Go to Post I wish I were on the GDC, just to watch everyone struggle to grasp the meaning of this. - Brandon_L [more]
Unread 25-09-2013, 16:45
KOGPaladin KOGPaladin is offline
FRC #3370
KOGPaladin is an unknown quantity at this point
Post .NET C# Based Add-On Help
So I am using an add-on that allows me to interface with special hardware in labview, and it works fine on brand new test projects unrelated to robot code (Blank VI's in a New Project.) The problem comes when trying to add it to our robot code, as (I believe) the cRIO does not have native support for the C#/.NET code. I am limited as to how much I can share on the nature of the add-on api, as I don't have permission from the author.
What I want to know, is if it's possible to make a generic addon that uses .NET 3.5 C# code to operate, compatible with the cRIO.
Oh, and the compiling error I get says
"Wire: Type not supported in current target."
Unread 25-09-2013, 17:01
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Rookie Year: 2010
Thad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond reputeThad House has a reputation beyond repute
Re: .NET C# Based Add-On Help
It is not going to be possible to run .NET code on the current CRIO because the libraries do not exist on the current VXWorks system. You can write native C++ code and interface with that through LabVIEW, but not .NET.
Now this could all change when the new RoboRIO comes out because there is .NET compiled for ARM Linux, and the base libraries should be compatible with a little work.
All statements made are my own and not the feelings of any of my affiliated teams.
Teams 1510 and 2898 - Student 2010-2012
Team 4488 - Mentor 2013-2016
Co-developer of RobotDotNet, a .NET port of the WPILib.
Unread 25-09-2013, 17:10
To confirm. I do not know of a .NET runtime for vxworks. LV supports ActiveX and .NET interfaces, but only on Windows for OSes where they libraries are there to interface with.
If the author can give C code such as a DLL, then it can be compiled as a .out for vxworks. That can be called by LV on all platforms.
Alternatively, you can read from the sensor or bus and pull the data straight into LV.
Greg McKaskle
Unread 25-09-2013, 20:39
FRC #3370
Thanks for the info, I guess i'll have to create a custom driver for windows to emulate a controller and program it in using normal methods. Alas, no custom interface for me >_<
Unread 25-09-2013, 22:21
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
If you're trying to write code to interface with a custom game controller/user interface, that would have to execute on the driver station side of things anyway. You could write a program in LabVIEW targeted to the driver station (where .NET is available) that interfaces with the controller, then sends data to the robot using Network Tables, UDP, or some other protocol.
This is assuming that the driver station will play nice with other programs running on the driver station that try to claim game controllers. As long as the driver station doesn't crash, the worst case scenario might be you have to start your software before you start the driver station.
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
