Go to Post There hasn't been an announcement to buy pool noodles yet. Considering that they are already out of stores in most of the country, draw whatever conclusion that you like. - Joe Ross [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 09-17-2013, 04:05 PM
JTN's Avatar
JTN JTN is offline
AKA: John Taylor Novak
FRC #0016 (Bomb Squad)
JTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond reputeJTN has a reputation beyond repute
Need Help With Sheet Metal Designing
I've become really interested in sheet metal designs over the years of watching FRC competitions and looking at the robots compete. This year I finally decided to start working on a CAD model for a swerve-compatible robot frame that is lighter, takes up less space (or takes up different space so we have more room inside), and more aesthetically pleasing than our current (and past) frames made of Item (similar to 80/20). At the moment we have no engineers who know much about sheet metal, but we do have CNC mills (I know they take a while) and the proper equipment to bend large quantities of metal. What I need help with is how to actually design a frame and/or components and how to attach the parts together. So far all I have been able to come up with in terms of attaching parts is this: https://docs.google.com/file/d/0B9fw...it?usp=sharing
(Sorry for URL instead of direct image. Still have to figure that out.)
All help is appreciated. Thanks!
They say I can't use a URL or BB code, so I'll use this for my signature.
Unread 09-17-2013, 04:25 PM
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Need Help With Sheet Metal Designing
I'd recommend taking a look at how 971 does their style of sheetmetal.
https://picasaweb.google.com/1177698...ingProgramming
https://picasaweb.google.com/117769834305511597729
They do a very unique hybrid of sheetmetal and tube design (which might be better suited if you do have access to a CNC mill and some bending)
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 09-17-2013, 09:38 PM
JTN's Avatar
JTN JTN is offline
Thanks for the reply. The pictures help a lot. Sorry for the late reply, I was coaching my FTC team after school.
Unread 09-18-2013, 02:28 AM
Travis Schuh Travis Schuh is offline
FRC #0971 (Spartan Robotics)
Rookie Year: 1999
Travis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant futureTravis Schuh has a brilliant future
Attachment methods vary based on what to parts you are trying to join. The trick is to use geometry to give you strength. Imagine you are making the parts out of paper (or even mock them up in paper), and go through the thought exercise of how they will hold up to different forces.
On the picture you have attached, I would at least overlap the two top flanges and add rivets there so that you have more than just the bend resistance of the metal keeping the parts at right angles to each other. Based on the strength needed, you might add more reinforcing features, but overlapping the flanges is a cheap and easy thing to do.
-Travis
Unread 09-18-2013, 03:28 AM
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
JT, We just started using sheet metal last season. We have a laser cutter sponsor so it's easier for us than it will be with you and the mill (remember to fillet your corners to the size of your end mills).
Here is the presentation I put together for the team last season when we decided to start doing this. It's definitely not complete and I was learning at the same time so I don't make any promises that is all correct but it will get you started.
https://www.dropbox.com/s/63ke4hzitw...t%20Metal.pptx
I would also recommend looking at the CAD files and robots from teams that do sheet metal well, 33, 148, 228, 1114, etc.
My favorite is still 148's 2011 Robot Raptor. I have a whole presentation that I go over with the team that is just on this robot.
Here is an interesting read on doing different types of 2D manufacturing (sheet metal, CNC routing, etc) for building things . http://www.instructables.com/id/How-...y-Really-Fast/.
Also go back through and read the threads on other people's designs. Some really smart people, give really helpful advice. Here are a few of the recent threads. 1114 Inspired Chasssis, 488 Fall Project 1 and 2, Sheet Metal Drivetrain Prototype and there are many more like it.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 09-18-2013, 04:20 AM
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I'd recommend filleting the corners to larger than the size of the end mills, even if just by a little.
Unread 09-18-2013, 11:20 AM
jspatz1's Avatar
jspatz1 jspatz1 is offline
AKA: Jeff
FRC #1986 (Team Titanium)
Rookie Year: 2007
jspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond reputejspatz1 has a reputation beyond repute
Send a message via AIM to jspatz1
JT, we've been doing sheet metal frames for 3 years now. Would be happy to send you those CAD models (Inventor) if you wanted them, along with info on assembly.
Unread 09-18-2013, 11:24 AM
JTN, I'm also available if you some sheet help.
Unread 09-18-2013, 05:30 PM
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
JTN,
The function of the part you are needing to attach is the driving force of the attachment method in the design. Let's list some methods to join sheet metal.
Permanent joins
  • Spot welding
  • Mig
  • Tig
  • Braze
  • Epoxy
Semi permanent
  • Pop rivet
  • Solid rivet
  • Tog-L-Loc
  • High bond adhesive tape
Temporary/Removable Joins
  • nut and screw
  • Screw and tap/thread
  • pem nuts
  • Pem studs
  • self tapping screws
  • drilling screws
  • Plastic connector
  • 1/4 turn fasteners
  • Riv-nut
Inter locking joins to position or fixture and increase strength, rigidity
  • mixture of tab and notch and hardware
  • dowel pins and holes
  • interlocking puzzle piece joint
  • Dual Lock
What do you think of our list? Did I miss anything?
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 09-18-2013, 10:52 PM
JTN's Avatar
JTN JTN is offline
Thanks for all the replies! Sorry I have not responded yet, I have a habit of forgetting to post... so I will reply to all the posts in one post.
Travis Schuh: Thanks for the tip, I was actually thinking about doing just that, but I'd have to see how I could get a CNC mill to mill those tight corners.
AllenGregoryIV: Yes! I have seen your robot, the sheet metal work looks fantastic! I really admired your robot last year. Thanks for all the great links, I will look into them when I don't have homework piled up... (tomorrow).
Sanddrag: Post taken into consideration, thanks for clarifying.
jspatz1: PM sent.
Akash Rastogi: I will send you an annoying amount of Facebook messages if the need arises, thanks for the offer.
Roystur44: I think we would most likely be using 3/16" rivets and screws. Your addition of dual lock at the end of the list intrigues me, I will look it up.
Thanks for all the great replies! I will work more on the CAD model tomorrow and post an improved corner!
Unread 09-18-2013, 11:32 PM
Chris is me's Avatar
AKA: Pinecone
It seems like your resources are multiple CNC mills + hand brakes to bend metal. Maybe it's just me, but it sounds like those are resources better suited to tube and plate based construction with bent sheet metal for specific parts rather than a full sheet metal robot. In a lot of cases you can make good, rigid, light structure in less time and about the same weight going that route. If you have a turret punch / laser cutter sponsor and precision bending equipment, sheet metal does get more attractive.
Unread 09-19-2013, 03:45 PM
JTN's Avatar
JTN JTN is offline
Improved joint: https://docs.google.com/file/d/0B9fw...it?usp=sharing
Unread 09-19-2013, 03:52 PM
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Originally Posted by JTN View Post
That bend will be hard (impossible maybe?) to get.
Rather, make the inside dimension of one rail match the outside dimension of the other rail.
Also, it looks like the two flanges on the left rail coming to a sharp corner with each other is a possible issue. Someone more knowledgeable in sheet working can clarify.
Unread 09-19-2013, 04:40 PM
tim-tim's Avatar
tim-tim tim-tim is offline
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
Let me start with I design sheet metal parts on a daily basis. While the top bend that would connect the two flanges is rather difficult, the guys in our shop would say its doable. The caveat to that is I work with extremely skilled artisans that do this for a living. That being said I would never ask them to make this.
That "S" bend in the part is what we would call a joggle. There are special tools and techniques that make this easier. Keeping tolerances can be difficult and may take time to get right.
A more simple solution would be to rivet/bolt a gusset plate across the top two surfaces.
This will also work, and most likely be stronger than the above mentioned method. Just be sure to leave room for tangent lines when designing the length of the inside piece. I wouldn't design to the exact distances given by CAD. Give yourself some room.
If you decide to use this method or Adam's method, be sure to give yourself more than a single attachment point between the two pieces. I would use 3 points or so.
Again, this is doable but not preferred. In order to do this you would need dies (or fingers) of the exact length of the flange. This could require cutting tooling. It is also a bad idea from a stress standpoint. A sharp corner (the tangent point of two bends) should be relieved. Most software packages have this as an option in the sheet metal tools. I would put about a 1/16" or so relief radius in this part. It generally also applies to bends that are in the middle of the parts (eg the flange doesn't run the full length of the part).
I would also recommend putting a radius or chamfer of decent size on each corner.
Hope this helps!
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
  #15   Spotlight this post!
Unread 09-27-2013, 06:10 PM
MetalJacket's Avatar
MetalJacket MetalJacket is offline
Has read the 2014 manual
AKA: Jesse Gibson
FRC #2068 (The Metal Jackets)
Team Role: CAD
Rookie Year: 2011
MetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura aboutMetalJacket has a spectacular aura about
Do you mind if I use this presentation with some modifications to help with training our members? (I will give you guys credit at the end of the presentation)
Team Role = !artTeam
2011 - Logomotion
- Virginia Regional : Tournament Semi-Finalist, Gracious Professionalism Award
2012 - Rebound Rumble
- Chesapeake Regional : Tournament Finalist, Gracious Professionalism Award
2013 - Ultimate Ascent
- Virginia Regional : Gracious Professionalism Award
