Go to Post Thank you to all of the mentors, You ARE changing the future. - chellyzee93 [more]
Unread 05-08-2013, 11:26
OWilliamson's Avatar
OWilliamson OWilliamson is offline
FRC #2594 (NASKCO)
Rookie Year: 2012
OWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of lightOWilliamson is a glorious beacon of light
pic: Don't Let the Frame Rust...
Unread 05-08-2013, 11:28
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: pic: Don't Let the Frame Rust...
For future reference on rust removal: Evapo Rust is magical. It works, it is non-toxic, it doesn't make dust/fumes, and it's widely available.
http://www.evaporust.com/
On a side note, how much did that weigh?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 05-08-2013, 11:41
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
I second that 100% though it's kind of expensive considering I have about 20 gallons laying around at any one time.
20 gallons x $18 a gallon = quite a lot of concentrated potato juice (look up oxalic acid)
Just be careful not to put things with black oxide in it (it will remove it).
Dilluted 'wood bleach' also works but handle that stuff with care (unlike EvapoRust it is much more caustic).
Also you might consider sand blasting or using an 'air eraser' on it.
Planning on powder coating it?
Unread 05-08-2013, 12:17
FRC #2594 (NASKCO)
Rookie Year: 2012
Thanks for the suggestions, I'll keep it in mind in case we ever have this issue again.
It ended up weighing about 32 pounds, it was actually a little lighter than we were expecting. It was all made out of steel tubing and sheet metal, because it was easier to weld together and we had access to a bunch of it.
And yes we are planning on powdercoating it, we figure if we do that and add some LEDs our bot will look a lot prettier for demos
2015: Utah Regional - Quarter-Finalists (3374 & 4158)
2014: Utah Regional - Semi-Finalists (1619 & 399)
2013: Utah Regional - Quarter-Finalists (1332 & 3562)
2012: Utah Regional
Unread 06-08-2013, 16:43
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
It is indeed expensive, though there are ways of maximizing it's utility. I have used it successfully by soaking a rag or towel with it and draping that over a part. At the end, just squeeze as much as you can back into a container. It helps to have the edges of the rag/towel submerged in fresh evaporust.
Unread 06-08-2013, 19:59
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
You can also use vinegar, or sodium carbonate and a power supply. Did a whole lathe that way.
Unread 07-08-2013, 14:41
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Rookie Year: 2011
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Sand blaster makes quick work on things like that heh.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 10-08-2013, 23:27
Camren's Avatar
Camren Camren is offline
Mentor
FRC #3081 (RoBoEaGleS)
Rookie Year: 2011
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
I have to agree a good bead blaster is all a iron clad robot needs.
