Go to Post It shows more than anything, that there are students out there that want to learn, to do better, to improve their own lives and those around them. Thankfully, FIRST is there to help them realize some of their goals. - Al Skierkiewicz [more]
Unread 28-08-2013, 19:10
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Some basic Pneumatic Design Questions
Hello Everyone,
My team has recently started exploring in pnematics and we have some basic questions:
1) How do we determine how many tanks we will need if we don't want to carry a compressor? I know we can calculate how much air the system will use depending on how many times we fire, but is it that simple?
2) When CADing, how do you go about working in the cylinders into your design? Are there specific models? Do you just take the stroke of the cylinder and adhere all designs to that?
Thanks,
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 28-08-2013, 19:41
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Some basic Pneumatic Design Questions
1)It is a smart choice not to carry a compressor,
If you keep the pressure above 60 psi, the answer is simple and as you have explained. Once the pressure in the storage tanks goes below the regulator pressure, the relationship is no longer linear. I will let someone else get into it because I am not sure how to calculate it.
2) There are two kinds of motions you can get from pneumatics; linear or some curve using a linkage.
When designing, I like to make the best estimate I can as to how long a cylinder I can use. Then, I will often use one that is a bit longer.
When designing linearly remember that you can adjust how far the cylinder retracts easily by adding a spacer to the piston. Adjusting how far the cylinder extends takes a new mounting system.
For linkages:
Design the system so that you can mount the cylinder in many different places. A hole pattern spaced ~ .375 inches can do this nicely. And remember that you can restrict retraction with a spacer too.
One other note on linkages,
When the cylinder is perpendicular to the lever arm, you are generating the most torque. Anywhere less than perpendicular is generating less than the max possible torque. This is a good thing to keep in mind when you are designing clamps and wrist joints.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 28-08-2013, 20:07
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Warning: Oversimplification. If you're just shifting a few times a match, and you have 3-4 tanks, that's a good choice. If, OTOH, you happen to have a long-throw or large-bore (or both ) piston firing a grabbing device dozens of times a match, on top of shifting and maybe an endgame pneumatic, you're going to run out of air pretty quickly unless you have a massive amount of tanks. In that case, you probably want to carry a couple fewer tanks and a compressor.
Don't forget using rotary pneumatics. Those are legal under 2013 rules, IIRC.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 28-08-2013, 20:20
DonRotolo's Avatar
Back to humble
FRC #0832
1. It's that simple. 2 cubic inches of air at 60 PSI = 1 cu in of air at 120 PSI.
Step 1 is to determine the throw of the cylinder you need. Round up to the nearest inch - it is easy to limit throw, but it can't easily be increased
Step 2 is to determine how much force you need. 60 PSI acting against 1 square inch (or piston area) gives 60 lbs of force (approx, there are friction losses). Use the smallest bore you can, since it uses least air. Note a larger bore can deliver more force, or the same force if the pressure is lower.
Step 3 is to Find the cubic inches at your given pressure. a cylinder with a 1 square inch piston that is 5 inches long uses 5 cubic inches.
Step 4 is to guess how many times you will actuate the cylinder. Extend and Retract are each "one time".
Cubic inches * # of actuations = air needed. Multiply by (output pressure / storage pressure) (usually 60 and 120) and that's how much storage you need "theoretically". (Tanks have a cubic inch capacity specified) In reality, pressure drops as you draw against it, so it becomes a differential equation... So just round up and add a tank, empirically it will be close. Then test.
Unread 28-08-2013, 21:25
Sunny
Rookie Year: 2007
So, suppose a piston uses 1 cubic inch of air, and is fired thirty time. As per your math, it would be:
1 cu in * 30 actuations * (60 output psi / 120 psi) ~> 15 cu inches of "theoretical" storage?
And as far as the design question is concerned, my question, which I now understand was slightly misleading, was more in regards to CADing the piston.
Are there nice models with the appropriate motion constraints built in, or do people just model in a pole and restrict its range of motion?
Thanks,
- Sunny G.
1648: 2013-2014
5283: 2015
Unread 28-08-2013, 21:37
DampRobot's Avatar
DampRobot DampRobot is offline
Physics Major
AKA: Roger Romani
FRC #0100 (The Wildhats) and FRC#971 (Spartan Robotics)
Rookie Year: 2010
DampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond reputeDampRobot has a reputation beyond repute
Thanks,
- Sunny G.
There are definitely some. Check the Bimba website. Usually, when you import them as a .step, you have to add in the motion constraints yourself.
The mind is not a vessel to be filled, but a fire to be lighted.
-Plutarch
Unread 28-08-2013, 21:41
Michael Hill's Avatar
Michael Hill Michael Hill is offline
FRC #3138 (Innovators Robotics)
Michael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond reputeMichael Hill has a reputation beyond repute
Actually, Bimba has a really cool CAD generator that can hook into your CAD software and watch it be made in front of your eyes. I can't recall if motion constraints are placed or not.
Unread 28-08-2013, 21:51
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
<up on soapbox>
Please they are not called pistons they are called cylinders.
<off of soapbox>
Unread 28-08-2013, 21:59
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Rookie Year: 2010
But would "wow so cylinder" look as good in our shooter?
-Plutarch
Unread 28-08-2013, 23:20
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Keep in mind the difference between gauge and absolute pressure, and your calculations will work out pretty well (or they have for us in the past). 60 psi gauge pressure is 74.7 psi actual pressure, and 120 psi gauge pressure is 134.7 psi actual pressure. This means each cu. in. of storage air corresponds to roughly 1.8 cu. in. of air in max working pressure. Another source of error in these calculations is assuming that the air is behaving as an ideal gas, but this is close enough for determining the number of storage tanks needed on an FRC robot, especially considering it makes sense to include a safety factor anyway.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 29-08-2013, 08:21
tr6scott's Avatar
tr6scott tr6scott is offline
Um, I smell Motor!
AKA: Scott McBride
FRC #2137 (TORC)
tr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond reputetr6scott has a reputation beyond repute
A couple of finer details to consider.
If you are working with the constraints of only using tanks, remember you have to feed the cylinder on both the extend and retract if it is a repetitive motion. In these situations, it may be favorable to look at cylinder that has a spring to return for one of the motions, so you don't have to supply air from the tank to return the cylinder.
Also there is what is called rod end of the cylinder. This is the side the working arm attaches to the piston in the cylinder. The working area on the rod end, is the area of the cylinder bore, less the area of the rod bore. So the rod end has less force at the same psi. Also the volume of air is less on the rod end of the cylinder.
The sooner we get behind schedule, the more time we have to catch up.
Unread 28-08-2013, 21:45
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
This is how we calculate air needs, but we usually multiply by 2, which would mean (using the simplified linear model) that you end the match with full working pressure, so that your actuators don't lose force. Basically this also becomes a safety factor - you can continue using the system for more actuations if necessary, but the force will reduce with continued usage.
We pretty much exclusively use Bimba cylinders - between the free product voucher in the KoP and the fact that McMaster carries them. Bimba has configurable CAD models of all their cylinders on their site.
If you use the Direct Insert method (which controls your Solidworks/Inventor/ProE remotely using a Java app and effectively generates the part on the fly) I think it may add the constraints. (It's been a while since I've used it, though, so I may be wrong.)
The Direct Insert process takes quite a while on my computer, so I usually opt for the STEP file download. STEP files don't have constrains, but if I need motion simulation, then I group the parts into either two subassemblies: cylinder and piston, then apply a single constraint to enforce axial motion.
I use Inventor - if you use Solidworks or ProE, it looks like there are application-specific formats which may include constrains.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
Unread 29-08-2013, 12:36
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
Rookie Year: 2011
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Actually, you are not guaranteed to get a Bimba from McMaster-Carr. We have gotten several non-Bimba (but compatible) cylinders from them in the past two years.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 28-08-2013, 21:58
DonRotolo's Avatar
Back to humble
FRC #0832
Yes. That 15 in^3 would drop to zero if it remained at 120 PSI until the last actuation. In reality, it would drop about 4 PSI (1/30 * 120) each actuation, so after 15 actuations your storage pressure would be 60 PSI. You can do the math to see where you'll end up. Ryan's "double it" is reasonable.
Be sure to take into account all leaks, which can be non-trival. Also, storage is often not at 120, but a bit less.
An AndyMark AM-2478 ($15) is 30 in^3, weighs 0.56 pound, two of those puppies will keep you moving 1 in^3 well above 30 actuations. On the other hand, a 12" cylinder with a 2" bore would work maybe twice at full pressure.
  #15   Spotlight this post!
Unread 29-08-2013, 09:45
Sunny
Rookie Year: 2007
In the drop calculations, I'm assuming that the 4 PSI is dependent on the cylinder size? Or is that more of a rough constant?
- Sunny G.
1648: 2013-2014
5283: 2015
