Thread Tools |
Rating:
Display Modes |
Re: FRC Blogged-Kit of Parts Drive System Option
Are you sure that's not just a coincidence?
The "Speed Loss Constant" in cell I5 is independent of the gearing in cells C12 thru D15, or the Drivetrain Efficiency in cell J5. . |
If I remember correctly, I once read a really, really old CD thread that said 81% was determined by taking one of 229's drive bases, running it to top speed, and measuring that speed. Ratio of that top speed to actual speed became the default "speed loss constant". I'm sure this number is somewhat correlated with efficiency, wheel size, tread type, etc etc. For most practical purposes it's "good enough".
Efficiency in JVN's calculator is used to calculate motor loading, not speed. |
As an extra piece of information, last year they said this about the 2013 kit drive: Quote:
Then that drastically reduces the coefficient of friction between the wheels and the playing surface, reducing the robot's ability to accelerate to the maximum drive speed, and possibly making it impossible to accelerate to 10 ft/s within the length of the playing field. However, they never said that the robot would be able to achieve that speed on the field. That was just the estimated speed.
I'm hoping that the dimensions are increased this year. The dimensions last year severely limited what teams could design (although it meant less clutter on the field). The fact that they somehow fit 6 wheels in a wide configuration makes me hopeful the dimensions are increased this year.
Has anyone tried modifying last year's wide 4-wheel KOP drive base in a 6 wheel base, keeping the same dimensions? This could answer the question of dimensions; if it's unfeasible or useless, then chances are that the dimensions could have been increased for next year. |
I hope the new dimensions stay. |
