Notes from an Inspector - Save some grief and read!
Posted by Mark Pierce at 03/09/2001 9:12 PM EST
Other on team #288, RoboDAWGS, from Grandville High School and X-Rite, Delphi, and others. I spent all of yesterday and part of today inspecting robots as part of the "Pit Tech Crew". Here are some common observations and recommendations for teams to get through the inspection process. I want to thank all the teams for their help and willingness to fix discrepencies. How to avoid common violations: Insulate battery terminals or other connections. Electrically isolate the light from the robot. Avoid tape as a fastener. It's OK for electrical insulation but looks tacky for holding things together. Use wire ties or other means to keep wires neat and orderly. Use the right size fuses and wires. Have a copy of your list of Small Parts Inc. items and cost. Although you may have submitted it electronically, you may have added things, or it may have gotten lost in the FIRST system. It helps to know what items are kit pieces and additional hardware as well. Students should know the electrical systems, pnuematics, and the parts usage of the system. Inspectors will ask them to explain these items. A wiring diagram or list showing fuse and wire sizes speeds things immensely, as would a piping diagram. Smooth out sharp edges. You don't want to break balls in competition and get penalized. Break one, no big deal, break two, there'll likely be some penalty. These are things we found repeatedly. I also recommend weigh in and inspecting sooner rather than later. Once you're assembled, checking size and weight early is better than waiting until after dinner. Even if you have to be re-inspected or re- weighed due to changes, you'll avoid finding yourselves 6 pounds overweight 15 minutes before the pits close. (Yes, that happened) I wish you the best of luck, wherever you next compete! |
| Drum Roll Please... | archiver | 2001 | 4 | 24-06-2002 00:59 |
