Re: Opening up Battery Chargers?
It can be dangerous, depending on the implementation. There are really two items to consider:
1. What happens in the case of a short?
2. What happens with all the heat that is generated by the circuit board?
For 1, we built ours in wood box, which should prevent any real chance of getting shocked by a short. If you build yours in a metal box, you'd really want to be careful with this, especially since it's a box that'll move around a fair amount.
For 2, we built in plenty of air space around the chargers, and included filtered fans to help keep the area well ventilated.
And finally for both, there is a master off switch that will kill power to the entire cart, in the event of an emergency.
So, safety first! We've had the cart now through 3 seasons, and the only issue we've had was when one of the chargers managed to get itself unplugged, forcing us to open up the back to plug it back in. We also perform a maintenance check once each year to make sure everything still looks ok.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
