Go to Post That's for us to know, and you to lose sleep over finding out! - Austin [more]
  #16   Spotlight this post!
Unread 13-08-2013, 14:59
T^2 T^2 is offline
FRC #5499
Rookie Year: 2011
T^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond reputeT^2 has a reputation beyond repute
Re: Urethane Wheels Run off Cim Motor
Originally Posted by craigboez View Post
Has anyone attempted to use these 4" urethane wheels as drive wheels? At $30 each it would be an expensive setup, but they appear to be similar to Colsons but with a higher CoF.
They stretch a lot. You might have to mold your own urethane tread around an aluminum or plastic rim that doesn't buckle. (I think 118 does this? Not sure.)
  #17   Spotlight this post!
Unread 14-08-2013, 04:01
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Yep. They actually do a custom wheel mold too.
Just tread a wheel or buy one. Its much easier, and the wheels that are out there are already great solutions for drivetrains.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
  #18   Spotlight this post!
Unread 20-08-2013, 00:54
whophil whophil is offline
whophil is an unknown quantity at this point
Colson makes a lot of wheels in addition to the "Performa" line sold cheaply at RobotMarketplace.
Colson has a line of polyurethane-tread wheels molded over aluminum, polyolefin, and cast iron cores. You can see the specs for these wheels here:
http://www.colsoncaster.com/products...e/default.aspx
I found some 6" polyurethane on polyolefin wheels on eBay for about $10 apiece.
I can't comment on the construction and concentricity of these wheels as I haven't received them yet, but if you ask me again in a few weeks I should have an answer for you.
  #19   Spotlight this post!
Unread 20-08-2013, 12:08
Chris is me's Avatar
AKA: Pinecone
There's a lot more that goes into whether or not a wheel is good for frisbee shooting than "does it use polyurethane"? Polyurethane varies widely in durometer (hardness), thickness, etc. The blue McMaster polyurethane wheels used by many teams this year have a very thick polyurethane layer (seemingly over an inch of polyurethane) bonded to a metal hub / core. Many wheels (Colsons I believe) have a much thinner polyurethane tread molded over a plastic core. Your mileage may vary.
While Gregor's suggestion was somewhat snide, if you do not have the machining capability to make a simple press-fit hub, these wheels really aren't the best option for your team. Investing in several of the Blue Banebots rubber "poverty" wheels would probably be more beneficial. Do note that despite being the same durometer, the Banebots wheels have drastically different wear characteristics than the McMaster wheels, and they need to be changed out over time.
  #20   Spotlight this post!
Unread 20-08-2013, 12:15
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Unless price is a huge driving factor (and it being so late in season, concerns over wear become smaller) the mcmaster urethane wheels are mounted incredibly easy with the style hub I recommended.
If you're trying to be cheap and fast, can't argue with the poverty wheels for a single offseason event if you're not going to practice much going into it.
  #21   Spotlight this post!
Unread 20-08-2013, 12:17
Hey, since when did we start calling them poverty wheels?
Relevant note, we've found a few machining sponsors in Walter's (LedLove96) area. We'll have them up and running with new resources soon
  #22   Spotlight this post!
Unread 20-08-2013, 12:20
AdamHeard's Avatar
Lead Mentor
Relevant note, we've found a few machining sponsors in Walter's area. We'll have them up and running with new resources soon
I was hassling 330 and 1717 at the LA regional for their poverty wheels, I guess it stuck after that.
Luckily they both switched to respectable wheels after that event.
  #23   Spotlight this post!
Unread 20-08-2013, 22:21
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Rookie Year: 2010
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
It is true. while we are going to be using the "poverty wheels" for club fair and a demo coming up, we hope to have hooked up with a sponsor and have some hubs machined by the Cow Town Throw Down. While a single off-season event will not be worth the wheels, the sponsorship gained just might,
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
  #24   Spotlight this post!
Unread 20-08-2013, 22:37
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
Seeing as I'm on the team that first made these wheels popular, I will say that there are better options. However, giving them a name like this may stop a lot of teams from using them and potentially stopping them from making themselves better. Let's not let this get too far out of hand. Also, seeing as Banebots have been a long time sponsor of FIRST I doubt they want any of there products referred to like this. I completely get the joke and would probably make it myself but once it gets out in to the community in can have many negative effects.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
  #25   Spotlight this post!
Unread 20-08-2013, 22:55
AdamHeard's Avatar
Lead Mentor
I can agree with all points made except their reputation.
Sponsoring FIRST doesn't mean their poor product and quality control should just be ignored.
