Go to Post Each team should ask not what their alliance can do for them, but what they can do for their alliance. - [more]
Unread 23-09-2013, 21:25
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
FRC #1629 (GaCo: The Garrett Coalition)
PhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond reputePhilBot has a reputation beyond repute
[FTC]: New 1/4 scale servos
I'm excited that FTC allows the larger 1/4 Scale servos this year.
I purchased one of each servo HS-755HB and HS-785HB
The 775 works as expected (180 rotation) tons of torque
The 785HB is weird though. It's listed as a 3.5 Turn Sail winch motor.
So I was expecting the same control as the 775, except just expanded to more turns.
However, the wheel turns way more than 3.5 turns.
Using the LavVIEW Schematic Diagram to control the servo, if I change the servo value from 5 to 255 I get about 8 turns of motion. It's very precise and normal except for the WAY expanded range. Setting the value too 100 will always return it to the same position.
However if I choose a servo value of less than 5 (like 0 for example) the servo turns slowly Counter Clockwise, and keeps turning forever. So, clearly no mechanical stop, but what's worse is that once it's run like this for a while, if I set the position back to a reasonable value (like 100) it doesn't go back to the same position that used to correspond to 100.
So it's not like a normal servo with absolute positioning, and it's not like a continuous rotation servo (since it only runs continually in one direction).
I've search all the hitec sites and they all say 3.5 turns...
Anyone have any experience with this servo..... It seems like the 0 code is a way to "home" the servo....
Phil
Phil Malone
Garrett Engineering And Robotics Society (GEARS) founder.
http://www.GEARSinc.org
FRC1629 Mentor, FTC2818 Coach, FTC4240 Mentor, FLL NeXTGEN Mentor
Unread 23-11-2013, 11:37
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Rookie Year: 2000
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
Re: [FTC]: New 1/4 scale servos
Great info! Have you learned anything new about the servos or used them on a mechanism on a bot yet?
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
