Go to Post CD, you are crazy!!! - Tottanka [more]
View Poll Results:
0%
Voters: 0. You may not vote on this poll
Thread Tools Rating: Thread Rating: 16 votes, 4.94 average. Display Modes
Unread 21-11-2013, 01:05
Vupa's Avatar
Vupa Vupa is offline
Mentor & Alumni
AKA: Alex Vu
FRC #4334 (Alberta Tech Alliance), FRC #6082 (Calgary Tech Coalition)
Rookie Year: 2013
Vupa is on a distinguished road
Re: 3d printers and robots
Thanks for all the great suggestions guys! I have been looking at all the options ya'll have supplied and am still deciding. Great news though, my budget bracket has now been upped to around the $2500.00 thus the range of 3d printers the team can afford is now slightly higher.
I started a little bit of my own research and came up with two possible, albeit poorly informed results. The TAZ 3d printer by LulzBot and the Replicator 2 by Makerbot. If anyone has more information on these models and whether or not they're worth their price please inform me. Also more suggestions are absolutely welcome.
Thanks!
Unread 21-11-2013, 07:39
protoserge's Avatar
protoserge protoserge is offline
CAD, machining, circuits, fun!
AKA: Some call me... Tim?
FRC #0365 (MOE) & former 836 Mentor)
protoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond reputeprotoserge has a reputation beyond repute
Thanks!
I would say that you can spend $1600 on a great pre-assembled printer (that just works) like the Up! Plus 2 (with auto bed leveling probe) and buy or build a second printer with the additional $900. Having two printers is better than one very expensive printer for a number of reasons, including: print speed, production capacity, and reliability/redundancy.
I am a fan of the Open Source Hardware projects, as the support is plentiful on the web and the systems can be modified/repaired with ease. The Prusa is a great printer and is available in several derivations. Also look at the Mendel series. You can get a kit and assemble it or use the RepRap wiki parts lists and accumulate the parts piecemeal.
Is filament covered in the $2500 budget? I'd expect to budget $300 a year on filament, including PLA/ABS and a variety of exotics (Nylon, Polycarbonate, High Impact Polystyrene, Carbon Fiber PLA etc.). Do you have access to an oven? Some filaments have short shelf lives once opened before they need to be baked for several hours to remove absorbed water.
Unread 21-11-2013, 09:58
techhelpbb's Avatar
techhelpbb techhelpbb is offline
FRC #0011 (MORT - Team 11)
Rookie Year: 1997
techhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond reputetechhelpbb has a reputation beyond repute
What Stinglikeabee said plus:
Please be aware that the MakerBot Replicator 2 prints PLA. MakerBot's PLA. Not ABS. Do not extrude anything else unless you want to deal with the MakerCare support issue your group is opening the door to. MakerCare is not a warranty. It's parts replacement agreement you can only use once you precisely follow the directions MakerBot provides you. Those directions can take many hours to follow and there are no estimates for the durations of any of the repairs.
The extruder assembly is several hundred dollars on the Replicator 2.
It's very possible for other extruders to be half that cost.
If the extruder does not work you are not printing anything.
So if you really have issues with the MakerBot extruder expect to potentially be looking at $500 to entirely replace it.
The hot-end alone is around $200.
I can not recommend altering the extruder on the MakerBot because again you'll pretty much be throwing away your MakerCare and MakerCare alone costs $500. For that $500 you could build an entire printer. So if you have a MakerBot if you really want to use other materials then you should build another printer. Don't spoil the pot or else that printer you probably stretched to afford might just get even more expensive.
Keep in mind that this technology is quickly evolving. There are 4 extruder printer designs out there. There are filament mixing systems that can use a single extruder and hot-end with multiple filaments. Committing to whatever today's technology is might impact funding future opportunities for the next generation of printers which will come.
PLA is rigid but more brittle unlike ABS which is more flexible and for FRC part purposes ABS is more likely to survive bending without cracking on a wearable component (it wouldn't matter on say a decorative cover). Since there is a tolerance at work here you'd be better off with ABS flexing than PLA cracking unless you can glue the resulting damage easy enough.
Be aware that PLA better holds the dimensions of the print but if you are planning on acetone washing or sanding the part that's not relevant anyway (measure twice cut once).
There are lots of other filament materials for the RepRap style extruders. MakerBot sells lots of PLA filament colors.
Please keep in mind: generally 3D printing ABS/PLA is slow. Team 11 just printed a smartphone shaped item laying flat on the bed of their Replicator 2X. It is merely 3/8" tall and it took 2+ hours between setup, printing and cleanup. Going to make wheel hubs at 1" thick laying flat on the bed? The wheel hubs probably take up more surface area on the printer bed and are taller that that smartphone print. Consider the time involved and that it is probably not wise to leave a heated printer unattended. Going to move the printer if you run out of time? Then you need to consider that you are interrupting the print and risking the print quality plus if you move the printer you need to level it again. I know that if I need to print anything large I sleep next to the printer in a ventilated area with fire alarms and my phone alarm to wake me up every once in a while.
With delays like this owning a single printer might be someone's undoing.
I personally own a SoliDoodle 3 (RepRap style printer) and an Up! printer.
I use the SoliDoodle 3 (which I heavily modified) for most things.
I reserve the Up! for sensitive things or overflow production capacity.
I have parts for at least 7 Prusa printers laying about.
I support the idea that this technology should teach a person to fish. Not give them a fish.
I would rather my students learn to build a cheaper printer they can keep at home and use on their schedule:
than create consumers that know little about their printer than if I click >this< button it 'usually' works.
The promise of the RepRap project is a printer in every home for anyone that wants it.
To extend my last point: what impacts students more? A laptop they can do as they please with or a desktop at the school everyone is afraid they might break and there are 100 students in line to touch? This is about creativity and access to enable that creativity.
Unread 21-11-2013, 12:01
ebmonon36's Avatar
ebmonon36 ebmonon36 is offline
AKA: Eric Bredehoeft
FRC #1018 (Robodevils)
ebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud ofebmonon36 has much to be proud of
Send a message via AIM to ebmonon36
I think stinglikeabee and techhelpbb have covered what you need to look for.
As they said, this is a quickly evolving technology. I got my printer 7 months ago. Since then, I can think of at least 6 different materials that have been released. I knew I didn't want to lock myself into a single material. I wanted something that gave me options. There have also been many printers released since I received mine.
I have been running a Makergear M2 since last April and it has done very well for me. I purchased the kit version ($1475.00) and it was very easy to assemble. I had it up and running in about 6 hours. The hardware itself is very robust. Linear slides on the X and Y axis and a lead screw with guides on the Z axis. My only complaint so far is that the Z axis end stop is tricky to adjust. Once it was set, I haven't had a problem with it.
The hot-end is rated for temperatures up to 230 degrees C so it can print PLA and ABS and uses the same mount that many RepRaps use so it is possible to use third party hot-ends. I have purchased an all-metal hot-end from E3D which will allow me to print nylon, polycarbonate, and many other exotic materials (with proper ventilation). Makergear is also in the process of developing their own all-metal hot-end and dual extruders.
Support through email and the Makergear Google group seems to be very prompt, although I have not needed it yet. Their website can be lacking at times.
On the software side, I use Simplify3D to do the slicing of the .STL files (exported from Inventor) and generate the gcode. It also works with the open source software packages such as slic3r and pronterface. While there are default settings for the slicing, it is worth it to tweak them to see what each setting does. Some settings need to be adjusted depending on what you are printing.
Unread 21-11-2013, 13:51
Bald & Bearded Bald & Bearded is offline
Jack of All Trades/Master on none
FRC #1885 (ILITE Robotics)
Rookie Year: 2007
Bald & Bearded is on a distinguished road
First concur that multiple printers is a really good thing. Some prints can take hours.
On filament, PLA is likely too brittle for many robot applications.
ABS is most common.
If you are doing exotics you will really need an all metal hotend to get the temps you need. Check out the new exotic filaments project that is on Kickstarter.
Unread 01-12-2013, 22:34
protoserge's Avatar
I am cross-posting this on a couple threads for maximum visibility. Hopefully, someone needs a printer and at less-than-regular price!
11 AM Eastern tomorrow, Amazon.com will be selling this printer (Up! Plus 2) at a discount. It is presently listed at $1612, and I've seen it as low as $1599 regularly.
Unread 02-12-2013, 12:51
protoserge's Avatar
It is $1290!
Unread 02-12-2013, 13:40
techhelpbb's Avatar
Rookie Year: 1997
Posted another deal here:
http://www.chiefdelphi.com/forums/sh...=121433&page=7
Unread 02-12-2013, 14:45
Rohawk1's Avatar
Rohawk1 Rohawk1 is offline
MC and GA :D
AKA: Patrick Jung
FRC #3824 (RoHAWKtics)
Rookie Year: 2012
Rohawk1 will become famous soon enough
Last year, we integrated 3D printing into over half of our robot. With the privilege of working with Oak Ridge National Laboratory, our team had the chance to use incredibly strong plastic such as Ultem, and we also printed a couple parts out of titanium. For support, our robot mainly used woven carbon fiber to complete the frame of the drive train. Two years ago, we had the first all-printed robot, so our team is definitely experienced in the area of additive manufacturing. This year, we have various consumer printers such as the Cube and the MakerBot Replicators, and we plan to utilize these printers for various FIRST motors, brackets, etc. so we can show how versatile this technology is.
