Re: Designing sheet metal parts in CAD
As Jesse said, most CAD programs have a sheet metal tool or part type. In Creo/ProE when you select that you're making a part (rather than an assembly, drawing, etc.) you can select to do a sheetmetal part rather than a solid part. You'll then model the part in it's 3D, bent form.
Assuming you have a sponsor doing the laser-cutting and bending, make sure you find out how they like getting the part files... whether .pdfs of the drawings, STEP or .dxf files, or a proprietary CAD file type. Also, find out what material thicknesses they stock or prefer... and what their preferred bend radii are. The sponsor that has often made sheet metal parts for us (but only infrequently bent) has a wide variety of sheet metal thickness (.050, .063, .083, .100, .125) but they only do bend radii in the multiples of a sixteenth. So, even though the standard is for the bend radius to be the material thickness, for our .100 parts we had to use a .125 bend radius.
In general, you can actually use a surprisingly thin piece of sheet metal as long as you take care to use bends and such as you should. You should rarely need to go over .083 for anything with bends... even AL5052-H32 plate (a relatively weak aluminum that is often preferred for bending) with a thickness of .100 or .125 has a surprising amount of rigidity to it. For a drivebase or other "high-strength" situation it wouldn't hurt to use .083; however, for most other situations .050 or .063 should be fine... as long as bends or stiffeners (angle, standoffs, etc.) are in place.
Feel free to post screenshots or CAD of your sheetmetal parts up here... we'll be glad to help give you tips before you send designs to be made.
"If you want to build a ship, don't drum up men to gather wood, divide the work, or give orders. Instead, teach them to yearn for the vast and endless sea." - Antoine de Saint-Exupery
"The fight is won or lost far away from witnesses - behind the lines, in the gym, and out there on the road, long before I dance under those lights." - Muhammad Ali
"Simplicity is the ultimate sophistication." - Leonardo da Vinci
Student: 2006-2010 (#1519)
Mentor: 2011-Present (#1519)
