Go to Post A big bowl of popcorn and FIRST. It doesn't get much better than that. - Warren Boudreau [more]
Thread Tools Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Unread 06-06-2013, 23:18
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Question Mini Cim Drive Motors?
I am currently trying to design a robot in CAD and I was trying to decide what type of motors should be for the drivetrain. Currently you can use 4 mini cims so 2 per side. Would that be strong enough?
Unread 06-06-2013, 23:22
Boe's Avatar
Boe Boe is offline
2175 Alum
AKA: Brian Boehm
FRC #2175 (The Fighting Calculators)
Rookie Year: 2012
Boe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud ofBoe has much to be proud of
Re: Mini Cim Drive Motors?
It would probably be strong enough (havent done the math but i would think it would work) but i would use four regular CIMs in your drive unless you have a good reason not to
2014 IRI-Quarterfinalists (Thanks 368, 1477, 233)
2014 Minnesota State Championship-Winner (Thanks 2052, 4778)
2014 Archimedes Division-Quaterfinalists (Thanks 399, 2056, 2834)
2014 North Star-Semifinalists (Thanks 967, 4607)-Creativity Award-Safety Award
2014 Northern Lights-Winners (Thanks 359, 2502)-Excellence in Engineering-Safety Award
2013 Minne-Mini-Winners (Thanks 2169, 3883, 4239)
2013 MRI-Winners (Thanks 2052, 3130, 3313)
2013 MN State Fair-Winners
2013 IRI-Participant
2013 Minnesota State Championship-Winners (Thanks 2052, 4607)
2013 Galileo Division-Finalists (Thanks 2169, 3284)
2013 North Star Regional-Team Spirit Award-Winners (Thanks 967, 4607)
2013 Northern Lights Regional-Entrepreneurship Award-Quarterfinalists (Thanks 3130, 1675)
2012 North Star Regional-Creativity Award-Quarterfinalists (Thanks 2549, 3130)
2012 Lake Superior Regional-Coopertition Award-Quarterfinalists (Thanks 1625, 2957)
Unread 06-06-2013, 23:53
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
It should work. However, VEXPro is quite clear in the motor description that it is only 2/3 of the power of the CIM (and a higher output speed, meaning less available torque). For an FRC-season drivetrain, you will need to make the decision as to whether the lower power in drive is worth the lower weight of the drive and higher power available elsewhere for yourself.
That said, why not try going with 1 of each? They use the same mounting, and aside from the speed difference (which is pretty easy to deal with by gearing), they should work well together.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 07-06-2013, 09:42
MichaelBick MichaelBick is offline
FRC #1836 (MilkenKnights)
Rookie Year: 2010
MichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant futureMichaelBick has a brilliant future
Based on the current motor allotments there isn't much reason to switch to mini-cims. You have 6 CIMs and 4 mini CIMs, which gives you plenty of power if you need it. Unless you have a game with low traction surfaces or wheels(like lunacy), I would recommend running 4 CIMs because it helps getting through defense and allows you to play defense if needed. The weight loss is worth it. I would reccomend always running at least 4 CIMs on your drive.
Team 1836 - The Milken Knights
2013 LA Regional Champions with 1717 and 973
2012 LA Regional Finalists with 294 and 973
To follow Team 1836 on Facebook, go to http://www.facebook.com/MilkenKnights
To go to our website, go to http://milkenknights.com/index.html
Unread 07-06-2013, 10:17
Nathan Streeter's Avatar
Nathan Streeter Nathan Streeter is offline
FIRST Fan(atic)
FRC #1519 (Mechanical MAYHEM)
Nathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond reputeNathan Streeter has a reputation beyond repute
4 Mini CIMs would probably be very noticeably weaker on the drivetrain than 4 CIMs.
According to the VexPro specs, the Mini CIMs have 66% of the power and 50% of the torque (when adjusted for their different free speed rpms) of the standard CIM. As an educated guess, the torque is probably a more important factor for acceleration and pushing than the max power is... So the 4 Mini CIMs would be pretty similar to a 2 CIM drive. In a nutshell, 2 CIMs is "inadequate" for a ~100+ pound that drives on an ordinary surface and will be accelerating beyond 10fps, pushing robots around, or driving over field obstacles. Given that a few teams are even using 6 CIMs now, I'd say you're best off with 2 CIMs & 2 Mini CIMs or 4 CIMS. The extra .5# per CIM on the drivetrain is well worth it for >95% of FRC robots.
As some anecdotal stuff: 1519's used 2 CIMs on three of our competition robots... one was Speedracer, a fast lapbot from 2008; the other was Fezzik, our hurdling robot from 2008; and one was Colonel York, our 2009 robot.
Speedracer from 2008: was a ~40# robot that had 2 CIMs driving the rear wheels and ackerman steering in the front. It was geared fast, but not excessively so. It accelerated well and never had overheating issues. Definitely no regrets on using only 2 CIMs. We have video of it on our team webpage (our more recent videos are on youtube, though).
Fezzik, our hurdler from 2008: was initially designed to meet all robot rules (weight, volume, interchangeable electronics, bumpers) together with Speed Racer... so we took a couple weight-saving compromises... one was to use only 2 CIMs. It experienced significant over-heating issues after matches - in elims they got hot enough that you couldn't keep your hand on them! After our first event (and the interchangeable robot thing was ruled illegal - see thread about it) we put the extra 2 CIMs on there. It was probably was ~11-14fps... moderately fast but nothing noteworthy.
Colonel York, our 2009 robot: ran on the low-traction surface using the required slick wheels... as a result there was no need for more than 2 CIMs of torque. I'd venture you could've used 1 RS550 on each side of a tank drive that year, given that the wheels had some <0.1 coefficient of friction on the field surface.
Every other year we've used 4 CIMs in either single-speed or two-speed transmissions. Again, if you really need the weight maybe switching 2 of the CIMs for MiniCIMs would be worthwhile; however, I'd venture for most robots there are better weight saving measures.
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
Unread 07-06-2013, 11:40
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
They are certainly a possibility for drive motors, our team had a great opportunity to talk to Paul Copioli at length about the Mini Cim's (and other Vex Pro products) at Waterloo this year. Paul told us that they were designed when paired 1:1 with regular CIMs in a drive system, a 4 CIM 2 Mini CIM drive could be quite powerful. We ran a 6 CIM drive this year and loved the acceleration and power it gave us with a single speed gearbox.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
Unread 07-06-2013, 14:55
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
The meaning of the above is a bit unclear to me.
It sounds like it's saying "no gear compensation for the different free speeds". That's not the intent, is it?
Unread 07-06-2013, 15:50
Jno
Thats the intent that I remember from Paul (I might be totally wrong), but to be honest I haven't worked on motor dynamics in a couple years. Obviously at free speed and stall the mini Cim wouldn't match the CIM, but the dynamics of how the load is shared in a gearbox with motors of non-matching free speeds is escaping me right now. I'll shoot Paul an Email and see if he can correct me.
Unread 07-06-2013, 16:06
Ether's Avatar
Rookie Year: 1969
Thats the intent that I remember from Paul.
I had forgotten that the mini CIM free speed is 6200. I guess that's close enough to 5310 that 1:1 would work. The mini-CIM would be carrying just a bit more than its "fair share" of the load (relatively speaking).
Unread 07-06-2013, 16:11
BenB's Avatar
BenB BenB is offline
AKA: Ben Bennett
FRC #1114 (Simbotics)
Rookie Year: 2007
BenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond reputeBenB has a reputation beyond repute
I wouldn't be surprised if this was the design intent. Joe Johnson explained why it doesn't matter if motor speeds match in this post. For packaging reasons, we geared 2 CIMs 1:1 with 2 mini-CIMs in our climbing mechanism this year and it seemed to work fine.
2010-present - Team 1114 - Simbotics
2007-2009 -Team 2166 - Bluebotics
Unread 07-06-2013, 16:54
Ether's Avatar
Rookie Year: 1969
To be clear: Joe did not say "it doesn't matter". He said:
The question of whether to put multiple motors in parallel is not a simple one to answer. ... I don't not agree with those who say that you must always match free speeds of the motor
There are times when you do want to match free speeds. It depends on the application and the expected operating conditions.
Here's a simple chart which shows the difference between running a CIM and a mini 1:1 vs running them with matched free speeds. Column H "relative heat" shows the mini's heat generation relative to the CIM. It's an indication of how "hard" the mini is working relative to the CIM. The mini is smaller than the CIM and cannot be expected to sustain the same rate of heat dissipation as the CIM.
Does anyone have any data on the relative heat dissipation capability of the mini compared to the CIM?
Unread 07-06-2013, 19:49
Paul Copioli's Avatar Unsung FIRST Hero Woodie Flowers Award
Paul Copioli Paul Copioli is offline
President, VEX Robotics, Inc.
FRC #3310 (Black Hawk Robotics)
Rookie Year: 2000
Paul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond reputePaul Copioli has a reputation beyond repute
Ok so the Mini CIM was designed specifically do mate 1:1 with the CIM motor. The design goals were:
(1) Same exact mounting as CIM motor
(2) Have current draw of approximately 40 amps at max power.
(3) Optimized (while keeping constraint #2) to mate 1:1 with the CIM motor to maximize the Mini CIM contribution at maximum power. We are about 10% off from this goal.
We utilized a Magtrol automated Dynamometer setup to test various conditions to make sure the contribution of the mini CIM when combined with a CIM motor was as expected.
My team ran mini CIMs along side CIM motors in our drive gearbox (4 CIMs and 2 Mini CIMs) and they performed as expected.
I hope this sheds some light on the mini CIM performance.
Paul
In full disclosure I am the President of VEX Robotics, a division of Innovation First International.
Unread 07-06-2013, 20:36
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Only a little data now, will try to get more later:
We fitted a CIM and a mini-CIM with thermocouples to measure temperature on their brush guides; this is the hottest non-moving internal part -- the moving armature windings get a few degrees hotter. On a Magtrol brake dynamometer, we ran the CIM at its normal load, which is about 0.45 N-m drawing about 27 Ampere, per the data sheet. We ran the mini-CIM at 2/3 of that load, 0.30 N-m drawing about 17 Ampere.
As has already been noted, the mini-CIM operating at 2/3 the torque load of a CIM is actually running more efficiently; thus its power losses (waste heat) are lower than the CIMs in both relative and absolute terms.
Our thermocouple measurements showed the CIM brush guide reaching 125 degrees Celsius after eight minutes, while the mini-CIM brush guide took twelve minutes to reach the same temperature.
Richard Wallace
since 2003
Unread 07-06-2013, 21:42
Ether's Avatar
Rookie Year: 1969
Originally Posted by Richard Wallace View Post
we ran the CIM at ... 0.45 N-m drawing about 27 Ampere... the CIM brush guide reaching 125 degrees Celsius after eight minutes
Did you record the CIM RPM under those test conditions?
This would be interesting: apply whatever load is required to pull down the mini (with 12V applied) to the same RPM as the CIM (1:1 mechanical pairing simulation) and see how many minutes it takes to reach 125C.
  #15   Spotlight this post!
Unread 07-06-2013, 22:15
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
At 12 volts, a CIM goes 3790 rpm at 40 amps and a miniCIM goes 3375 rpm at 40 amps. Therefore, designing a drive train to pull 40 amps per motor at the traction limit with CIMs and miniCIMs in parallel is near achievable with a 1:1 pairing of the motors.
Running the miniCIM at the same speed as the CIM at the traction limit (1:1 pairing) would mean running the CIM at 40 amps and the miniCIM at 34.3 amps, at 12 volts.
Based on these results, I would say it makes sense to run CIMs and miniCIMs together 1:1 in the drive train if design calls for it. So if you need extra power elsewhere, need weight savings that can't be found anywhere else, or have other design criteria, it should work well. It has worked well for many teams.
From what I've seen, miniCIMs are best suited of any of the 2013 legal motors to supplement or replace CIMs in the drive train since they are designed to take that type of abuse. Most other FRC motors simply are not.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
