Go to Post I believe in my students, I encourage them to fail in their endeavors to find the best formula. There is valuation in failure. - Chief Hedgehog [more]
Unread 17-06-2013, 23:00
tyler34 tyler34 is offline
Rookie Year: 2011
tyler34 is an unknown quantity at this point
Trouble with limit switches
So basically we can't get a change in value when the limit switch is pressed.
We have one end of the limit switch wired to signal and the other to ground on the Digital Inputs on the Digital Sidecar.
We are using Java for our programming.
Heres the code pulled out from robotInit and teleopPeridodic:
Code:
private DigitalInput limit;
limit = new DigitalInput(1);
System.out.println("ingest switch: " + limit.get());
We tried connecting the ground a signal wires together without the limit switch, tried different cables, and different ports. Nothing seems to work.
If someone has any idea on what to try it would be helpful.
We are gonna try a new digital sidecar tomorrow and see if that works.
Unread 18-06-2013, 00:44
Teamcodeorange's Avatar
Teamcodeorange Teamcodeorange is offline
FRC #3476
Teamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant futureTeamcodeorange has a brilliant future
Re: Trouble with limit switches
One symptom of a broken ribbon cable is bad I/Os. Do a continuity test on each of the pins. This exact thing happened to us and cost over an hour at competition.
Try Code Orange's electronics tutorials!
2015 - Tesla Division Champions
2015 - Inland Empire Engineering Inspiration Award
2015 - San Diego Regional Chairman's Award
2014 - San Diego Regional Chairman's Award
2013 - Newton Division Champions
2012 - San Diego Regional Winners
Unread 18-06-2013, 07:56
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Measure the voltage on the DIO signal pin. It should change when you flip the switch.
Is the Digital Sidecar correctly powered? The 5V light needs to be shining bright in order for the inputs to work.
Unread 18-06-2013, 11:31
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
It's not working because you are supposed to connect the switch to SIG and POWER.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 18-06-2013, 11:36
Rookie Year: 2011
The 5V light was lighting up like it should be.
Everywhere I've looked says to connect ground to signal, so I'm not sure that is correct. Connecting the power to signal doesn't do anything either anyways.
We have other IO pins being used with encoders that are working perfectly fine. Whenever we try to use a limit switch on any of the pins, it doesn't work. I can try a new ribbon cable later today and see if that works.
Unread 18-06-2013, 11:43
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
That's not correct. The digital sidecar has a pullup to 5v on the signal line. Connecting a switch between signal and power means that signal will never change from 5v. You need to connect the switch between signal and ground, so that signal will switch from 5v (when open) to ground (when closed).
I also guess that something is wrong with power. Follow Alan's suggestions.
Unread 18-06-2013, 12:08
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Some thoughts:
1. Double and triple check the code to make sure you aren't assigning something else to that pin as well.
2. Try creating a whole new software project that has nothing in it but the limit switch code, to make sure you aren't running into any issues with other stuff interfering.
3. Unplug your limit switch and verify it's working as intended - use a multimeter to measure resistance between the two pins on the PWM connector - you should see the resistance value switch between infinite and 0 ohms when pressing the switch (as for which one is which, that's up to how it's wired - normally connected or normally open).
4. Check the LED's on the DSC - all three should be brightly lit (5V, 6V and Power), and you should see the RSL working correctly.
5. Take spares of other parts (DSC, DSC-cRIO cable, etc) and swap them out to make sure the problem isn't in one of them.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 18-06-2013, 12:40
androb4's Avatar
AKA: Andrew A.
Ooooowwh...it pulls up.
In my defense, I don't think I've used a custom digital input.
Unread 18-06-2013, 13:18
efoote868 efoote868 is offline
foote stepped in
AKA: E. Foote
FRC #0868
efoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond reputeefoote868 has a reputation beyond repute
Originally Posted by Jon Stratis View Post
Some thoughts:
You can also use that same multimeter to measure the voltage potential on and across the limit switch while it's plugged in. If it's changing how you expect it to, you likely have a software problem. If it isn't changing, you likely have a wiring problem.
Be Healthy. Never Stop Learning. Say It Like It Is. Own It.
Like our values? Flexware Innovation is looking for Automation Engineers. Check us out!
