Go to Post Evolution is innovation. - Chris is me [more]
Unread 23-08-2013, 18:54
Pault's Avatar
Pault Pault is offline
FRC #0246 (Overclocked)
Rookie Year: 2012
Pault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond reputePault has a reputation beyond repute
Re: 6 wheel holonomic drive feasibility
Originally Posted by ekapalka View Post
I'm getting the feeling that you have something against mecanum wheels... well, to each his own We have plenty of drivetrains that work, and even more people who know how to use them. Teams that decide to use mecanum wheels have to start somewhere, right?
My opinion (and I think his opinion, and the opinion of many people on this forum) is that just because you can build a mechanum drive doesn't mean you should. Maybe your team thinks differently, and thats perfectly fine. But the point was that the resources you put into a mecanum drive would be better spent on improving either your tank drives (no tank drive is perfect, there is always room for improvement) or the other mechanisms on your robot. Again, thats an opinion, and like you said, to each his own.
If you have want your robot to have pushing power, mecanum is definitely a terrible choice (this is an opinion backed by a lot of evidence). The are drivetrains out there that can give you omnidirectional movement and pushing power (swerve, octocanum, and probably some other rare ones), but only the best teams (think IRI caliber) are able to make one without devoting nearly all their resources to it. Generally, unless your strategy to play a certain year's game revolves completely around omnidirectional movement with pushing power, you should just stick with tank drive (or mecanum if you really insist). (I'm addicted to parenthesis (like, really addicted)).
Unread 23-08-2013, 19:49
Nate Laverdure's Avatar
Nate Laverdure Nate Laverdure is offline
FRC #2363
Team Role: Coach
Rookie Year: 1999
Nate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond reputeNate Laverdure has a reputation beyond repute
Now is the perfect time to build a mecanum drivetrain. Your experience may differ, but I couldn't understand mecanum's bad reputation until I built my own version and saw firsthand how the drivetrain's actual behavior differed from the way I'd imagined the system would behave. If you get it done in the next 4 months, you'll be able to carry all of your "lessons learned" into the 2014 build season.
Unread 24-08-2013, 10:45
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
Mecanum wheels are a wonderful exercise and learning experience for a team. If you guys want to experiment with them I say go for it.
When it comes to winning matches however, remember that the game should decide what type of drive you use, a mecanum drive might not match the game. We have done it once with great results and I could see them being very helpful in one other season I have participated in, that's 2 out of 9 seasons for me.
Unread 24-08-2013, 13:44
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Which two games? I assume 2011 is one of them.
Unread 23-08-2013, 09:29
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
What I was wondering is how to control the center wheels so as to not conflict with the mecanum wheels while still providing pushing power.
You could do it with independent drive of all 6 wheels (i.e. 6 drive motors, one for each wheel). Control the mec wheel speeds as you normally would (i.e. based on standard mec inverse kinematics), and control the omni wheel speeds based on inverse kinematics of the FWD and ROT command components.
I doubt whether this will provide much (or even any) benefit compared to standard 4-wheel mec though.
Unread 23-08-2013, 10:09
ekapalka's Avatar
ekapalka ekapalka is offline
FRC #3216
ekapalka has a spectacular aura aboutekapalka has a spectacular aura about
That's exactly what I was trying to say :) So you don't think encoders will be necessary? Why would it not add any pushing power?
Unread 23-08-2013, 11:11
Ether's Avatar
Rookie Year: 1969
I purposely worded it the way I did:
Control the mec wheel speeds as you normally would (i.e. based on standard mec inverse kinematics), and control the omni wheel speeds based on...
To control the wheel speeds properly requires an encoder on each wheel. But you could probably make it work somewhat using open-loop voltage control.
If you custom-made the center omni wheels using high-traction treaded rollers there might be a small difference. Seems like an awful lot of time, expense, and effort when there are better ways to achieve increased pushing force.
Unread 23-08-2013, 12:20
ekapalka's Avatar
FRC #3216
thanks
Unread 23-08-2013, 12:28
Ether's Avatar
Rookie Year: 1969
my apologies
Just to be clear:
All caps is considered shouting.
Bold is not considered shouting. I bolded it for context only.
No offense was taken, and no apology required.
(I went back and edited the prior post to remove the bold, lest my intent be misunderstood)
Unread 23-08-2013, 11:15
Racer26 Racer26 is offline
Racer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond reputeRacer26 has a reputation beyond repute
1114 has published a fantastic paper on the economics of drive-base selection for different teams.
Drivetrain Selection (or: Why every team should build a tank.)
Unread 23-08-2013, 11:23
Ether's Avatar
Rookie Year: 1969
A good resource. The comments about programming mec and omni seem somewhat dated.
