Go to Post Maybe we'll see some awesome Game change like.... CARPET! - thefro526 [more]
View Poll Results: What drivetrain did your team use this year
4 wheel tank 51 17.29%
6 wheel tank 158 53.56%
8 wheel tank 24 8.14%
10+ wheel tank 0 0%
Swerve Drive 4 1.36%
Omni Drive 6 2.03%
Mecanum Drive 35 11.86%
Tank Treads 0 0%
Articulating Drive train (butterfly, nonadrive, octocanum) 10 3.39%
Other 7 2.37%
Voters: 295. You may not vote on this poll
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 28-05-2013, 19:06
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: What Drivetrain?
Actually... Switching drivetrains is something you could get away with, IF you've planned correctly. For example, if you've got the extra hole(s) drilled already, it'd be relatively simple to go from 8WD to 6WD, or vice versa, or 4WD to 6WD, or 4WD to mecanum (with a pair of transmissions added). Planning correctly means that you built the robot to be able to switch--though it does not necessarily mean modularity.
330 did that back in 2005--the competition robot had an extra set of transmission slots so we could swap to mecanum from 6WD if we thought it was a good idea. The testbed--a Kitbot--ran mecanum. We didn't have the weight that year to switch. To this day, 330 has yet to run mecanum on a competition robot.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 28-05-2013, 20:24
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
The one year we did mecanum (logomotion) we machined our frame with holes to easily be able to add dropped center wheels if the mecanum didn't work. We were happy with it's performance because the ease of strafing to hang tubes and that games rules limiting defense.
This year we made major drivetrain changes at our second regional and we were inspected and driving by 2:00 on Thursday. It can be done if you plan properly and practice the change, a second robot is invaluable for this.
Unread 28-05-2013, 19:10
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Originally Posted by Teamcodeorange View Post
3. Our drive base is very simple and easy to fix, just a piece of extrusion, bearing blocks, chain, and wheels. (Don't trust hex bearings.)
When you say extrusion, did you use something other than the normal 2X1 tubing?
Also whats up hex bearings?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 28-05-2013, 21:48
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
Team Role: Leadership
ablatner is on a distinguished road
Not sure if this is what he was getting at, but I'll give it a shot. There have been a couple of issues with hex bearings this year. One of the main ones was simply supply. For a long period of time this season, hex bearings were completely sold out wherever you looked. There were also problems with the hex itself, which was often oversized or undersized.
1/2" hex bearings are sold out at VexPro and West Coast Products (although their store is down for maintenance). They used to be sold out at AndyMark, although it looks like they're back in stock with an order limit of 10.
2009-2013: Student, Team 100
2013-????: ?
Unread 29-05-2013, 00:50
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Yes, we use 1/8" 1 x 2 aluminum extrusion.
The hex bearings are a problem because they shouldn't exist, at least not for 4 dollars. It seems that the vex pro ones are just normal bearings broached to fit a 1/2" hex shaft. The problem with this is that the added force on the corners of the shaft crack the inner race and render the bearing useless. This happened to use every couple hours of driving in practice, and a 2 times in competition. If you use hex parts, do it with round bearings if at all possible. (you can machine down a 1/2" hex shape on 5/8th shaft)
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 27-05-2013, 12:49
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
Originally Posted by MICHAELABICK View Post
About them being the best, what do you qualify as WCD.
The "standard" definition of a WCD is a 6WD drop-center, cantilevered wheels, live-axle, center directly driven off of the gearbox (usually a 2-speed gearbox), outside wheels chain-driven off the center axle.
I don't necessarily agree that WCD is the best of the tank drives, partly because it does take some precision to make and thus might be rather difficult for some teams, but it is up there if a team can build it properly.
Past teams:
Unread 27-05-2013, 16:56
cadandcookies's Avatar
cadandcookies cadandcookies is offline
Director of Programs, GOFIRST
AKA: Nick Aarestad
FTC #9205 (The Iron Maidens)
cadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond reputecadandcookies has a reputation beyond repute
What if your team switched drive trains through the season...
No, it didn't end well.
Unread 28-05-2013, 08:25
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Last year, our team changed drivetrains at Championships. Try to avoid that.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 31-05-2013, 22:38
Niezrecki's Avatar
Niezrecki Niezrecki is offline
AKA: Justin Niezrecki
FRC #1124 (ÜberBots) + FRC #5686 (Wirecats)
Rookie Year: 2012
Niezrecki has a spectacular aura aboutNiezrecki has a spectacular aura aboutNiezrecki has a spectacular aura about
We use Six wheel drop center.
Unread 01-06-2013, 12:44
Joseph Smith's Avatar
Joseph Smith Joseph Smith is online now
Persistence alone is omnipotent.
FRC #3539 (Byting Bulldogs)
Rookie Year: 2011
Joseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant futureJoseph Smith has a brilliant future
3539 used a 6w WCD this year. The past two years, we used 8 wheel standard tank drive, but this year we tried WCD to open up the inside of our frame for our ground intake and we were EXTREMELY happy with the results. Our drivetrain was easy to build, easy to maintain, rugged, light, and extremely nimble. We had a 1/8" drop on the center wheel, direct driven from our gearboxes. Custom 6" aluminum wheels with roughtop tread. We were geared for about 13 fps, so we were able to drive around most other robots on the field. We were very satisfied with the WCD style and will likely be visiting it in the future.
Here's a little video of our robot driving around at Troy. It was fun to watch this thing go
http://www.youtube.com/watch?v=gnDLFystS1Y
Design/fab team 2011-2013
Design/fab mentor 2014--
There are three types of people in the world:
1. Those who make things happen
2. Those who watch things happen
3. Those who wonder what happened.
Unread 01-06-2013, 13:48
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
To the people selecting "other", could you explain? Thanks!
Unread 01-06-2013, 14:44
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
Our robot: http://www.chiefdelphi.com/forums/sh...=3397+Serenity
It runs two wheels in the front, a floating omni-wheel in the back. It does not really fit into any of the categories that were provided, I believe it is called a "kiwi" drive, which is not on the list.
If you want reason as to why we went with this design, all of the details are in the thread linked to earlier.
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 01-06-2013, 14:54
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
FRC #2175 (The Fighting Calculators)
Rookie Year: 2012
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
A kiwi drive has 3 omni wheels all driven offset at 120 degree angles from each other the only team i know of that did one this year was 1425 but im sure there are others i havent seen. you can kind of see the drive in this video http://www.youtube.com/watch?v=jWGYa...ature=youtu.be
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 01-06-2013, 22:46
UAH Class of 2019
Rookie Year: 2010
We called our a "stingray" drive, due to the shape of the frame. I was just told by someone that it was kiwi, thanks for clearing that up.
  #15   Spotlight this post!
Unread 02-06-2013, 08:38
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The inverse kinematics for Kiwi are very simple and are shown here on one page.
