Go to Post [in best Tom Hanks voice] Are you crying? ARE YOU CRYING? There's no crying! THERE'S NO CRYING IN ROBOTICS! - dlavery [more]
Unread 31-05-2013, 22:01
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
Team Role: Leadership
Rookie Year: 2011
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
How many motors can you run at once?
Last year (2012), our team had a problem of running too many motors at once, we had 2 motors for our intake, and 3 for our shooter, and when we would drive (2 motors), we would stall out one of our motors. How many motors did your team run at once? and what techniques did you use to prevent something like this?
Unread 31-05-2013, 22:14
Samwaldo's Avatar
Samwaldo Samwaldo is offline
College Student / Between Teams
Rookie Year: 2010
Samwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to beholdSamwaldo is a splendid one to behold
Re: How many motors can you run at once?
If I remember correctly our 2012 bot gets the award for most motors
4 motors for conveyer belts/pick up
2 motors for shooting
2 motors to drive
1 motor to tilt shooter/shift electronics board and battery (for weight movement during balance)
1 motor for bridge device
Thats 10 (I might be missing one because I remember the number 11).
We placed bets to see which would burn out first. We NEVER changed one.
no problems, with so many motors. most were even running the whole time, and many under ALOT of wieght
Team 1099, The DiscoTechs, 10' - 14'
Driver 11' - 14'................Team Captain 13' - 14'
University of Hartford Class of 2018, Mechanical Engineer
2015 & 2016 NE District Volunteer
Unread 31-05-2013, 22:20
rwkling1's Avatar
Rookie Year: 2011
2 motors to drive
That's so interesting, because for some reason our robot would always kill one motor even though we were only running 7-8 at one time
Unread 31-05-2013, 22:22
Colin's Avatar
Colin Colin is offline
FRC #0254
Colin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond reputeColin has a reputation beyond repute
Do you know what motor specifically was stalling? It sounds more like a mechanical issue.
The only issue that I have seen with running too many motors (more than what you are describing here) is tripping the main robot breaker.
Unread 31-05-2013, 22:25
rwkling1's Avatar
Rookie Year: 2011
It was one of our banebot motors for our intake
Unread 01-06-2013, 01:28
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Almost certainly mechanical. This year we had 4 CIMs and 4 MiniCIMs running at the same time with no problems.
Unread 01-06-2013, 08:13
apples000's Avatar
apples000 apples000 is offline
Rookie Year: 2012
apples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant futureapples000 has a brilliant future
We had 6 cims on drive, 2 banebots for shooter, 1 minicim for deploying the climber, and a compressor running at the same time. In the past, we've had more. Its probably a mechanical issue.
Unread 01-06-2013, 10:33
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
As others have pointed out, it's not the quantity of motors, but the current that they draw. Do you have a way of measuring? Any motors getting overly warm?
Unread 01-06-2013, 10:35
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
In 2012 we had 12 motors
4 550s on drive
2 cim shooter
4 motors for intake
1 motor for bridge tipping(don't remember motor)
window motor for turret
Unread 01-06-2013, 10:50
AlexH AlexH is offline
Rookie Year: 2010
AlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to allAlexH is a name known to all
Originally Posted by tickspe15 View Post
4 550s on drive
you drove a 150lb robot with 4 550's?
how did that work out?
My Instructables
Unread 01-06-2013, 11:05
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
We had 14 in 2012. Our only confirmed failures were mechanical (or programming).
- (4) CIMs - 1 per swerve wheel, driving
- (4) BB 395s - 1 per swerve wheel, steering
- (2) AM-0912s - ball acquisition & lift
- (1) FP 9015 - shooter drive
- (1) Denso Throttle - shooter tach
- (1) FP 9013 - barrier crossing + ball intake
- (1) Window Motor L - bridge lowering
I'm not saying it a was a good idea, but it worked out ok. No systemic electrical issues with respect to it.
Unread 01-06-2013, 11:56
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
The limiting factor is how much current can you pull from the battery before the voltage drop across the sum of all resistance exceeds the drop out for the voltage regulators. The internal resistance on a new, fully charged battery is .011 ohms. At 400 amps that will drop almost 5 volts. Figure another 2 volts for other resistance and you now are below the threshold at which the voltage can be maintained in the DSC. when the voltage falls down to 4.5 volts, the 24 volts and the 12 volts for the radio will drop out.
My recommendation is to limit motor usage to below 300-350 amps at any one time. You can do this by ramping up the motors you are turning on and using delays to prevent them from all starting at the same time. A motor that is not turning is in stall and will draw full stall current limited only be the series resistance of the circuit feeding the motor. Typical stall currents of 115 amps for CIM motor is common on an average robot.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 01-06-2013, 13:28
Andrew Lawrence
Posts: n/a
I'd say you can run no more than the amount specified in the rules.
Unread 01-06-2013, 14:06
Siri's Avatar
Dare greatly
Team Role: Coach
Rookie Year: 2007
Technically, this was unlimited in 2012 (and 2013), because there was no cap on the allowed number of drive motors in COTS computing devices. You would hit the weight, cost or size limit eventually, though.
Section in full: K. drive motors or fans that are part of a speed controller or COTS computing device and fans included in the 2012 Kit of Parts.
There were also an unlimited number of certain servos and electrical solenoid actuators, which, while not "motors", do seem to fall into the OP's electrical concerns. However, it'd take some doing to compare them with a CIM, and I don't think that's actually what caused the referenced problem anyway. Electrical load issues can manifest in many ways--listen to Al (always, but particularly about the radio dropping out). But it's not the most likely explanation for stalling the same motor over and over again.
  #15   Spotlight this post!
Unread 01-06-2013, 22:10
rwkling1's Avatar
Rookie Year: 2011
Thanks for the input guys, I'll have to do some testing over the summer!
