Go to Post I think there is much to be learned from working in teams, and team projects, but even more when you go out on your own some time for something you are truly passionate about. - paul_v [more]
Unread 06-10-2013, 12:49
null's Avatar
null null is offline
Mentor, FLL West Side Sparkplugz
AKA: Zach M.
FRC #3525 (Nuts and Bolts of Fury)
Rookie Year: 2012
null is an unknown quantity at this point
Re: Programming Laptop Suggestions
High latency on your RAM could be an issue. Is every module of RAM in use of the same type and speed?
Unread 06-10-2013, 13:26
The issue was generally caused by bugs in the caching of compiled files. This resulted in several hundred VIs being compiled and saved back into the database. On slow machines, this can literally take minutes -- which is why there is a cache in the first place. A number of things were done to correct for slow builds, including adding in more thorough tests to measure the build and deploy time in various configurations.
Greg McKaskle
Unread 07-10-2013, 09:34
Invictus3593's Avatar
Invictus3593 Invictus3593 is offline
time you like wasting is not wasted
FRC #3593 (Team Invictus)
Team Role: Leadership
Rookie Year: 2010
Invictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really niceInvictus3593 is just really nice
Yeah, they're two kingston 8gb cards, then I guess there's an extra 4gb embedded on the mobo somewhere because we use both sodimm slots for our 8gb cards
Per Audacia Ad Astra
Unread 04-10-2013, 09:16
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Team Role: Coach
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
I just ordered one of these for programming in C. Note, however, that this one doesn't have a DVD drive. Oops - didn't realize that when I ordered it. It's super slim and light, though. I like a 15.6" screen as a compromise between longer battery life and big viewing size - this way we can use it more easily in the stands if we use laptops for scouting again. This one has a touch screen, which would be nice for scouting as well. I'll probably end up spending $40 on an external USB DVD drive.
http://www.newegg.com/Product/Produc...82E16834314085
I figure this thing should last five years pretty easily. It is currently way overpowered for what we would need to program either C or LabView. This laptop has an i5 and 6 GB of RAM and nothing special on graphics. That is exactly where I wanted to spend the bucks. I trust an i5 processor, but if I'd decided to research this more I might have gone with AMD as a way to save a few bucks (that model is $20 less) and possibly get longer battery life if AMD processors are still less energy hungry than Intel. Not sure if that is still true as I haven't researched AMD processors in years.
