Go to Post Hey... wait... that looks like a LEGAL bumper configuration! You can't post a photo with a legal configuration... we'd have nothing to talk about! - dtengineering [more]
Unread 04-06-2013, 03:45
ablatner ablatner is offline
AKA: Andrew Blatner
FRC #0100 (The Wildhats)
Team Role: Leadership
ablatner is on a distinguished road
Re: WCD Bearing Blocks
Originally Posted by craigboez View Post
Thanks for all the explanation. I never realized that the sideplates actually clamped the bearing block in place. The cam tensioners make a lot more sense now.
Usually the side plates actually ARE the bearing blocks. The bearings are in the two side plates which fasten together from opposite sides of the tubing.
2009-2013: Student, Team 100
2013-????: ?
Unread 04-06-2013, 15:30
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
It sounds like there are two common ways to create the bearing block assembly.
  1. Use two sideplates and a block of aluminum. The bearings go in the aluminum block, the sideplates hold it all together and clamp it in place. The machining for this setup is relatively simple.
  2. The two sideplates become the bearing block and are constrained coaxially with a short piece of thick walled tubing that connects them. The machining for this setup is comparatively complex.
Is that a fair statement? If so, what are the benefits to method #2?
Unread 04-06-2013, 18:05
AKA: Andrew Blatner
I've never actually seen #1.
2013-????: ?
Unread 04-06-2013, 19:36
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
The Team 221 "Universal Chassis" uses this design.
This is a neat concept along the same vein.
Unread 04-06-2013, 19:55
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Originally Posted by Nate Laverdure View Post
The Team 221 "
Given that those already have to be CNC machined there's not a lot of benefit to doing it that way than the way we do ours.
2001-2004: Team 100
2006-Present: Team 254
Unread 05-06-2013, 20:58
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
I like these a lot.
If you created the center block with a single through hole and made the side plates with a larger hole in them to accommodate for the flange then you could make these without flipping the stock.
And if you have a drill bit at 1.125 and 1.25, you could do it without CNC work.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 04-06-2013, 19:39
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
We run #1. CAD in sig. 09 was unique, 10 and 11 were new design.
Unread 04-06-2013, 21:10
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Jabba made one like this while mentoring for 931 several seasons back.
They refined the design and used it a couple of times since, I think.
Richard Wallace
since 2003
Unread 05-06-2013, 22:50
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
The biggest benefit to #2 is weight. We've gone both routes(2012 #1 using sponsors because we didn't have a mill in house, 2013 #2 buying from WCP). If you have a CNC #2 is fine, but it isn't necessary by any means. You can do #1 super simply. When we did it, we didn't even do chamfers on the center block and our sideplates could have been made with a chopsaw. Depending on your teams resources you can make the blocks marginally more complex(chamfering the blocks means you don't have to file as much later, waterjetting sideplates is a small weight savings and they look a bit nicer). Either way works, and the method you choose completely depends on your team and its resources.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
