Go to Post I have also emailed Dean Kamen for more information regarding our team and its future, as I may have confused myself a bit. - ExcuseBoy [more]
Unread 06-08-2013, 14:20
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Re: pic: 3CIM Ball Shifter
Originally Posted by Andrew Schreiber View Post
33 Ran an autoshift in '04 with their 4 speed. The the whitepaper is http://www.chiefdelphi.com/media/papers/1580 but it doesn't go into much detail on the shift algorithm. I'm sure Jim has/would describe it somewhere.
They're not out here
Unread 06-08-2013, 16:14
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Our 11 code has the full implementation of it (for a 2-speed), but the code is a bit messy and I would implement it differently now. It's drivetrain/autotrans.vi. Upshift was enabled (and the driver feedback was all good), both downshifts were disabled due to driver feedback (Specifically he would rely on coasting into the peg with a tube, and the coast down would throw off his maneuvering as he was slowing down). Better calibration could have likely improved this.
The logic is fairly simple. We do three types of shifts:
Upshifts
Coast down shifts
Kick down shifts
Acceleration should be multiplied by the sign of velocity (or the abs of velocity should be used to calculate acceleration) to normalize for changes in direction.
Upshifts are based on thresholds for speed (greater than), abs of avg of throttles (for skid steer - this is pre-halo and culver drives) (greater than), vehicle acceleration (greater than), abs of diff of throttles (less than) (not turning)
Coast down shifts are based on absolute low speed (~2fps).
Kick downs are based on speed (we used 8 fps, which is higher than redline in low) (less than), abs of avg of throttles (greater than), not turning, vehicle acceleration negative and less than calibration (large negative number).
Upshift handles normal upshift driving.
Coast down shifts back when the vehicle speed is close to zero so it can upshift again at he next launch.
Kick down shifts down when you hit something and need to push.
This algorithm worked well enough for FRC. The corner cases (when turning) are simply ignored by the autoshifter, which was 'good enough'. We also impose a minimum time between shifts to prevent gear hunting, most automatic shift implementations see this and our solution is a 500ms inhibit timer.
Kettering Motorsports
Unread 06-08-2013, 15:12
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Originally Posted by apalrd View Post
I guess this differs from the 'west coast' opinion that 'high gear is where we operate, and low gear is just in case we need to push'. We operate in both gears.
These are design philosophy issues. Sometimes your design philosophy leaves every day performance on the table. Airplanes could be a lot lighter (and more efficient) if they weren't good for a very very very very bad day.
Something else I think is important for many teams to consider is that there is a driver in the loop. Even if your slow gear is Killer Bees fast, if you're driver isn't up to snuff you will spend lots of time monkeying around when you could have been scoring. I still think one of the best things FIRST could do to improve game play is make the default speed of the kitbot slower. You see lots of operators that really just don't have the practice to be efficient at top speed.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 06-08-2013, 22:16
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Originally Posted by AdamHeard View Post
We use it in the same way, and then also use it for thins like balancing on the bridge last year.
For how our drivers operate, I view low gear as insurance that lets you gear as fast as you desire for other objectives, but still have a drive mode where you won't get destroyed by defense (tripping breakers, etc...)
Because of this, we love a real slow low gear.
Agreed. Maybe this is just a west coast perspective, but in my mind a slow gear gives you the ability to have a super fast top speed (15+ fps as some west coast teams like to have). A low gear is only used when you're in a pushing match, or positioning accurately such as in autonomous, which isn't all that often. I personally don't see much point at having a low gear being lower than traction limited, which is about 6fps for a 4 CIM drive.
Part of this may (and I'm speaking with a complete lack of emperical evidence here) be because of a slight efficiency advantage of WCDs over "east coast drives." Most non-WCDs I've seen have more places where power can be lost (gears, more chain reductions, 35 chain vs 25 chain, etc). West coast drives have as little as two reductions down to a wheel, and typically have either 25 chain or belts to transmit power to outside wheels. Non-WCDs on the other hand are usually based off AM shifters, which require at least three reductions for the power to release the wheels to reach the wheels. Perhaps this small added efficiency lets west coast accelerate slightly more quickly in high gear.
I know I just threw out a bunch of stuff which I really can't prove and don't 100% believe is true, stuff that I would usually not post. But, given the apparent difference between east coast and west coast perspectives here, I wanted to propose a theory that might explain some of the differences.
In terms of 6 CIM vs 4 CIM drives, I'd say 6 CIMs is nice but not really necessary. You'll accelerate better, be faster and more powerful, but there are real drawbacks. One is current draw, which detracts from other mechanisms and can trip the main breaker. The other, as Karthik pointed out, is that it takes away from your ability to have CIMs power other mechanisms.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 15-08-2013, 15:13
evanperryg's Avatar
evanperryg evanperryg is offline
IT'S THE BUMP N' DUMP
AKA: Evan Grove
FRC #4536 (The Minutebots)
Rookie Year: 2011
evanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond reputeevanperryg has a reputation beyond repute
Originally Posted by Andrew Lawrence View Post
I love the 3-CIM shifter, but the ratio is terrible. 17 ft/s is a great high gear for 3 CIMs, and 5 ft/s is a great low gear for 3 CIMs, but speeds of 9-12 fps low or high gear don't benefit much from the extra CIM.
The problem with having such an insanely high gear is that the robot will be very hard to control. Another issue with such a huge difference in gearing is momentum. This year, my team used AM supershifters at 5/12fps. If we we were in high gear then switched to low at full speed, we would tip over 75-80% of the time. Imagine how bad it would be going between 17 and 5.
I'm pretty sure 111 did a 3-speed this year. Also, how could 4 speeds possibly be beneficial, even as an autoshift?
FRCDesigns Contributor | "There is only one corner of the universe you can be certain of improving, and that's your own self." -Aldous Huxley
2012-2016 | FRC Team 2338: Gear it Forward
2013
Wisconsin Regional Winner 2014 Midwest Regional Finalist 2015 Midwest Regional Chairman's Award, Finalist, Archimedes Division Champion, IRI Semifinalist 2016 Midwest Regional Chairman's Award, Finalist, Archimedes Division Gracious Professionalism Award, R2OC Winner
2015 | FTC Team 10266: Mach Speed
2015
Highland Park Qualifier Winner, Motivate Award
2017-???? | FRC Team 4536: The Minutebots
Thanks to the alliances and friends I've made along the way: 33 74 107 111 167 171 234 548 1023 1089 1323 1625 1675 1732 1756 2064 2077 2122 2202 2358 2451 2512 2826 3936 3996 4039 4085 4241 5006 5401 5568 5847 5934
Unread 15-08-2013, 15:22
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Back then we had a lot less power, to get reasonable acceleration and still have a high top speed was hard.
Unread 15-08-2013, 15:42
apalrd's Avatar
More Torque!
VRC #3333
We didn't want a 4 speed, we wanted a 3 speed. We wanted a fast and very fast gear, like our current design goals for high and low, but we had less power, so we needed a low low for pushing (remember this is back before bumpers) and couldn't get away with the fast-low we like now.
But, with the resources we had, it was easier to build a 4 speed than a 3 speed (since we end up with 2 2-speeds in series). The shift patterns are then low/low,low/high,high/low,high/high, with a different ratio spread of each of the 2-speeds in series. But the 2-3 shift (going from low/high to high/low) requires a double-swap shift which is just plain nasty to execute synchronously between two shifters while under power. A possible solution is to run it like a 3-speed with two options for 2nd gear, and essentially jump-shift past the 2-3 shift. This would add complexity to the shift scheduler, although more than 2 speeds already adds complexity to our shift scheduler.
A ball shifter design can do any number of speeds just by adding more gear pairs to the shafts, so it's possible to do a 3-speed instead of a 4-speed, but it's much harder to manufacture than the dual 2-speed with andymark parts or dual 2-speed mesh shifter design (or even the dual 2-speed ball shifter).
So 4 speeds was easier to build, but the 2-3 shift is bad.
Unread 15-08-2013, 15:54
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
For reference, 222 has been running a 3-speed ball shifter since 2004.
http://www.chiefdelphi.com/media/papers/1539
Unread 15-08-2013, 15:56
Data Nerd
FRC #0079
Rookie Year: 2000
I thought they'd gone to just running 2 speeds as of late?
Unread 16-08-2013, 12:55
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
This is correct. We only ran 3 speeds in 2004. We didn't find the added complexity and weight to be worth the added gear ratio.
2013 was the first season since 2004 that we haven't made our own transmissions. This season we went with the vexpro ball shifter and will likely use them again in the future FWIW.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 15-08-2013, 15:32
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Their initial design goal was 3(+) speeds, but the method they chose allowed for 4 speeds just as easy as 3. Essentially, each shifting mechanism they incorporated doubled the potential ratios. One mechanism would be two speeds, two mechanisms allows for four potential speeds. If they added a third, it would be 8 speeds. Rather than try to explain it in greater detail myself, I'll simply use the wonderful resource they posted on the gearbox (with nice pictures that explain it better than any amount of paragraphs ever could).
Unread 15-08-2013, 15:36
AlecMataloni AlecMataloni is offline
Excellence is Bliss
FRC #0111 (WildStang)
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
We used the COTS two-speed ball shifters from Vex this year. Nothing too fancy.
Unread 06-08-2013, 12:02
Aren_Hill's Avatar
Aren_Hill Aren_Hill is offline
Build Nifty Things
Aren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond reputeAren_Hill has a reputation beyond repute
Originally Posted by cad321 View Post
Quick bit of advice, it is probably good form (on both the ball shifter and dog gear setups), to put your third reduction after the shifting shaft.
This method can be seen on the Ball Shifter with optional 3rd stage, and the AndyMark Sonic/Super Shifters.
This lowers the overall torque being transferred by the shifting components, which results in less chance of failure and lower required shifting forces.
See this thread for once instance of failure: http://www.chiefdelphi.com/forums/sh...ght=20+carnage
Doing this would also allow you to make your gearbox overall shorter as you can offset the last output shaft in whichever direction you like.
A guy who likes robots.
1625->3928->148->1296->971 oh dear
Unread 06-08-2013, 12:19
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I have another question. Why bother with a 6-CIM, 2-speed drivetrain at all? It seems like a lot of resources to invest in only marginal gains over either a 4-CIM, 2-speed or 6-CIM single speed.
  #15   Spotlight this post!
Unread 06-08-2013, 13:21
Unsung FIRST Hero
Karthik Karthik is offline
VEX Robotics GDC Chairman
Rookie Year: 1998
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Something very important that also needs to be considered is what is the opportunity cost of those two extra CIMs. The concept of opportunity cost is invaluable in making effective strategic designs decisions, especially when it comes to resource allocation.
Here's a Kahn Academy lesson that does a great job of explaining opportunity cost. A bit more detailed than is needed for these purposes, especially in terms of the PPF, but hey at worst you're going to learn some extra stuff.
https://www.khanacademy.org/science/...?v=pkEiHZAtoro
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
