Go to Post Being a mentor doesn't have an age requirement. As long as you are positively influencing someone you could be called a mentor and a role model. - EricLeifermann [more]
Unread 28-11-2001, 19:46
Andrew Wyatt Andrew Wyatt is offline
#0524 (Alpha Omega Robotics)
Andrew Wyatt is an unknown quantity at this point
Send a message via AIM to Andrew Wyatt
Modular Control box assembly
we're working on a new design of control box that completely armors the computer and sub assemblies. The box will be an actual box with a lid, and the computer and assorted subassemblies will be mounted on removeable plexiglass cards.
now, we can't find suitable connectors for the application.
They need to be able to securely mounted to the cards, and take the current load.
There are only two tools you really need: duct tape and Wd40. if it moves and it shouldn't, use the tape. if it should move and doesn't, use the wd40.
Box Control Tton General Forum 2 12-02-2003 23:38
Image Discuss: Team 25 modular gearbox and modified wheel assembly CD47-Bot Robot Showcase 6 10-02-2003 20:02
control box size gail OCCRA 2 24-09-2002 05:30
control box archiver 2000 8 24-06-2002 00:20
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
