Go to Post It would also level the playing field by bringing the bottom up, rather than the top down. - russell [more]
Unread 11-07-2013, 18:54
mkaa00x's Avatar
mkaa00x mkaa00x is offline
Momo
AKA: Mohammad Al-Ahdal
FRC #4627 (Iron Manning)
Team Role: RoboCoach
Rookie Year: 2012
mkaa00x is an unknown quantity at this point
Electrical Quick release after motor controller?
Okay hey guys, so I have this question.
Is it legal to have a quick release after the motor controller, but before a motor so that you could separate/sever the electrical connection quickly. The same quick release used to connect the circuit breaker and the PD Board to the battery.
Something like this:
http://www.ceautoelectricsupply.com/vhcconnectors.html
Unread 11-07-2013, 18:57
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: Electrical Quick release after motor controller?
Many teams use Anderson connectors for this all time. 45/30 amp powerpoles work well and are much smaller and designed for 10/12 awg wire unlike most connectors for the large anderson connectors that we use on the batteries.
Powerwerx and Allied Electronics both carry them along with a host of other vendors.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 11-07-2013, 18:59
jbsmithtx's Avatar
jbsmithtx jbsmithtx is offline
FIRST Fanatic
AKA: Josh Smith
FRC #4206 (RoboVikes)
Rookie Year: 2012
jbsmithtx is a jewel in the roughjbsmithtx is a jewel in the roughjbsmithtx is a jewel in the rough
According to current rules, yes you can, but there could be a reason as to why they may change this in the future...
R49
Branch circuits may include intermediate elements such as COTS connectors, splices, COTS flexible/rolling/sliding contacts, and COTS slip rings, as long as the entire electrical pathway is via appropriately gauged/rated elements.
Unread 11-07-2013, 21:56
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
Rookie Year: 2013
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
My team did have quick disconnects this year. The only problem we had was that sometimes they would wiggle themselves out just enough to not work. It wasn't a huge deal but it was just an extra thing to think about before every match.
Unread 11-07-2013, 22:24
Engineering Coach
Team Role: Coach
Zip ties, or if you want to get fancy they sell clips to prevent this.
Unread 12-07-2013, 07:38
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Some type of connector is recommended to allow fast replacement of damaged or defective sub-assemblies. As pointed out the Anderson 30 and 45 amp connectors are one of the best ways to do this. However, a simple design where the speed controller is mounted near the motor works well. Quick connects on the controller itself, allow shorter motor wiring and less opportunity for failures. We use 1/4" spade connectors on the controllers and Andersons if we can't position the controller and motor close to each other.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-07-2013, 11:29
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
CHS Robotics used (pretty sure we still are) the Molex .093" series wire to wire connectors for interconnects between the PDB and the Motor Controller, and the Motor Controller and the Motor. These were only for the lower amperage circuits (20 amp max on a connect specc'd for 15 amps). We used a set of Anderson PowerPoles with a 30 amp rating for the 40 amp circuits (but we had some problems with failure of the solder joints. Possibly consider getting the actual crimper for the 45 amp contacts, or switching to a different connector, possibly a Molex).
At university, we use the XT90/60 and Deans T-connectors for high amperage circuits (75+ amps). The nice thing about these connectors is that they are actually fairly small, do not tend to come out easily, and very robust. Bad thing is they can't be panel mounted. Also, the Deans connectors are not the safest of connectors (unshrouded male pins).
One thing you should do is design your system to be modular and, well, idiot-proof. If you package your entire control system (cRIO, breakouts/headers, and PDB) and place modular interconnects between everything (use wire-to-wire connects for power, and 0.1" headers to DB9/15/25), you have made a system very open to prototyping (just plug and play, quite literally), and setting up your system for competition is fairly simple. If you standardize your connectors to the type of circuit, i.e. a particular connector for 20A circuits, a particular connector for 10A circuits, a particular connector for 40A circuits, and a particular connector for 5V circuits (this one is key!!!), and you do this between the controller and power, then essentially an idiot (i.e. a rookie) could wire up your robot for you.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 12-07-2013, 14:31
saikiranra's Avatar
saikiranra saikiranra is offline
UCI
AKA: Saikiran Ramanan
FRC #3476 (Code Orange)
Rookie Year: 2011
saikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond reputesaikiranra has a reputation beyond repute
We always use Anderson Power Poles in the wire that connects a motor controller to a motor. They are reliable and fairly easy to crimp. This season, we also got the clips to go along with them, and they worked like a charm. In the past we have used zip ties too, however.
2014 - Current: Team 3476 Electronics, Programming, and Scouting Mentor
2011 - 2014: Team 696 Student and Drive Coach
Unread 12-07-2013, 15:11
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
You should double check what you're using... All connectors must be "appropriately gauged/rated", per R49, previously quoted. To me, that says that if you have a 20A breaker on a given line, any connectors in line with that breaker also need to be rated for a minimum of 20A. For 30A breakers, they should be rated for 30A or above, and for 40A breakers for 40A or above. With what you've suggested above, you are using connectors that are rated less than the breakers - as I read it, that violates the rules.
The crimper for the PowerPoles works really well, and i highly recommend it, although its not necessarily required. For the open PP connectors (shaped like a U), you can bend the tabs over carefully with a pair of pliers. Even with the crimper, though, I recommend everyone solder the terminals as well. So long as it is properly soldered, it'll never be coming apart. The key is to solder it properly... with people new to soldering, its very easy to get a cold solder joint and thus a weak connection that'll break off easily.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
Unread 12-07-2013, 22:44
caseybarisax14's Avatar
caseybarisax14 caseybarisax14 is offline
Electrical Team Leader
AKA: Casey
FRC #0587 (The Hedgehogs)
Team Role: Electrical
Rookie Year: 2012
caseybarisax14 is an unknown quantity at this point
Yes you came your team used them for all of your motor controllers
Unread 12-07-2013, 23:05
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Amazon is a good source for a lot of things, especially Amazon Supply(formerly known as Small Parts).
Here is the 100 pack we ordered a few weeks back. They also have smaller packs, 50 and 10.
I have seen other teams use different colors for each motor and motor controller for quick visible recognition of where the connections go.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 12-07-2013, 23:38
mkaa00x's Avatar
Momo
Rookie Year: 2012
Thanks once again! Okay so I've talked to my team's electronics guy and he'll be checking over this. Once again GOOD LUCK TO ALL TEAMS AND THANKS FOR THE HELP ^_^
Unread 13-07-2013, 06:29
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Ham radio operator and a boater here: I've been using Power Poles for years and I love them. Spend the money and buy the crimp tool. The crimp puts even mechanical pressure on the wire, and creates wire/crimp areas that are pressure tight. Even mechanical pressure means the crimp will not come off in abnormal use. Pressure tight means no corrosion at that point (Corrosion is bad on a boat).
They come in colors and the right sizes for the job. They give you the ability to do both "correct wire colors" and allow for final decision at the device. Case in point, swerve drives have two motors close to each other. The wires coming to them are black/red indicating power. But the Power poles are Black and Red and Black and Yellow, and they mate to the same colors on the motors. (Drive and steer)
On the boat I have lots of pairs of items. Port side gets black/red starboard side gets black / orange.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 13-07-2013, 20:17
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
We use the Anderson Powerpole connectors. If you do them right, they shouldn't come apart. However, we wrap tape around ours just to be safe.
If you were to put motor controllers that far out, wouldn't you have to make your PWM cables really long, too? We try to keep all of our wires short to minimize resistance/emf interference.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
  #15   Spotlight this post!
Unread 14-07-2013, 00:15
tim-tim's Avatar
AKA: Tim Miedzinski
We use this crimper and have not had any issues.
The RoboBees
