Go to Post If you are "retiring" the old ball, make all the lights green, hang it 8 feet in the air, line up a bunch of 'bots and let 'em shoot poofs. RoboPinata! (warning kids - don't eat the "candy" that falls out!) - Taylor [more]
Unread 27-05-2013, 14:04
java4first java4first is offline
(Java) Programming Mentor
AKA: Stu
FRC #0501 (Power Knights)
Rookie Year: 2011
java4first is an unknown quantity at this point
Getting RoboRealm to Work w/ NetworkTables
Hi -
Java for robot programming.
2.50.24 for RoboRealm version (just updated this morning).
We have been using RoboRealm and the SocketCommunication module to get the variables down to the robot (so we had a server thread running on the bot). I wanted to move to NetworkTables ... in part to free up the port for something else.
However, when I added the NetworkTables module to RoboRealm according to the instructions (see the attached picture of the settings, which seem to be right based on what I read), I get exceptions thrown on the robot (pasted in at the end of this post). I took a quick look through the NetworkTables code, and nothing jumpted out at me.
It appears to be 'connecting', as it offers up all the rest of the variables we have in the table from the robot as something to read. And, when playing around with it, during a reboot and a power cycle, I get messages in RoboRealm about "Write Failure! Disconnected from server".
At this point I have no code in the robot trying to read them. But if I run the TableViewer application, the variables from RoboRealm never show up in it - which I am assuming they would if it were working.
I'm assuming it is something really simple ...
Thanks!
Stu
edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@1e entered connection state: GOT_CONNECTION_FROM_CLIENT
[frcrun] [cRIO] edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter@1e entered connection state: CONNECTED_TO_CLIENT
[frcrun] [cRIO] Uncaught exception in Thread.run():
[frcrun] [cRIO] on thread Server Connection Reader Thread
[frcrun] [cRIO] java.lang.IllegalStateException: Cannot set the Id of a table entry that already has a valid id
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.NetworkTableE ntry.setId(NetworkTableEntry.java:147)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.server.Server NetworkTableEntryStore.addEntry(ServerNetworkTable EntryStore.java:32)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.AbstractNetwo rkTableEntryStore.offerIncomingAssignment(Abstract NetworkTableEntryStore.java:146)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.server.Server ConnectionAdapter.offerIncomingAssignment(ServerCo nnectionAdapter.java:106)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.connection.Ne tworkTableConnection.read(NetworkTableConnection.j ava:147)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.connection.Co nnectionMonitorThread.run(ConnectionMonitorThread. java:30)
[frcrun] [cRIO] at edu.wpi.first.wpilibj.networktables2.thread.Defaul tThreadManager$PeriodicNTThread$1.run(DefaultThrea dManager.java:18)
[frcrun] [cRIO] at java.lang.Thread.run(231)
[frcrun] [cRIO] in virtual method #47 of com.sun.squawk.VMThread(bci=42)
[frcrun] [cRIO] in static method #3 of com.sun.squawk.VM(bci=6)
