Go to Post Brandon, it's not an issue... but the fortune cookie thing that you get when you give someone rep is a little creepy... - Beth Sweet [more]
Unread 15-07-2013, 13:36
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
IRI Teams with a spare P60 gearbox?
Do any teams going to IRI happen to have an extra BaneBots P60 16:1 gearbox for 500 series motors, either with an unattached pinion or a legal motor already mounted?
We realized when getting our packing list together this weekend that we are out of spares. Worst case scenario, we will be able to run our collector with a 26:1 gearbox in the case of a failure (which we have found to be quite common with these gearboxes), but a 16:1 would be preferable. We are currently running it with a RS-550, but most of the legal motors that can mount would do. Based on our experience when ordering from BaneBots, we do not think there is any way they would get it to us in time.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 15-07-2013, 13:40
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Re: IRI Teams with a spare P60 gearbox?
I think we have one or two with a 550 mounted from last year. I'll check this afternoon.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 15-07-2013, 14:35
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
I will check our gearbox box (heh... gearboxbox) and try to bring one.
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-07-2013, 16:41
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
We have lots of 4:1 Banebots stuff packed with us. We should be able to help you out. I think I have a 2 stage housing but I can't say for sure.
Unread 15-07-2013, 16:43
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
At a minimum this should let them make a 20.4:1 gearbox (swap a 4:1 stage w/ the 26:1 gearbox) right?
Unread 15-07-2013, 16:47
Team Role: Teacher
Oh, right. Forgot they're the same housing. I'm sure we have two 4:1 stages, so it should be good.
Unread 15-07-2013, 16:56
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I believe we have a 20:1 with a 550 mounted on it. If so I'll have our team toss it in with the rest of the stuff in case you need it.
Unread 15-07-2013, 17:48
Engineering Coach
Team Role: Coach
Found it, it will be packed up with our stuff. Stop by our Pit Thursday or Friday.
Name:	2013-07-15 16.45.34.jpg
Unread 16-07-2013, 00:03
AKA: Carl Springli
Rookie Year: 2010
Thanks everyone! We will be sure to stop by you pits on Thursday or Friday, Allen.
Adam, the only complication I can think of with constructing a 20.4:1 from available parts is replacing the sun gear from the carrier to match the "wrong" size of the next stage, but it seems doable. Certainly wouldn't be a bad way to go if we had time and were stuck between a rock and a hard place. Anyone have experience with that on BB planetaries? See everyone in a few more days!
Unread 16-07-2013, 14:29
AdamHeard's Avatar
Lead Mentor
Good Catch, with only single stage 4:1's you'd be missing the sun/carrier for a 4:1.
Unread 16-07-2013, 15:14
AKA: Carl Springli
Rookie Year: 2010
We may actually still have a good sun/carrier. The failure we see is a completely galled first stage reduction. The motor pinion and the gears it meshes with get destroyed. More than once this season I was able to combine the innards of multiple 16:1 gearboxes to make a new one. Of course by this point the motor was toast and we would need to attach a new pinion to a new motor anyway. The condition of the ring gear where it meshes with the first stage varies quite a bit though depending on how bad the galling got. The problem is that we can hardly notice it until the gearbox is completely seized.
One of our mentors looked at one of the failures and his immediate reaction was that there was no way the gears were cold-rolled, they must have been powder sintered because of the way there was metal powder everywhere in the gearbox. The cross section of the exposed inner surfaces of the gears also appears very non-uniform and grainy.
I've been doing research on other options for planetary gearboxes and we will likely be working with the VexPro Versa Planetaries in the future.
Unread 16-07-2013, 15:18
MechEng83's Avatar
MechEng83 MechEng83 is offline
Lead Mentor/Engineer
AKA: Mr. Cool
FRC #1741 (Red Alert)
Team Role: Coach
Rookie Year: 2011
MechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond reputeMechEng83 has a reputation beyond repute
To transition between a 5:1 and 4:1 stage, you need a special carrier/sun gear that goes from the 5:1 planet spacing to the 4:1 sun gear size. There are actually 5 different carriers for the P60 gear box.
- 4:1 planets to output (required for last stage)
- 5:1 planets to output (required for last stage)
- 4:1 planets to 4:1 sun
- 5:1 planets to 5:1 sun
- 5:1 planets to 4:1 sun
http://banebots.com/c/P60P-CP
Incidentally, if you have mixed 4:1 and 5:1 stages, all the 5:1 stages must appear first in the gear box (nearest the motor), meaning you need to have an input motor with the 5:1 sun gear.
2016 INWLA GP| INWCH Entrepreneurship | INPMH DCA | INCMP Team Spirit | CAGE Match Winner (w/ 1747 &868), Finalist (1471 w/ 1529 & 1018), Best Fans
2015 ININD Judges Award, Proud "Phyxed Red Card" alliance partners of 1529 & 1720 | INWLA EI | INCMP GP
2014 Boilermaker Creativity | Chesapeake Finalist, Safety, GP, Entrepreneurship | IN State Championship Winner (w/ 868 & 1018) | CAGE Match Winner (w/ 1024, 5402 & 1646)
2013 Boilermaker RCA, Innovation in Controls, Finalist | Crossroads Entrepreneurship | Newton Semi-finalist
2012 Boilermaker Entrepreneurship | Queen City EI | Curie Semi-finalist
2011 Boilermaker RCA, Entrepreneurship
Red Alert Robotics
Unread 16-07-2013, 15:28
AKA: Carl Springli
Rookie Year: 2010
I understand that the 5:1 stage requires a specific carrier plate (and planet gears), but are you saying that the 4:1 sun gear can not be pressed into every variety of carrier plate that accommodates the previous 5:1 stage? There's a different carrier plate for pressing in a 5:1 sun gear vs. a 4:1 sun gear? That would be absurd. Why not have the 5:1 sun gear and the 4:1 sun gear with the same press fit geometry?
Unread 16-07-2013, 15:52
MechEng83's Avatar
AKA: Mr. Cool
Team Role: Coach
Rookie Year: 2011
Yes, I am saying that. I don't have access to the gearboxes until I get to our shop tonight to confirm, but I believe the carrier plates are different between the two. From what I recall, the sun gear in a carrier plate fits into a broached hole with the same number of teeth as the sun gear.
Red Alert Robotics
