Thread Tools |
Rating:
Display Modes |
Re: Need Help With Sheet Metal Designing
JT, we've been doing sheet metal frames for 3 years now. Would be happy to send you those CAD models (Inventor) if you wanted them, along with info on assembly.
JTN, I'm also available if you some sheet help.
JTN,
The function of the part you are needing to attach is the driving force of the attachment method in the design. Let's list some methods to join sheet metal. Permanent joins
Semi permanent
Temporary/Removable Joins
Inter locking joins to position or fixture and increase strength, rigidity
What do you think of our list? Did I miss anything? Last edited by roystur44 : 19-09-2013 at 12:14. |
Thanks for all the replies! Sorry I have not responded yet, I have a habit of forgetting to post... so I will reply to all the posts in one post.
Travis Schuh: Thanks for the tip, I was actually thinking about doing just that, but I'd have to see how I could get a CNC mill to mill those tight corners. AllenGregoryIV: Yes! I have seen your robot, the sheet metal work looks fantastic! I really admired your robot last year. Thanks for all the great links, I will look into them when I don't have homework piled up... (tomorrow). Sanddrag: Post taken into consideration, thanks for clarifying. jspatz1: PM sent. Akash Rastogi: I will send you an annoying amount of Facebook messages if the need arises, thanks for the offer. Roystur44: I think we would most likely be using 3/16" rivets and screws. Your addition of dual lock at the end of the list intrigues me, I will look it up. Thanks for all the great replies! I will work more on the CAD model tomorrow and post an improved corner! Last edited by JTN : 18-09-2013 at 22:57. |
It seems like your resources are multiple CNC mills + hand brakes to bend metal. Maybe it's just me, but it sounds like those are resources better suited to tube and plate based construction with bent sheet metal for specific parts rather than a full sheet metal robot. In a lot of cases you can make good, rigid, light structure in less time and about the same weight going that route. If you have a turret punch / laser cutter sponsor and precision bending equipment, sheet metal does get more attractive.
Improved joint: https://docs.google.com/file/d/0B9fw...it?usp=sharing
Rather, make the inside dimension of one rail match the outside dimension of the other rail. Also, it looks like the two flanges on the left rail coming to a sharp corner with each other is a possible issue. Someone more knowledgeable in sheet working can clarify. |
Let me start with I design sheet metal parts on a daily basis. While the top bend that would connect the two flanges is rather difficult, the guys in our shop would say its doable. The caveat to that is I work with extremely skilled artisans that do this for a living. That being said I would never ask them to make this.
That "S" bend in the part is what we would call a joggle. There are special tools and techniques that make this easier. Keeping tolerances can be difficult and may take time to get right. A more simple solution would be to rivet/bolt a gusset plate across the top two surfaces. Quote:
If you decide to use this method or Adam's method, be sure to give yourself more than a single attachment point between the two pieces. I would use 3 points or so. Quote:
I would also recommend putting a radius or chamfer of decent size on each corner. Hope this helps! Last edited by tim-tim : 19-09-2013 at 16:45. Reason: Clarification |
