Go to Post If regolith ever makes a return, I will jump out of a window. - Oblarg [more]
Unread 15-09-2013, 09:36
GuyM142's Avatar
GuyM142 GuyM142 is offline
AKA: Guy
FRC #3339 (BumbleBee)
Rookie Year: 2012
GuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really niceGuyM142 is just really nice
Accelerometer doesn't work in robot project
When I first tried to use the kit accelerometer with the example it didn't work (with SPI).
Then I connected it with I2C and it worked (With the example).
But when I took the example to the robot project it started acting wierd,
The wiring is the same so it has nothing to do with it..
The problem is that on the begin the open vi of the accelerometer goes into infinite loop, I added a photo of it and the loop itself deep within the vi.
ID:	15212  Click image for larger version
ID:	15213  Click image for larger version
ID:	15214  Click image for larger version
Unread 15-09-2013, 14:38
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Accelerometer doesn't work in robot project
what else is in your begin?
Just to verify, you ran the example on your robot and everything was fine, it was only when you integrated it with the rest of your code that it failed.
Unread 15-09-2013, 19:59
GuyM142's Avatar
AKA: Guy
Rookie Year: 2012
Exactly, the example worked just fine.
And in the begin I have gyro, two joysticks, camera and drive motors.
2016-2017 - Programming Mentor
Curie Sub-Division Champions with 694, 379 & 1511
2015 - Team Captain & Head of Programming Crew
Carson Sub-Division Champions with 1325, 20 & 1711
First ever Israeli team on Einstein
2014 - Team Captain & Head of Programming Crew
2013 - Head of Programming Crew
2012 - Member of Programming Crew
Unread 16-09-2013, 09:22
Doug Norman's Avatar
Doug Norman Doug Norman is offline
no team (National Instruments)
Doug Norman will become famous soon enoughDoug Norman will become famous soon enough
A couple things to check:
1. In LabVIEW go to Help>>About FIRST Robotics Competition Software... and make sure you have Software Update 5.1.0. I think we may have made an I2C fix.
2. Open WPI_I2CRead.vi and check that the CompatibilityMode switch on the front panel is ON (I think this is the fix we made). If it is not, turn it on, and then right-click on the switch and choose Data Operations>>Make Current Value Default and then save the VI.
Doug Norman
