Thread Tools |
Rating:
Display Modes |
Re: NI Week Athena Announcement and Q&A Panel
I expect that the cRio will not be considered part of the legal control system starting in 2015. That doesn't stop you from using it on a practice bot, just like teams used the old IFI control system for non-competition robots after the cRio came out.
-Every day I work in Simulink, I'm like 'man this is a big subsystem, I should zoom in' and then I zoom in. And then later I zoom out. AND THEN I GO BACK TO LABVIEW AND CANT ZOOM. @everyone, Thoughts on the new controller: -I think the expansion port is great for packaging, and allows plenty of additional IO, but I think it's going to be JUST that - a place where you can plug in a break out board to use the additional PWM/GPIO/ADC signals when you need them. I don't think more than a few teams will actually make something else for this port. Maybe a company or two, but basically no teams. --I'm not worried about enough IO, but a few more ADC's would be nice for extra datalogging. Buzz18 uses 5 of 7 and Buzz 17 used 6 of 7, and it's nice to look at other analog signals every now and then. I also wonder if the 5v/3.3v supply is monitored by the ADC separately because we like to look at that for diagnostics, and previously used a jumper in adc7 to do this, which consumes an analog channel. -The spec lists integrated 3-axis accelerometer. I wonder why they didn't include a gyro on this, since a gyro is definitely a way more useful sensor for FRC. I have never found a use for a chassis-mounted accelerometer in FRC. -No spec on boot times as far as I can tell. Dissappointing. The radio issue demonstrated by 2468 almost made a joke out of the current boot times. -OS is listed as RT Linux, which will definitely make some people very happy, but I don't really care that much. I still think we're brute-forcing the CPU loading issues rather than considering efficient design in quite a few places (outside of user code). -Hopefully the download times improved. They were just purely awful this year. I know that was because of a LV RT bug, but it's still totally unacceptable in every way that it made it past testing like that. -Maybe if I can get one early enough it'll push me to design something better. Who knows. But releasing software on kickoff is just crazy, I mean we really do have to install LV and new Driver Station and new Utilities on a whole bunch of computers, and there isn't even anything game related in a new version of software. I too would like to see the new controller and software in my hand at least 6mos before 2015 kickoff. |
Cross the Road Electronics is also going to have a CAN pneumatic device that will take care of the Compressor, Pressure Switch and 8 solenoids (12v OR 24v not both). http://i.imgur.com/276hmyB.jpg Pneumatic Controller from IRI 2013 -Clinton- |
Also, teams can use single acting Solenoids and reduce the number of outputs needed. As long as they are comfortable with having a default state of their cylinder, that will actuate at the end of the match or loss of comms. The CTRE device is replacing the current solenoid module that has 8 outputs, but allows for easier (and less weight) expansion of more outputs. -Clinton- |
Q&A Starting!
From the Q&A, there will be an expansion port for your own electronics/more analog inputs.
#10
#11
Kate won't say whether the roboRIO is even allowed for 2015.
#12
Driving pneumatics off a spike is doable, but really doesn't make any sense in this era. The CAN based pneumatics bumper would presumably allow effectively unlimited for FRC sake. Also, no way 236 used more than 8 solenoids for that motion. I just don't see enough going on for that. |
#13
Also, I feel like the 500% increase in processing power was a bit unnecessary, but it's going to be cool to work with a dual core ARM Cortex processor. Looking at the spec sheet, we can now use both ethernet and USB connected cameras, but their is no use listed for the USB device port. Some questions: -Do we have a jumper for the 6V servo power? -The spec sheet lists specs for both a 5V and 3.3V supplies. Where are they, and can we use them? The old DSC had two extra pins for the 5V supply next to the DIO, but I don't see a way to get 5V from here without using one +5 pins on a DIO. -How do we know which of the pins in the "custom electronics" connector do which things? -The picture of the pcb shows a 5V/3.3V selection jumper, but it can't be seen from the new pictures. What does this select? |
#14
There aren't any jumper ports... I hope we won't need a separate board for them.
#15
