Go to Post While [a college FIRST competition] would be pretty fun, I think that you'll see this build season that mentoring is a heck of a lot of fun too. (except when the kids pretend to cut their fingers off to see your reaction) - Beth Sweet [more]
Thread Tools Rating: Thread Rating: 4 votes, 5.00 average. Display Modes
Unread 30-09-2013, 17:15
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
2015 Control System Alpha Testing
I was just informed that our 2015 Alpha Test Control system should be arriving tomorrow morning.
Our team is thinking through how exactly to test the devices. At this time, we'll be receiving:
roboRIO 1
Power Distribution Panel 1
Breakers (40A) 2
Voltage Regulator Module 1
Pneumatics Control Module 1
Battery cable 1
120A breaker 1
Serial cable 1
USB Cable 1
3-wire "PWM" cables 2
Talon motor controller 2
USB WiFi Radio 1
My question, which goes out to all the teams is this: if you had a chance to get your hands on the control system, what would you want to test and how would you do it?
Some things we're going to look at initially:
1. Time to boot (OS Running)
2. Time to code-available (OS Running and code executing - tethered)
3. Time to driving (OS Running and talking to the DS wirelessly, mainly a function of the USB Wifi Radio boot time)
4. Code interoperability - running our 2013 code on the new system
5. CPU usage - we're going to do some A versus B vision tests to really stress the CPU and compare it to the 4 slot cRIO.
6. ?
Remember a couple things before you make suggestions. We are a LabVIEW team, and we're using this to train new members. So we can't fill any C/C++/Java requests at this time.
In addition, we don't have elaborate test setups. If you want PWM accuracy measurements with oscilloscopes, it probably isn't going to happen... but we'll try to accomodate requests if we can.
I'm sure FIRST will have a series of tasks that they want us to perform as well. I do know that this control system is going to be placed our on 2013 competition robot and tested on a FIRST field. We'll keep a log of events on our web page: we hope to have pictures of the components up tomorrow. I'll start a seperate thread on that when it happens.
Finally, please keep in mind that nothing we post is official. We will not be posting code or associated documentation that is released to us by FIRST. This has been a request from FIRST to prevent multiple revision levels and confusion if documents that are not ready are made public. We are more than welcome, however, to post our own code, pictures, and anything we learn about the unit.
We will be demoing the controller at a later date and throughout the 2014 competition season.
Unread 30-09-2013, 17:28
BBray_T1296's Avatar
BBray_T1296 BBray_T1296 is offline
I am Dave! Yognaut
AKA: Brian Bray
FRC #1296 (Full Metal Jackets)
Rookie Year: 2010
BBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond reputeBBray_T1296 has a reputation beyond repute
Re: 2015 Control System Alpha Testing
Tests in a more physical way:
-How heavy is it (rRIO, PDB, Radio, Breaker)
-What are each part's footprints? are they bigger/smaller/different shaped than current system?
-Are mounting procedures similar? are ports easily accessible? (current PDB is tricky)
-No more sidecar? what is the status on that?
As far as software goes (though I have no experience in LabView):
-How does it handle multiple (or many) threads?
-Can it process images faster? Targeting? (our targeting took retro-reflective feedback, determined the useful return, calculated target distance, and sent numbers to other systems for shooter speed and left/right alignment)
If molecular reactions are deterministic, are all universes identical?
RIP David Shafer: you will be missed
Unread 30-09-2013, 17:44
Tom Line's Avatar
Rookie Year: 1999
Great questions. So,
6. Weight and dimensions of each component, and comparisons to current system.
7. Mounting system for each component.
8. Connectivity and component layout
As for threading, LabVIEW is inherently parallel. We don't have to do to anything special to have things process concurrently. LabVIEW handles that all itself. How would you test something like that?
As for the processing images, that's #5 on the list.
With regards to the sidecar - no, it's not needed. Almost all the standard I/O that you're used to is now built directly into the controller itself, and it has a small footprint and is very light (comparitively). Expansions are allowed through the I/O port on the top of the controller. There will be an external pneumatic controller (if you need to use it). General info about the RoboRio can be found here: https://decibel.ni.com/content/docs/DOC-30419
Unread 30-09-2013, 18:11
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Rookie Year: 2011
cgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond reputecgmv123 has a reputation beyond repute
Be sure to post plenty of pictures!
BadgerBOTS Robotics|@team1306|Facebook: BadgerBOTS
2016 FIRST Championship Tesla Division | 2016 Wisconsin Regional Engineering Inspiration Award
2015 FIRST Championship Carson Division | 2015 Wisconsin Regional Chairman's Award
2013 FIRST Championship Curie Division | 2013 Wisconsin Regional Chairman's Award
2012 FIRST Championship Archimedes Division | 2012 Wisconsin Regional Engineering Inspiration Award, Woodie Flowers Finalist Award (Lead Mentor Ben Senson)
Unread 30-09-2013, 18:19
kaliken kaliken is offline
294 Old Fart Mentor...
AKA: Ken S
FRC #0294 (Beach Cities Robotics)
kaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant futurekaliken has a brilliant future
As another alpha team, I just wanted to remind the CD community that we are under an NDA so there will be things we cannot answer. We will look to this thread to see what the community asks for to see how we can help. Just remember we may not be able to give you what you want.
If we get the familiar with the system in time we are going to attempt to bring it in our 2013 robot for an offseason events. Also, we will be bringing our unit to any fall workshops in the Southern California area.
2010 World Champions! Newton Alliance Captain: Many thanks to 67 and 177 for the amazing ride
mman1506's Avatar
mman1506 mman1506 is offline
Focusing on Combat Robots!
AKA: Marcus Quintilian
no team (WARP7)
Rookie Year: 2012
mman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond reputemman1506 has a reputation beyond repute
Information on the USB host ports would be interesting. Are there any native USB storage or camera drivers? Can labview access them?
Unread 30-09-2013, 19:22
I am Dave! Yognaut
AKA: Brian Bray
Rookie Year: 2010
Originally Posted by Tom Line View Post
I guess if I had seen this earlier it would have eliminated a few questions before I posted.
The design sure harks back to the pre-cRIO days.
just though of an important question:
-Will it survive being run over by a hummer like the cRIO can?
Last edited by BBray_T1296 : 30-09-2013 at 19:23. Reason: Just thought of something
Unread 30-09-2013, 20:12
Uh, ... no. Since that isn't really an FRC requirement, it isn't worth the tradeoffs -- weight, cost, etc. Similarly, the modularity used in industry is also removed -- it was added back in a new way.
To the USB question, the USB ports can do whatever the drivers allow, UVC is the video standard, and UMS is the memory-stick standard. You can get a pretty good idea of what is supported by looking at the standards on wikipedia and identifying the linux support.
Greg McKaskle
Unread 30-09-2013, 21:17
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
That's what you think! *goes and launches Photoshop*
Unread 30-09-2013, 21:18
I am Dave! Yognaut
AKA: Brian Bray
Rookie Year: 2010
Yeah, I figured as much just had to ask anyways. It would be schadenfreude to see you smash a brand new rRIO though.
Unread 30-09-2013, 21:31
Tom Line's Avatar
Rookie Year: 1999
While we intentionally fried a couple of Talons last year just to see how robust they were, I don't think we'll pursue the same testing regimen with the roboRio...
Unread 30-09-2013, 21:41
cgmv123's Avatar
AKA: Max Vrany
Rookie Year: 2011
Why, was it too hard to fry them?
Unread 30-09-2013, 22:11
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
Rookie Year: 2011
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Wait, was there a registration for becoming an alpha tester/how did these teams get selected for this?
Did I miss something?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 30-09-2013, 22:57
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
To echo Tom Line, we'll be doing similar testing from a Java perspective, and I'll be keeping an eye on this thread so we can try to duplicate tests and independently confirm results/find differences between different languages, if applicable.
dellagd - You can see the official Alpha Testing announcement here: http://www.usfirst.org/roboticsprogr...-alpha-testing
FIRST had a process for selecting teams to invite to be Alpha Test teams (There was no open registration for this - invite only, as far as I know). If you have questions on their exact process, I recommend asking them in a comment on the above blog post.
2007 - Present: Mentor, 2177 The Robettes
LRI: North Star 2012-2016; Lake Superior 2013-2014; MN State Tournament 2013-2014, 2016; Galileo 2016; Iowa 2017
2015: North Star Regional Volunteer of the Year
2016: Lake Superior WFFA
  #15   Spotlight this post!
Unread 30-09-2013, 21:34
There was the one FRC situation I know of ... see attachments.
Of course in the grand scheme of things, it doesn't do much good when the cRIO simply gets mashed through the bottom of the robot and crate. The energy has to go somewhere. The cRIO may survive, but you still have to build it a new body.
I hope Rick doesn't mind me bringing back painful memories.
Greg McKaskle
ID:	15239  Click image for larger version
ID:	15240  Click image for larger version
