Go to Post I think with 1114 & 217 as our partners we could have won with my refrigerator on the field. - JVN [more]
Unread 30-06-2013, 10:14
Mr. 1033's Avatar
Mr. 1033 Mr. 1033 is offline
AKA: Paul E. Lathrop
FRC #1033 (Team CLUTCH)
Team Role: Coach
Mr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the roughMr. 1033 is a jewel in the rough
FTC: Using the Hitechnic SuperPro Prototype Board
Does anyone have any experience with the Hitechnic SuperPro Prototype board?
http://www.hitechnic.com/cgi-bin/com...on&key=SPR2010
My 5 FTC teams have always had inconsistency issues with the encoders from Tetrix and the IR sensor.
My understanding from what I've read is that we can use this prototyping board and attach sensors to it. Then its just a matter of programming it in LabView or Robot C.
Thoughts?
Unread 30-06-2013, 13:11
Rainydaymaker's Avatar
Rainydaymaker Rainydaymaker is offline
AKA: Jim
FRC #1983 (Skunk Works)
Rainydaymaker is on a distinguished road
Re: FTC: Using the Hitechnic SuperPro Prototype Board
We used it last year to read limit switches.
Jim Smith
FLL Coach
FTC Coach 3721
FRC Mentor 1983
Unread 30-06-2013, 22:19
Andrew Lobos Andrew Lobos is offline
FTC4977/FRC225 Alum
FRC #0225 (TechFire)
Rookie Year: 2011
Andrew Lobos has a spectacular aura aboutAndrew Lobos has a spectacular aura aboutAndrew Lobos has a spectacular aura about
We have used the protoboard in the past to read potentiometers for position of arms and swerve pods.
We have had no issues with the encoders being read by the motor controllers in the past. What issues did you encounter?
If you are thinking of using the protoboard to read encoders, I would be careful. Since there is no way to catch interrupts on the protoboard, you would have to constantly poll the protoboard; this creates the potential for missing pulses. The TETRIX motor controllers use interrupts on the encoder ports to prevent missing pulses.
Unread 01-07-2013, 07:40
Mr. 1033's Avatar
Team Role: Coach
In all my years of coaching ftc, the tetrix encoders could give accurate readings in some matches and completely wring the next match.
I've observed and heard this from over 20 other teams in addition to my 5 or 6 teams.
We mount encoders per the instructions using white cloth gloves and everything.
The program produces clean build and will run correctly up until the randomness ten or more attempts later.
Regardless I think were going to use the prototype boards for limit switches, leds etc.
Anyone have any tips or ideas for encoders?
Unread 01-07-2013, 11:08
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
"Completely wrong" as in no pattern at all or +/- a few inches up to a feet?
One suggestion is don't draw too much power from the motor controllers at once (like putting full throttle on a six motor drivetrain instantaneously) since that does in fact mess up the encoder count.
Unread 01-07-2013, 11:42
FTC4977/FRC225 Alum
Rookie Year: 2011
This happens because the encoder counts are stored and read from the motor controllers - if they loose power (or brownout), the count will reset.
My FTC team used encoders to achieve infinite rotation on our swerve drive last year, and we had no issues with the encoders returning the wrong position.
A few more questions -
How old are the encoders you're using? Some of the older packages they made used adhesive backing, which I've seen come loose.
When deciding the encoders are returning incorrect values, are you looking at the value itself, or just seeing the results of an action using the encoders? If you are observing the robot driving different distances, but the encoder values are consistant, your issue may be rooted in how your code decides it is "there".
Unread 01-07-2013, 17:50
Mr. 1033's Avatar
Team Role: Coach
Can you guys show some sample code?
When I say "its random" I mean when they enter autonomous mode sometimes the robot moves correctly, other times it never stops moving, sometimes it moves the opposite direction, and sometimes it barely moves.
Many of my teams use LabView and they always include a "reset encoder" module block before and after every move forward segment of code.
I'd love to iron out these issues and be able to communicate them back to other coaches who are also frustrated about it.
Has anyone used the IR sensors attached to the prototype board rather than the IR sensor from hitechnic?
Unread 01-07-2013, 18:01
AKA: Henry Lei
I don't have access to LabView or RobotC currently but the pseudo-code should be:
Code:
reset encoder;
while (encoder<some_value) //assuming positive is forward
  motors go forward;
motors stop;
All of the possibilities above might be related to an encoder problem except moving in the opposite direction. Referring to the pseudo-code above, the motors only go one way (forward). If your teams and other teams are using built-in functions or blocks, then it might be possible that the "block" is not setup correctly (like negative encoder count is forward but a positive encoder count is used hence never reaching the value).
The code above has no feedback control and with a reliable reasonable drivetrain, it should consistently be +/- 1 in. per 2 feet.
Unread 01-07-2013, 18:27
Mr. 1033's Avatar
Team Role: Coach
Ok. I'll see if the robot c team have the same in their code.
Is there any way to get more precise/repetitive than +/- 1in per 2 feet?
Unread 01-07-2013, 20:23
AKA: Henry Lei
Yes. Usually with the aid of software feedback control with the famous example being PID. However, just tuning and maximizing the consistency of the drivetrain, battery power, and having a ramping up / down function (to minimize slippage / skid) will be significantly easier and beneficial overall as it will help not only autonomous but also tele-op performances.
Also, in most scenarios +/- 1 in. is more than enough since the field usually have different elements (such as taped lines / walls / IR sensor) to "reset" the robot. With "advanced" implementation techniques (such as mounting the IR sensor on a servo, having multiple IR sensor from different angles, etc.) the IR sensor can be extremely beneficial; even just directly polling from the IR sensor and drive till a certain value is reached is accurate, as long as there is a shield to block out ambient light.
