stock turned to press fit into the wheels bore. I took a look at 1114s hubs and they knurled them to make the press fit better. We didn't have the resources to do so but were fine through all of champs. ![]() |
They are in fact 2477K36. We used them both this year and last year with some success. They also seem to have gained reasonably popularity with a number of teams by Champs. I saw 254, 973, 1717, 1678, and probably some others all using them.
Don't spin them over 10,000rpm. Bad things happen. 5-6k rpm Quote:
As a couple of others have pointed out the McMaster part number for these wheels is 2477K36 and the description is: "Large-Bore Urethane Drive Roller, 60A Durometer, 4" Diameter, 0.92" W, 1-1/4" Bore ID". 2056 first used these wheels in 2012, so we decided to try them out this year. They were easy to work with and incredibly robust. They did require a custom hub, but it was a fairly simple part to machine. A drawing of the hub is attached.
Edit: 2056 posted the same info above. |
3138 used the same wheel this year and last year. They've worked out great for us.
Thanks for posting that information, Tyler and Karthik. I always assumed it was a custom molded wheel before.
#10
One more thing, how much compression was typically run with these wheels on the disks?
#11
We had to run probably 3 times as much compression with this wheel than we did with the blue banebots wheel it replaced. I don't know what that is in absolute terms, but it was a lot.
#12
It should be mentioned that we were running them at much higher speeds, since ours were turned down to 2-7/8" to match the BB wheels they replaced.
#13
We ran ours with about 1/4" to 1/2" of compression. At speed, they noticeably increase in diameter as the urethane stretches (which is why you shouldn't run them at extremely high speeds -- we blew two of them open at the Sacramento Regional). However, in practice the frisbee buckled upward much more than the urethane compressed.
#14
What rpm would you say is the breaking point of the wheels? |
#15
Can't speak for 254, but ours, at 60A durometer, never wore and never had to be replaced (unless they exploded).
