Go to Post "automated chaos" nuff said. - Jferrante [more]
Unread 27-05-2013, 15:18
apples000's Avatar
apples000 apples000 is offline
Rookie Year: 2012
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
Java Swerve Drive Math Inconsistencies
Our team is working on putting a cRIO onto one of our old swerve bots from the past. We're writing the swerve software in Java and we came up with our own equation that gives us rotation and x/y control of the robot. However, when testing, we've found that it gave a different result than Ether's swerve spreadsheet. We figured that he was right, so we put his equations into the program and we still got the same incorrect results as we did the first time. The answer we get is close, but it is usually off by 20%. Right now we get three different answers when we run our code on the robot, on our computer, and in Ether's spreadsheet, but I can't find the difference. Does anybody know what causes these inconsistencies between platforms/applications, and how to stop them from happening?
Here is our java code for the robot, and attached is an application we made that gets very close, but wrong answers for the swerve calculation.
Code:
 * To change this template, choose Tools | Templates
 * and open the template in the editor.
import com.sun.squawk.util.MathUtils;
import edu.wpi.first.wpilibj.DoubleSolenoid;
import edu.wpi.first.wpilibj.Encoder;
import edu.wpi.first.wpilibj.PIDController;
import edu.wpi.first.wpilibj.PIDOutput;
import edu.wpi.first.wpilibj.PIDSource;
import edu.wpi.first.wpilibj.SpeedController;
import edu.wpi.first.wpilibj.Victor;
import edu.wpi.first.wpilibj.command.Subsystem;
public class Drive extends Subsystem {
    //declare the steering pods and shifter valve
    private Pod frontLeft, frontRight, rearLeft, rearRight;
    private DoubleSolenoid shift;
    public Drive() {
        //set up the steering pods with the correct sensors and controllers
        shift = new DoubleSolenoid(RobotMap.Solenoid.DRIVE_SHIFT_HIGH, RobotMap.Solenoid.DRIVE_SHIFT_LOW);
        frontLeft = new Pod(RobotMap.PWM.DRIVE_FRONT_LEFT,
                RobotMap.PWM.DRIVE_FRONT_LEFT_STEERING,
                RobotMap.DIO.DRIVE_FRONT_LEFT_ENC_A,
                RobotMap.DIO.DRIVE_FRONT_LEFT_ENC_B, 1);
        frontRight = new Pod(RobotMap.PWM.DRIVE_FRONT_RIGHT,
                RobotMap.PWM.DRIVE_FRONT_RIGHT_STEERING,
                RobotMap.DIO.DRIVE_FRONT_RIGHT_ENC_A,
                RobotMap.DIO.DRIVE_FRONT_RIGHT_ENC_B, 2);
        rearLeft = new Pod(RobotMap.PWM.DRIVE_REAR_LEFT,
                RobotMap.PWM.DRIVE_REAR_LEFT_STEERING,
                RobotMap.DIO.DRIVE_REAR_LEFT_ENC_A,
                RobotMap.DIO.DRIVE_REAR_LEFT_ENC_B, 3);
        rearRight = new Pod(RobotMap.PWM.DRIVE_REAR_RIGHT,
                RobotMap.PWM.DRIVE_REAR_RIGHT_STEERING,
                RobotMap.DIO.DRIVE_REAR_RIGHT_ENC_A,
                RobotMap.DIO.DRIVE_REAR_RIGHT_ENC_B, 4);
    public void teleopDrive() {
        //get values from joysticks
        double x, y, rotate;
        boolean isLowGear, isHighGear;
        x = CommandBase.oi.stick1.getRawAxis(RobotMap.Control.DRIVE_CONTROLLER_AXIS_1);
        y = -CommandBase.oi.stick1.getRawAxis(RobotMap.Control.DRIVE_CONTROLLER_AXIS_2);
        rotate = CommandBase.oi.stick2.getRawAxis(RobotMap.Control.DRIVE_CONTROLLER_AXIS_1);
        isLowGear = CommandBase.oi.stick1.getRawButton(RobotMap.Control.DRIVE_CONTROLLER_SHIFT_LOW);
        isHighGear = CommandBase.oi.stick1.getRawButton(RobotMap.Control.DRIVE_CONTROLLER_SHIFT_HIGH);
        //calculate angle/speed setpoints using 28 by 38 inch robot
        double L = 28, W = 38;
        double R = Math.sqrt((L * L) + (W * W));
        double A = x - rotate * (L / R);
        double B = x + rotate * (L / R);
        double C = y - rotate * (W / R);
        double D = y + rotate * (W / R);
        //find wheel speeds
        double frontRightWheelSpeed = Math.sqrt((B * B) + (C * C));
        double frontLeftWheelSpeed = Math.sqrt((B * B) + (D * D));
        double rearLeftWheelSpeed = Math.sqrt((A * A) + (D * D));
        double rearRightWheelSpeed = Math.sqrt((A * A) + (C * C));
        //normalize wheel speeds
        double max = frontRightWheelSpeed;
        if (frontLeftWheelSpeed > max) {
            max = frontLeftWheelSpeed;
        if (rearLeftWheelSpeed > max) {
            max = rearLeftWheelSpeed;
        if (rearRightWheelSpeed > max) {
            max = rearRightWheelSpeed;
        frontRightWheelSpeed /= max;
        frontLeftWheelSpeed /= max;
        rearLeftWheelSpeed /= max;
        rearRightWheelSpeed /= max;
        //find steering angles
        double frontRightSteeringAngle = MathUtils.atan2(B, C)*180/Math.PI;
        double frontLeftSteeringAngle = MathUtils.atan2(B, D)*180/Math.PI;
        double rearLeftSteeringAngle = MathUtils.atan2(A, D)*180/Math.PI;
        double rearRightSteeringAngle = MathUtils.atan2(A, C)*180/Math.PI;
        //set shifter
        if(isLowGear){
            shift.set(DoubleSolenoid.Value.kForward);
        if(isHighGear){
            shift.set(DoubleSolenoid.Value.kReverse);
        //set pods
        frontRight.setSteeringAngle(frontRightSteeringAngle);
        frontRight.setWheelSpeed(frontRightWheelSpeed);
        frontLeft.setSteeringAngle(frontLeftSteeringAngle);
        frontLeft.setWheelSpeed(frontLeftWheelSpeed);
        rearLeft.setSteeringAngle(rearLeftSteeringAngle);
        rearLeft.setWheelSpeed(rearLeftWheelSpeed);
        rearRight.setSteeringAngle(rearRightSteeringAngle);
        rearRight.setWheelSpeed(rearRightWheelSpeed);
    private class Pod implements PIDOutput, PIDSource {
        private Encoder steeringEnc;
        private SpeedController drive;
        private SpeedController steer;
        private PIDController pid;
        public Pod(int drivePWM, int steeringPWM, int steeringEncA,
                int steeringEncB, int podNumber) {
            steeringEnc = new Encoder(steeringEncA, steeringEncB);
            steeringEnc.setDistancePerPulse(RobotMap.Constants.STEERING_ENC_REVOLUTIONS_PER_PULSE);
            drive = new Victor(drivePWM);
            steer = new Victor(steeringPWM);
            pid = new PIDController(RobotMap.Constants.STEERING_PID_P,
                    RobotMap.Constants.STEERING_PID_I,
                    RobotMap.Constants.STEERING_PID_D, this, this);
            SmartDashboard.putData("Steering Pod " + podNumber, pid);
            pid.setInputRange(-180, 180);
            pid.setContinuous(true);
            pid.enable();
        public void pidWrite(double output) {
            steer.set(output);
        public double pidGet() {
            return steeringEnc.getDistance();
        public void setSteeringAngle(double angle) {
            pid.setSetpoint(angle);
        public void setWheelSpeed(double speed) {
            drive.set(speed);
    public void initDefaultCommand() {
