Tank Drive Without a Microcontroller
If you didn't want to use a microcontroller, is it possible to make a tank drive such that it was directly wired to potentiometers?
Re: Tank Drive Without a Microcontroller
It certainly seems feasible, assuming you can get a linear response out of the pots. The one difficulty I'd see is controlling it remotely, but even that might be doable with some model airplane electronics.
Sure just use a microprocessor without integrated peripherals
![]() Need to watch your terminology here. I wonder if digital logic is outside your request or just integrated computing. You can build analog speed controls. They can be adjusted with potentiometers. They can recieve from various radio modulations. I have done it before for non-FIRST application. An analog speed control can still pulse the motor like the FIRST speed controls. So an analog speed control need not be resistive or linear to the motor. However analog speed controls suffer from temperature and noise limits (drift). Thermistors help with temperature but only to a point. It is entirely possible to fly an actual plane with analog electronics. If integrated circuits are still allowed within your scope it is even easier and smaller. Then you have tiny operational amplifiers. If digital logic is allowed take a good look at the 555 timer. I won a contest in highschool driving hobby servos without their board using 558 IC. I only implemented a single joystick then but I could have made 2. You can drive a PWM input with merely simple timers like the 555 using PWM. It is possible you just need to tinker a bit. See Analog Systems: http://en.m.wikipedia.org/wiki/Fly-by-wire Last edited by techhelpbb : 10-08-2013 at 09:20. |
If you are planning to control motors like CIMs, you will need to use a speed controller like a victor or a jaguar. If you want to generate the pwm signal without using a microcontroller, you will need a 555 timer. Team 358 has a schematic for a circuit that can control a victor here. You could use this to control your victors.
All the FIRST approved motor controllers have microcontrollers in them.
The circuit to drive a DC brush motor like the CIMs with pulsed power is an analog/digital chopper. Circuits without microcontrollers existed for decades. Motor control chopper (generic term) come in time (like PWM) or current/voltage control. Current/voltage control choppers have a wider range of speeds with good torque. Complexity and wasted energy tends to increase for current/voltage choppers. It is unclear exactly what is being looked for in this topic. Like Ether wrote if you have a high power resistor/potentiometer/rheostat you can make this work. However a chopper circuit is better with larger motors. The pulsing dramatically impacts the waste heat. You can make a relatively small speed control for a CIM sized motor without a microcontroller. I did it for wheelchairs. Just consider that all features require more parts. Last edited by techhelpbb : 10-08-2013 at 11:47. |
1. As has been said, you can't control a Jaguar, Victor, or Talon directly with a potentiometer.
2. There are other COTS speed controllers (not FIRST-legal) that accept analog input. I've used the Sabertooth series in personal projects before and have been happy with them. Some models from this series accept analog input, and there are models that can switch up to 60A per motor channel. You can get them on Trossen Robotics or Robot Shop 3. If you want a remote-controlled system that requires no programming, that's entirely possible. The PWM signal that Jaguars, Victors, and Talons accept is a standard signal type outputted by many (if not most) hobby RC systems. 4. If you're looking to easily test your speed controllers without the need for a microcontroller, AndyMark has a product for that, or you can build your own version, as has been said. Last edited by RyanCahoon : 10-08-2013 at 22:08. Reason: Added links for Sabertooth controllers, fixed AndyMark link |
Yes a little unclear, but a servo tester may fit the bill?
http://www.andymark.com/product-p/am-2503.htm We have a few that we picked up at a hobby shop for less than $10 each, but they don't seem to run a jag or a victor to full speed, but perfectly fine for testing systems. The AM one started last year, and may be calibrated to the motor controllers, as opposed to the hobby servos? Or maybe you get what you pay for? |
Did you make sure to re-calibrate the Jag (I haven't used a victor before so I am unsure as to what is necessary for them). If you go on the vex website they provide documentation on how to re-calibrate the Jag for different pulse width ranges. We had the same issue where the Jag would only put out 50% power when we used a servo controller on a test board we built. Once we re-calibrated the Jag with that servo controller it worked perfectly. Just make sure that you re-calibrate the Jag once it goes back on the robot.
An old junker laptop makes an ideal PWM generator for testing. All you need is some software and a cheap diode and resistor. You can adjust the PWM period and the max pulse width. http://www.chiefdelphi.com/media/papers/2702 |
#10
Depending on the size of the motors you want to use and how you reduce the speed you could use spike relays, which would not require a micro to control them. This of course would cause the motors to either be full speed in fwd/rev or stopped, but if your robots full speed was something manageable like maybe 4ft per second that is totally plausible. All you would need is 5 volt inputs to the spikes which could easily come from buttons or other non-micro related circuitry. I have built a few robots like this. Tank drive is achieved but speed control is not desired.
#12
A hobby RC radio is ideal here, it even has multiple channels for other systems.
V-tail mixing is the same as arcade drive. AndyMark now stocks a popular and affordable chinese model. |
#14
It's not clear what you are asking. What are you proposing to directly wire the potentiometers to? In principle you could wire a pot directly to a DC brushed motor (like a CIM), but in practice it would have to be a very heavy duty pot, and it would waste a lot of battery power (and get hot). Wiring a pot directly to a Talon or Jag or Vic would not work. These devices require a PWM input signal, not a DC voltage.. |
#15
I think we'd appreciate a bit more context. Are you asking for a project you had in mind, or are you just curious about alternative motor controllers?
