Go to Post I still believe that if we are legitimately trying to make FRC be recognized as a real sport, then the GDC must treat it like one. - Jim Zondag [more]
Go Back   Chief Delphi > Other > Chit-Chat > Games/Trivia > Fantasy FIRST
  #316   Spotlight this post!
Unread 23-11-2013, 18:49
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: [FF]: 2014 Season Long Fantasy FIRST
Originally Posted by EricH View Post
FYI, I may need to suspend San Diego mid-draft. Something's come up. If suspended, it'll be for about 3 hours, hopefully less.
Yep, suspended. Still waiting on lists from Awesome Blossom and Prestige Taco. If you've got live picks to make and all slots ahead of you are full, make 'em; otherwise, the list folks have priority when I get back.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
  #317   Spotlight this post!
Unread 23-11-2013, 19:10
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Just made our first pick live. Working out the rest of our list. Plans kinda fell through...
(Team Awesome Blossom)
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
  #318   Spotlight this post!
Unread 23-11-2013, 22:11
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
San Diego, both tiers, is live once again. Gimme a couple minutes to get caught up, then we'll roll. If you're live-drafting, and I see a team member on Chief, I'll shoot a PM once I hit your spot--you'll have 5 minutes to get a response in before you get random.
Past teams:
  #319   Spotlight this post!
Unread 23-11-2013, 23:08
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
My apologies for having to suspend the San Diego draft tonight, and thanks for your patience with getting the draft going again.
As some consolation, the setup portion of the draft-running program is now uploaded to CD-Media. Be sure to enable your macros and load your lists--and I expect you guys to try and break it a bit.
http://www.chiefdelphi.com/media/papers/2881
Past teams:
  #320   Spotlight this post!
Unread 24-11-2013, 01:31
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
First instance of a break--Mars_James found a bug, and anybody else who downloaded it probably needs to go get the new version that was just uploaded to the same place. Unless you like having a lot of extra tiers floating around, that is.
Past teams:
  #321   Spotlight this post!
Unread 24-11-2013, 09:31
Koko Ed's Avatar
Koko Ed Koko Ed is offline
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Crossroads Randomized Rankings
447
4521
3147
4103
4085
3266
2199
1108
3959
2360
2197
1014
4306
2252
3947
3559
4008
2171
2338
3010
3494
4070
4269
4283
4690
144
829
4926
461
1024
71
128
291
234
48
5188
537
868
1038
1018
3940
  #322   Spotlight this post!
Unread 24-11-2013, 12:13
Basel A's Avatar
Basel A Basel A is offline
It's pronounced Basl with a soft s
AKA: @BaselThe2nd
FRC #3322 (Eagle Imperium)
Basel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond reputeBasel A has a reputation beyond repute
My VBA skills are very limited at best, but you can set up macros to run whenever certain cells are changed, so you can use that to change the format of a cell from time to integer (and to trigger rebuilding the remaining teams list).
Team 2337 | 2009-2012 | Student
Team 3322 | 2014-Present | College Student
“Be excellent in everything you do and the results will just happen.”
-Paul Copioli
  #323   Spotlight this post!
Unread 24-11-2013, 12:19
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
You got more knowledge on that than I do--I didn't know you could set 'em up to run on a change. I'll have to set up a format-change macro next (I'm actually planning on setting up a clear function to empty out a draft, but changing format ought to be pretty simple).
BTW, if anybody does decide to look at the macros--be advised, they're kind of a mess, though I *think* I left enough comments to follow what I was doing. When I've got it fully functional, I'll have to go in and try to clean up a little.
Past teams:
  #324   Spotlight this post!
Unread 24-11-2013, 13:48
MARS_James's Avatar
MARS_James MARS_James is offline
Always Scouting
AKA: James Comstock
FRC #0179 (The Children of The Swamp)
MARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond reputeMARS_James has a reputation beyond repute
Send a message via AIM to MARS_James
UNH Randoms:
1761
213
4793
1247
1058
4034
319
1512
348
3451
4555
3323
4925
2084
501
1073
58
3585
4546
3499
1289
4042
1307
131
176
4958
151
5265
3236
3597
3467
5286
509
166
69
2713
126
3479
Lists I need:
Deus X
Breakfast Company
Schrodinger's Cats
Prestige Tacos
Driving Record: 24-8
Coaching Record: 66-31
2014 South Florida Regional Woodie Flowers Finalist
  #325   Spotlight this post!
Unread 24-11-2013, 20:27
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
UPDATE
November 25 Northern Lights, Lake Superior
November 26 Central Valley, Kettering
November 27 Hub City, Gull Lake
November 29 Orlando, Oregon City
November 30 North Carolina, Glacier Peak
December 1 Mexico City, WPI
December 2 Dallas, Escanaba
December 3 Utah, Howell
December 4 Kansas City, Springside
December 5 St. Louis, Eastern Washington
December 6 Tech Valley, Mount Vernon
December 7 Wisconsin, Clifton
December 8 Boilermaker, West Michigan
December 9 Montreal, Waterloo
December 10 Arizona, Wilsonville
December 11 Los Angeles, Rhode Island
December 12 Virginia, Shorewood
December 13 Hawaii, Seneca
December 14 Greater Pittsburgh, Northeastern
December 15 FLR, Long Island
December 16 Washington DC, Livona
December 17 North Bay, Traverse City
December 18 North Star, 10000 Lakes
December 19 Peachtree, St. Joseph
December 20 Queen City, Auburn
December 21 Oklahoma, Central Washington
December 22 Smoky Mountains, Hartford
December 23 SVR, Bridgewater-Raritan
December 24 Israel, Troy
December 26 South Florida, Bedford
December 27 Colorado, Pine Tree
December 28 Bayou, Southington
December 29 Chesepeake, Oregon State University
December 30 NYC, Buckeye
January 1 Lone Star, Sacramento
January 2 Western Canadian
January 3 Windsor Essex
January 4 Las Vegas
  #326   Spotlight this post!
Unread 24-11-2013, 20:52
MARS_James's Avatar
Always Scouting
AKA: James Comstock
Re: UPDATE
January 4 Las Vegas
I see no change, and Great Lakes is full at 30 so it should go on the schedule now. And waterford is at 13 slots out of 20 so it should go on as well (though if it doesn't grow we will need 5 tiers)
  #327   Spotlight this post!
Unread 25-11-2013, 02:28
Brandon_L Brandon_L is offline
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
For the shortage of draft runners, I'm available fridays+weekends usually. During the week, just a select few nights. If you guys need someone and I'm around, I'll run one.
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
  #328   Spotlight this post!
Unread 25-11-2013, 08:10
PayneTrain's Avatar
PayneTrain PayneTrain is offline
Q&A Dartboard Detractor
AKA: Lizard King
FRC #0422 (The Meme Tech Pneumatic Devices)
Team Role: Mascot
PayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond reputePayneTrain has a reputation beyond repute
If needed, I can run a few drafts that fall between December 1st and December 9th.
  #329   Spotlight this post!
Unread 25-11-2013, 10:31
BrennanB's Avatar
BrennanB BrennanB is offline
TBC is good at getting almost first
AKA: Brennan Bibic
FRC #4476 (W.A.F.F.L.E.S.)
BrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond reputeBrennanB has a reputation beyond repute
I might try my hand at running a draft as well if you need it... It sounds moderately fun.
Brennan Bibic - @b_bibic - Eh-Nalysis
10 years of inspiration compilation - W.A.F.F.L.E.S. #4476 YouTube Channel - 64 events and counting!
FRC 2013-2017 (W.A.F.F.L.E.S. Community Robotics #4476) - FLL 2006-2017 (W.A.F.F.L.E.S. #105) - VRC 2010-2013, 2015-2016 (W.A.F.F.L.E.S. #4476)
FRC 2009-2012 (K-Botics #2809)
Fantasy First 2014-2017 (The Breakfast Company) #TBCWin
2014 Dean's List Finalist
"Work until your idols become your rivals."
  #330   Spotlight this post!
Unread 25-11-2013, 17:03
Koko Ed's Avatar
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Lake Superior Randomized Rankings
2169
4663
4009
3755
2264
3294
3839
3828
3277
706
4818
3184
4511
3313
4539
2177
4054
1816
2977
4397
3054
4845
3102
2472
3278
2052
2526
3018
4217
3740
4230
3630
4011
3300
3788
4181
4207
3122
93
5143
4182
1714
3840
4986
3042
2499
3061
5290
2503
4228
5299
3883
