Go to Post If you use a flux capacitor make certain it is a COTS component, or that you fabricate it from COTS materials. - Richard Wallace [more]
Thread Tools Rating: Thread Rating: 13 votes, 5.00 average. Display Modes
Unread 19-06-2013, 16:07
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
[FRC Blog] New 2015 FRC controller from National Instruments
Original post: http://www.usfirst.org/roboticsprogr...ts#comment-948
NI will be releasing details about the 2015 FRC controller at their NI Week conference in August… but they’re excited about how well it’s all coming together. They even shared this photo of the bare PCB, hot off the press, with us. See anything interesting?
I’ll blog again soon.
Frank
I believe I spy PWM outputs on there. I'd love to see the death of the digital sidecar and the return of on-board I/O!
Team 2052- Knightkrawler
Mentor and volunteer
Unread 19-06-2013, 16:18
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: [FRC Blog] New 2015 FRC controller from National Instruments
The 3.3v and 5v jumper on the bottom left corner looks interesting. maybe both voltages will work for IO. on the top i see an ethernet port, a USB port, and also maybe an ISP header on the top right. ARM based maybe?? Also i'm liking the new size of the board.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 19-06-2013, 16:23
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
I think you're right about the PWM inputs, but that 2x16 (or so) set of holes looks like it might be for a ribbon cable attachment. Perhaps both onboard PWM and the option for a digital sidecar?
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 19-06-2013, 16:33
Richard Wallace's Avatar
Richard Wallace Richard Wallace is offline
I live for the details.
FRC #3620 (Average Joes)
Rookie Year: 1996
Scaling from the size of the 34 way DIL header pads near the middle, it appears this board will fit into an ~square plastic enclosure that is just under 7 inches on each side, with holes spaced 6 inches apart. It should also have a low profile. These are steps in the right direction.
Richard Wallace
since 2003
Unread 19-06-2013, 16:21
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
I heard it is about the size of two digital sidecars put together and that it includes PWM outputs. So it combines the crio and the digital sidecar but you need an extension for pneumatics.
Edit: I've attached a smaller version of the image for reference.
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 19-06-2013, 16:30
Peter Johnson Peter Johnson is online now
WPILib Developer
FRC #0294 (Beach Cities Robotics)
Peter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud ofPeter Johnson has much to be proud of
My guesses at connectors (referenced to photo location)
Top of picture (left to right):
- unknown 4-pin
- USB-B?
- 2x stacked USB-A
- Ethernet
- unknown 10-pin ribbon-style
Left of picture (top to bottom):
- unknown 4-pin
- unknown 3-pin
- 10x PWM: motor or digital
Bottom of picture (left to right):
- 3-pin: power input
- J1 (2 pin): robot signal light?
- 8x PWM: analog
- 2x unknown?
Right of picture (top to bottom):
Center of picture:
- Big ribbon cable (34 pin): digital sidecar expansion?
Author of cscore - WPILib CameraServer for 2017+
Author of ntcore - WPILib NetworkTables for 2016+
Creator of RobotPy - Python for FRC
2010 FRC World Champions (294, 67, 177)
2007 FTC World Champions (30, 74, 23)
2001 FRC National Champions (71, 294, 125, 365, 279)
Unread 19-06-2013, 16:34
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
- unknown 4-pin
- USB-B?
- 2x stacked USB-A
- Ethernet
- unknown 4-pin
- unknown 3-pin
- 8x PWM: analog
- 2x unknown?
Center of picture:
I hope we get more than 20 combined pwm out/digital in!
Unread 19-06-2013, 16:41
WPILib Developer
Based on other information I've seen posted about the new system, there will likely be a way to get more through some sort of expansion port like they're doing for pneumatics breakouts (via CAN bus). If the 34-pin header is compatible with the existing digital sidecar that's an even more straightforward expansion.
Speaking of, at least a couple of the connectors on this PCB should be for the CAN bus, but it's hard to tell which ones.
Unread 19-06-2013, 16:43
ehochstein's Avatar
AKA: Evan Hochstein
FTC #5943 (ESGM)
Team Role: Coach
Rookie Year: 2007
I've also heard you will be able to run two controllers in master-slave mode to allow for additional ports. I believe their goal is to make this controller affordable for each team to buy one yearly (as it should be).
Unread 19-06-2013, 16:45
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Here's the things you should be trying to fit in: http://www.chiefdelphi.com/forums/sh...23#post1267723
Unread 19-06-2013, 16:51
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
I'm going to guess that the IDE style connector will got to a CAN "sidecar" like the CRE crosslink.
also the ethernet and the USB-B port look like right angle parts. hmmh....
2014-2015: FRC 865 Warp7 Team Captain
2016: FRC 865 Mentor
2017: Free Agent Mentor, Inspector
Unread 19-06-2013, 17:43
Kims Robot's Avatar Unsung FIRST Hero
Kims Robot Kims Robot is offline
Onto a New Chapter...
AKA: Kim O'Toole Eckhardt
Rookie Year: 1996
Kims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond reputeKims Robot has a reputation beyond repute
Send a message via AIM to Kims Robot
Is it bad that his comment made me look for the screenprinted FIRST logo somewhere on the board? Unfortunately it doesnt look like that is the "interesting" part. A little sizable, but looks like some good features
~kim~
Kimberly O'Toole Eckhardt <3
Principal Systems Engineer & Program Manager
History - Team 176, Team 229, Team 1511, FIRST Volunteer!!
My new FIRST Photography Hobby & Angry Eric's Fan Page
Excellence - is the result of caring more than others think is wise, risking more than others think is safe, dreaming more than others think is practical, and expecting more than others think is possible.
Unread 19-06-2013, 18:14
WPILib Developer
The center component looks like it's for a Xilinx FG400 package.. so maybe a Spartan-3 series FPGA? If so, processor is likely on the other side of the board.
Unread 19-06-2013, 23:30
WPILib Developer
I think the big connector is simply the "custom electronics port". The Ethernet and USB ports look vertical style instead of right angle (if it was right angle, the Ethernet port would be facing the center of the board). Also, vertical style ports would be consistent with the cRIO style and make possible more compact electronic layouts (no ports off to the sides!).
  #15   Spotlight this post!
Unread 19-06-2013, 19:05
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
There definitely appears to be an IDE style connector in the middle of the board. What functionality could that provide that wouldn't be better suited for a CAN or similar digital connection? Seems like those big and bulky ribbon cables are relics of the past. Backwards compatibility?
