Go to Post ...regardless of anything that happens, there should be no booing at competitions, only cheers. True, many of us want to win, but in the end, all of us are working to expand FIRST and to promote the inspiration and recognition of science and technology through gracious professionalism. - Aignam [more]
Unread 23-07-2013, 12:30
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: 25# Sprockets
Originally Posted by Akash Rastogi View Post
I've been meaning to run plate sprockets and gears on a sponsor's laser, do you have experience with any pros/cons of having them waterjetted vs laser cut?
Thanks,
Akash
It really depends on the specific machine, and the knowledge of the person operating it.
First I'd say get some samples cut, and see for yourself. That trumps all advice I'm about to give.
We've had gearing water and laser cut on multiple different machines and different sponsors.
Most waterjets take a real quality hit on curved teeth as the cut is slowed down and excessive blowout seems to happen. The lower the toothcount, the more the teeth are curved. Even with this, pretty much every gear we've cut at 16DP or larger (including a 9T pinion) has run fine after some wear in. Our swerve also ran a 50T 20DP gear that ran fine.
When you get into huge gears, like the 300ish toothcount 24DP turret gear for Encore, the teeth are essentially straight and the smaller toothsize isn't really an issue.
Every waterjet gear we've cut has required some run/wear in, but has performed fine and lasted the season.
For Lasered gears, if they know how to run their machine right, you should get far better results that allow much more freedom in terms of small teeth and small toothcount. I did have one laser run that was just too gummed around the edges and was a total failure; this however was from a company that primarily worked in steel, and never worked on parts with fine detail.
As for sprockets, pretty much everything should work. For some waterjets you may want to artificially shrink the sprocket a few thou. Wear in will also be necessary (but can be done on the final vehicle of course) unless they are nicely tumbled or something. Laser should make beautiful sprockets.
In summary, we love it as a process. It's not the greatest method for small gears, and small teeth; but these are the easiest gears to cheaply get premade, so it isn't really an issue.
Unread 24-07-2013, 11:12
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
Re: 25# Sprockets
We routinely make our own #25 sprockets from 0.09" plate aluminum on the waterjet. 6061 works fine.
We also used custom sprockets in our drivetrain this season using the same process....no maintenance and no failures.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 24-07-2013, 11:17
Re: 25# Sprockets
Thanks for all the input and feedback!
One more item: Would the heat from the laser make the teeth brittle or anything?
Unread 24-07-2013, 11:55
nathan_hui nathan_hui is offline
AKA: Nathan Hui
FRC #2473 (CHS Robotics)
nathan_hui will become famous soon enoughnathan_hui will become famous soon enough
Send a message via AIM to nathan_hui
Re: 25# Sprockets
If anything, should anneal the metal, unless you quench the part after fabrication.
Nathan Hui
B.S. Electrical Engineering, UCSD '16
FRC 2473 (CHS Robotics), Team Captain '12
FTC 4950, 6038
Unread 24-07-2013, 12:07
AdamHeard's Avatar
Lead Mentor
Re: 25# Sprockets
Don't take this as fact. I would wager it anneals the material, but I've heard that if the settings are correct it can locally harden.
I'd ask the shop to be sure.
Unread 24-07-2013, 12:17
Re: 25# Sprockets
Will do!
Thanks,
Akash
Unread 22-07-2013, 17:37
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Rookie Year: 2010
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: 25# Sprockets
As mentioned above, most teams don't do it due to the fact that AM (and similar) sprockets are so readily available and cheap. I am sure, however, that there are a few teams out there that do it just for giggles.
It is relatively light on the design process. Drawings for the sprockets are readily available online from various sources. Drawings can also be done easily with a tool in inventor (don't ask me how, but I've seen it done).
Once you have your design, you have to choose your manufacturing process. A popular method is to use a waterjet to cut them out of a sheet of 6061 aluminum that is .125 of an inch thick. I prefer the waterjet idea as it allows you to make a lot of them at one time and minimizes machine time.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
