Re: OPR-computation-related linear algebra problem
Just installed Octave3.6.4_gcc4.6.2_20130408 on this computer. Results: GNU Octave, version 3.6.4 Anybody know why Octave takes so long to load N ? Load N times, all on the same computer: Delphi....0.6 seconds Last edited by Ether : 30-05-2013 at 21:28. |
LV times were on this computer
Win 7 Professional 64-bit Xeon CPU E5-1620 3.6GHz 16G RAM Greg McKaskle |
Is anybody else running Octave on a machine with 32-bit-XP Pro? Are you having the same 30 second delay for Octave to load, and 90 seconds to load the 12MB N.dat file? |
I can check after work in the lab this evening if no one gets to it first, Ether!
Code:
Welcome to RLaB. New users type `help INTRO'
RLaB version 2.1.05 Copyright (C) 1992-97 Ian Searle
RLaB comes with ABSOLUTELY NO WARRANTY; for details type `help warranty'
This is free software, and you are welcome to redistribute it under
certain conditions; type `help conditions' for details
> tic();
> d=readm("d.dat");
> toc()
21.9
> tic();
> N=readm("N.dat");
> toc()
28.8
> tic();
> x = solve(N,d,"S");
> toc()
34.8
Xeon 2.93 Ghz cluster. But this code may not be doing any multithreading. |
CD let me attach again. I attached the things I intended for the previous post.
As with many of the analysis functions, this calls into a DLL, to the function InvMatrixLUDri_head. So it seems to be using LU decomposition. I think the matrix qualifies as sparse, so that helps with performance. The direct solver was almost ten seconds. Greg McKaskle Last edited by Greg McKaskle : 26-05-2013 at 06:34. Reason: Another piece |
The reason I say it's computationally intensive is this article: http://www.johndcook.com/blog/2010/0...t-that-matrix/
Even normal Gaussian elimination will be pretty fast on a sparse matrix (though still slower than most methods above), but it has problems with numerical stability that get worse and worse as matrix size increases and is for that main reason avoided by most people solving numerical linear algebra problems. |
#10
Re-ran using Scipy's sparse matrix solver.
Average run time: 0.085s Standard deviation: 0.005s Code:
import sys
import numpy
import time
import scipy
import scipy.sparse
import scipy.sparse.linalg
import psutil
n_runs = 1000
print ""
print ""
print "Python version %s" % (sys.version)
print "Numpy version %s" % (numpy.__version__)
print "Scipy version %s" % (scipy.__version__)
print "Psutil version %s" % (psutil.__version__)
print ""
N = numpy.loadtxt(open('N.dat'))
d = numpy.loadtxt(open('d.dat'))
Ns = scipy.sparse.csr_matrix(N)
data = []
for i in range(1,n_runs+1):
start = time.time()
x = scipy.sparse.linalg.spsolve(Ns,d)
end = time.time()
row = [end - start]
row.extend(psutil.cpu_percent(interval=1,percpu=True))
s = "\t".join([str(item) for item in row])
data.append(s)
f = open('times2.dat','w')
f.write("\n".join(data))
f.close()
_x = scipy.sparse.linalg.spsolve(Ns,d)
print ", ".join([str(f) for f in _x])
print ""
#11
I did the computation on this computer using a slightly modified version of DMetalKong's Python code. Python 2.7.5 SciPy 0.12.0 NumPy 1.7.1 Code:
>>> import numpy
>>> import time
>>> import scipy
>>> import scipy.sparse
>>> # Read N & d ...
... start = time.time()
>>> N = numpy.loadtxt(open('E:\z\N.dat'))
>>> d = numpy.loadtxt(open('E:\z\d.dat'))
>>> end = time.time()
>>> print "%f seconds" % (end-start)
6.532000 seconds
>>> # solve...
>>> x = numpy.linalg.solve(N,d)
>>> end = time.time()
15.281000 seconds
>>> # Convert to sparse...
>>> end = time.time()
0.234000 seconds
>>> # solve sparse...
>>> xs = scipy.sparse.linalg.spsolve(Ns,d)
>>> end = time.time()
0.453000 seconds
Perhaps there's an MKL for Python I need to install? |
#12
Sorry I'm a bit late to the party.
I'm running Octave 3.2.4, so an older version than flameout Hardware is Dell E6420 laptop (CPU i7-2640M @ 2.8GHz) Win 7 64bit Code:
octave:2> N = load('N.dat');
octave:3> d = load('d.dat');
octave:4> tic; Ns = sparse(N); toc
Elapsed time is 0.136 seconds.
octave:5> tic; r = Ns \ d; toc
Elapsed time is 0.096 seconds.
octave:6> tic; r = N \ d; toc
Elapsed time is 0.921 seconds.
#13
BTW, in case anyone was wondering...
Ax~b (overdetermined system) ATAx = ATb (normal equations; least squares solution of Ax~b) Let N=ATA and d=ATb (N is symmetric positive definite) then Nx=d A is the binary design matrix of alliances and b is the vector of alliance scores for all the qual matches for the 2013 season, including 75 Regionals and Districts, plus MAR and MSC, plus Archi, Curie, Galileo, and Newton. So solving Nx=d for x is solving for 2013 World OPR. Last edited by Ether : 27-05-2013 at 00:01. |
#14
RLaB is not a contender for fastest speed, but it's definitely the tiniest linear algebra app out there. It weighs in at under 1.5MB. Makes a wonderful pop-up for that quick calculation, or for high-school students just learning linear algebra. Very easy to use... and free. Welcome to RLaB. New users type `help INTRO'The second solution method (x=solve(N,d,"S")) tells RLaB that the matrix is symmetric, so it uses LAPACK subroutine DSYTRF (Bunch-Kaufman diagonal pivoting) to solve, which cuts the time in half. Last edited by Ether : 30-05-2013 at 21:35. |
